tires on custom wheels
subub9gurusubub9guru Member Posts: 1
edited November 2020 in Subaru
trying to figure out what size tires i need to run to fit 22" rims on my tribeca b9. comes factory 255/55 r18, wanting to put 22" on it without having any major changes.
  • kyfdxkyfdx Moderator Posts: 275,130
    If Tirerack.com doesn't have a 22" size available, then you likely won't be able to do it without modifications.
    That was my thought as well!
  • skyisthelimitskyisthelimit Member Posts: 46
    What tire size did you end up buying?
  • NelsamNelsam Member Posts: 3
    Hey I could not able to find it in Bathesda, MD, which wheel size you have bought in the end?
    edited May 2021
    Found that that in silver spring MD, and the size perfectly fits.
