Oops, what to do if wiper fluid was accidently poured into transmission fluid tank?
It appears that wiper fluid was accidently poured into transmission fluid tank.
Not sure what to do now.
Haven't started car or driven after adding wiper fluid.
Was hoping to try suctioning wiper fluid out with a turkey baster but can't find one. Even then, unsure if I could get it all out and if safe to drive after suctioning all that I can and adding fresh transmission fluid.
Suggestions on how to proceed?
Best Answers
kyfdx
Moderator Posts: 271,155
I think that's a good plan. Suction out all of the fluid that you can, then re-fill.LuckyDuck22 said:It appears that wiper fluid was accidently poured into transmission fluid tank.
Then, maybe do it again. Drive it for a couple miles, then repeat.
Other than that, have it towed to a mechanic to do the job for you.
Some transmissions are hard to drain completely. No idea if your vehicle is one of those. (this is the first thing I'd try to find out).Edmunds Price Checker
Edmunds Moderator1 -
texases
Member Posts: 11,187
Yep, take it to a good transmission shop, don't start it. There's not a 'tank' for transmission fluid that I know of, it dumps right into the transmission, so it all needs to be drained.5
Answers
The car if a Buick Lucerne, 2008.
I have no idea how to find out how hard it is to drain this cars transmission. Apparently there's not a drain plug for draining transmission fluid.
I'm leaning toward bringing it into a recommended mechanic since I'm a little worried that if I don't get enough of wiper fluid out and fill w transmission fluid, even following your very reasonable suggestions of suctioning again after that and refilling, driving a couple of miles and repeating, that I could mess up and damage transmission. The car is old, but has worked great.
