Visitor Agreement.
A manual clutch is much more durable until you fry the pressure plate and the throw out bearing (experience #2 on my dads current 1978 vintage Mopar iron) But a whole new clutch and flywheel solved the problem.
I've tried all kinds of 87 octane gas (BP, Shell, Marathon w/ 10% ethanol, Speedway, Sunoco) and they all seem to do the same (thought the ethanol mix was a little better). I was thinking of changing the plugs to see if this would help. I would just buy higher grade gas, but that stuff is getting really expensive.
None the less, if you guy (and gals) could recommend a good aftermarket plug it would be greatly appreciated. I would prefer a copper core plug versus some of the platinums. NGK, Autolite, Bosch, would all work.
Thanks again.
P.S. My milage has been around 16 - 17 at 5,000 miles and I don't really drive to nice
Also, has anyone had similar experiences "doing it yourself" and some words of advice.
I purchased the following items from CarQuest:
*ATP TX-109 spin on filter@ $9.72
*ATP TX-111 flat filter @ $12.92
*Valvoline ATF +3(specifically for Chrysler vehicles requiring type 7176)@ $2.29 ea
I only purchased 6 qts following the BOB.
Ed
Took my grandson to school today and to my amazement his teacher had a 2001 Dak 2wd pickup and she had rotors turned and 2,000 miles later new brakes. She unloaded the vechicle.
The verdict. The zone guy says to replace everything: rotors, drums, shoes, pads. According to him (Zone guy)DC has experienced NUMEROUS complaints about premature rotor wear and warpage especially on Jeep grand Cherokees. Seems the current pad compound "holds" too much heat rather than dissipating it thereby warping the rotor. Also, DC has had issues with their supplier of brake rotors (Bosch). The issue revolves around the rotors not being properly "cured" prior to initial machining at the foundry. What this means is that they will warp the first time they get a good dose of brake application. (No fake jake!)
Anyway, this all sounded fine I suppose. I didn't do backflips or anything. Since the part numbers for the pads and shoes are new due to a new pad and shoe material makeup, the parts have to be ordered.
I will say this, this is DC last chance to make good on a lousy design/manufacturing issue. There won't be a "next time" as I will pursue aftermarket components.
Maybe I should have done that already? Ahh but theres that thing called warranty!
http://www.dodgedakotas.com
Bill in NY
If there TRULY was a problem with the vendor-built parts then the VENDOR would be footing the bill for the replacement parts to DC.
BTW are you aware that BOSCH (or a predecessor) invented the first SPARK PLUG, FUEL INJECTION and ABS brakes! (not all at once.)
For what its worth, I could care less who makes the components for my truck. All I ask is use a little quality and put a little thought into the design.
It all boils down to lousy design and manufacturing processes. As I have stated previously, I owned a lot of clunkers in my day and most of those were driven at the hands of a less than careful teenager(me!) And I never had the headaches with brakes that I do now. I am not suggesting that DC build brakes just so we can abuse them but rather build brakes that last beyond the warranty period.
Maybe Bosch is footing the bill somehow? I don't know and thats not my problem. I do my part with respect to maintenance & I expected more from Dodge that what I have received so far.
While wipping dirt/dust off of upper engine surfaces, I found what appears to be some sort of U-shaped rubber grommet. It was on the right side, actually straddling a plastic hose that appears to go to the oil fill neck. The sides of it are about a 1/4" thick at the bottom of the U, and about 3/4" thick at the top of the U. I've looked in the BOB, but I'm not sure where to even focus. Any ideas?
I have the power door locks and they typically make an electro/mechanical chirp when they lock or unlock. This has been this way since I got my QC. However, recently the door lock occansionally makes a much louder, and I would say, definitely electronic, beep. Again, any ideas or similar experience.
Hope you've been enjoying the summer. Thanks.
Ron35
My '01, 2wd, has a rear end whine between 45 & 50 mph.
Any TSB or recalls I should be aware of before I take it in?
Also, there is a very annoying squeak/rubbing from the bed area when I turn. Any suggestions?
Thanks folks, this is an excellent site with great people and info.
I am not sure about your description of the U-shaped rubber grommet...
NO! i obviously didnt spend enough weeks thinking about this little diverter. i looked at the plug in place and it is smaller than my wifes subaru drain plug so i took her extra plug to make sure it would fit in the diverter and not clog it up and it did fine. well i put my diverter in place and loosened the plug and let it drop and whallah! it has a large flanged area that was huge compared to the wifes plug and it clogged the drain and it overflowed all over the skid plate and oil started seeping from a dozen or so little holes. well at this point i am very dizzy from the anger and disgust at myself and the engineers. i end up having to remove the skid plate and clean it up and the many quarts of oil all in my driveway. then once i got my fumoto valve with drain hose (thank god i did that so this wont happen again) i proceeded to the oil filter and decided that the little access panel was a bad design also so i removed that whole plastic cover so i could get to the filter and it went off without a hitch. point of story a 15 min project turned into a 3 hour deal including cleaning the driveway. the engineers should have done a better job than that. was it free crack day in detroit the day they came up with this stuff?
oily and disgusted,
robert
The "grommet" looks like the a "U", but with depth. The height is 1 1/4" by 1" wide, and the depth is about 1/2" at the bottom of the U and it is 1" deep on either side of the U at the top. Being rubber, it looks like it's to protect an opening from something going through the opening, or visa versa.
Anyway...
I don't mean to laugh, because I've been thru the same nonsense only difference is, I uttered enough choice words to singe a preacher's ears!
At least your oil filter came off, mine was literally glued on and I ruined two wrenches trying to get it off. Finally said (well, guess what I said) and punched a long screwdriver thru it and took if off that way. And I agree the teeny access hole is silly unless you are a munchkin from the land of OZ....or is it the land of Detroit where glass belly buttons are needed so VPs can see the light of day?
Bookitty
Try replacing a 500 pound electric motor mounted 200 feet up on a seperator tower (or even OILING it). Fortunately, he caught this while still on paper and had them re-think the design before building it.
(Power Distribution Center ... behind the battery)
robert
Excellent pics!
OH NO! Trying to make it out of the intersection... all gauges are normal... no smoke or unusual sounds. Acceleration sounds ok... make it about a block and pull over.. put into park and idle drifts then quietly stalls..
A restart of the engine seems ok... but power seems weak. I nurse my rig the 10 miles or so to the dealer.. where no unusual sounds come from the engine or drivetrain. I explain my symptoms and leave her in ICU. A rental RAM at dealers cost is available.
bpeebles, mopar67.. and thoughts? I will say one thing..if she had a carb, I woild SWEAR she backfired thru the carb (shadtree mechanic speaking here)... weird...
details at 11
Does this finally settle the hemi - not hemi discussion?
At any rate, I hope I'm wrong on this (now thats a first!)'cause thats some serious stuff there!
Glad you made it back to the dealer in one piece and I am sending court jester prayers onwards and upwards.
stay tuned for updates, same bat channel, same bat time
The problem i'm having is finding any sort of service manual. Can anyone offer any suggestions.
Thank you....
The Dakota manual costs about 90 bucks unless the price has changed.
First tire store says "Are you sure that is the size?" Yeah, I checked just before I walked in. He goes out to look at the tires. Sure enough. He says the only place you can get those is at a Goodyear store. Nobody makes a tire that size. This is the first sign that the price just went up.
The Goodyear store was literally next door. Walked over and asked for a price on the tire. The guy rummages through the price book. $205 but I can give you a discount today. Tire, stem, balancing, disposal fee including "today's discount" : $178.98 for one tire!!! I had a road trip the next day so I cough up the money.
I am thinking about changing from 255x65x15 to 265x75x15 to help fill out the fender well and improve the gas mileage (going on the idea that the taller side walls would make the circumference larger meaning farther travel per axle rotation).
Aside from having to have the odometer recalibrated, does anyone see any glaring problems with the new tire size.
(Per BOB!)
I saw this artical during my extensive research prior to deciding on purchasing my Dak.
You mis-interperted about the main bearings tho...
That "one piece 5 main bearing bottom end of the crank 'that'is glued in place with bathtub caulking" is actually a trick from RACING engines. There are almost 20 bolts holding this engine skirt to the block. The adhesive is there to ENSURE that the bottom-end is bulletproof. There is virtually NO twisting of this block under stress. The skirt is also made from nodular castiron and graphite!!
(BTW the ol 1960's-based "LA" V8s from Dodge [318, 360] are KNOWN to be hard on the main bearings due to harmonics and block twisting.)
As for the oil pump... it is NOT an AMC unit... instead, it is a brilliant design borrowed from AMC. A GEROTOR pump driven off of the CRANK that eliminates about 5 power-robbing, friction-causing mechanical linkages!
Rotors
Drums
PAds
Shoes
The pads and shoes are made from a different compound that is supposed to dissipate heat better than what was on there.
The dealer even washed the truck and I paid nothing for this (other than aggravation but how do you put a price on that?)
Hope this fixes it and I can go back to driving with ease. I will say this, the bounce and shudder is gone and braking is smooth once again.
WIll it last? Hmmm.......jury is out on that one.
SNOWCOUNTRY.....reply bpeebles is right, keep in mind for YEARS, japanese bikes with 4 cyl motors had the "split case design" and those engines often saw the high side of 9,000 rpm on a regular basis.
Two things I DONT like on this engine are the delicate magnesium valve covers to which the BOB states nothing should rest on them lest a hole be worn thru. Stamped steel never had that issue. Second, the idea of non replaceable valve guides is baloney! Especially when you can re do valve guides on a lawnmower engine. The BOB states if the valve guides are worn beyond acceptable limits, then the entire head must be replaced. All I hope is that aftermarketers figure out how to get around that.
Otherwise it appears to be a good engine, if a bit quirky at times. Lets hope it gets a good rep for durability, it seems to have all the ingredients for that.
Film at 11
The crank sensor has a TSB on ot for clearance problems anyway. (the 'tonewheel' hits it in some engines)
TECHNICAL QUESTION OF THE DAY; (for 100 extra points)
Without the CrankPositionSensor how does the PCM decide to fire the plugs and injectors?
It refers to pre set programing schedule.
Well my DAK is ready and waiting; I'll go get her at lunch.
Service guy asked me "both differentials"? I told them NO. Figure simple knowledge that
I am not going to tow >2000 lbs in 4 wheel drive at 60mph, but why does he ask?
Does anyone put synthetic in the front diff? or is it suggested in BOB?
Figure just trying to get my goat, or make $$ Starting to get that "incompetence training"
feeling from my dealership.
Ger
My question was meant to ask;
How does the PCM know what position the crank is in to fire the plugs and injectors without a crank-position sensor?
For example... if the throttle position sensor fails... The PCM can calculate an approximate throttle position based on intake air density, intake vacuum, and engine speed sensors.
Thusly, if the crank-position sensor is shot... what existing inputs are used to figure out when to fire the plugs and injectors?
There needs to be SOME trigger that tells the PCM when the pistons are on the compression stroke.
(This is why this question is worth 100 points)
ta da!
I know cause I had to get mine replaced about 90 days or so after I bought my truck. It made the MIL light illuminate then when it really gave up the ghost, it made the MIL light flash regularly.
When I first read this in the BOB, I thought that this was overkill because either one of these sensors would be enough to run the engine. In fact... most engines use just a crank-sensor or cam-sensor to calculate all spark and injector firing.
I am now convinced that this is another brilliant design on the 4.7L V8 hemi. Without this redundancy, one would be STUCK with a non-running engine due to a sensor-failure. With the 4.7L... one merely gets a MIL and can continue to drive in 'limp mode'.
Also, using both of these sensors. the onboard computer can determine if the timing-chain and all related linkages are properly functioning.
