Visitor Agreement.
My cooler will be on ready alert once I have the plugs in hand...also the weather will finally allow an under hood check-up... time for preventative maintenance
Given that one does not change the plugs often, it makes since to go with higher-quality stuff that will go the distance. (How can a 97cent sparkplug compare to a 5$ one in quality?) The Bosch with nickle-plated threads, copper-core, platinum tip and silicon-ceramic insulator is far superiour to the others.
I have experienced the "cheep" sparkplugs actually seezing in the hole and break off when removal was attempted. (Can you guess what was needed to fix this?)
Did you know that this year is the 100th anneversery for the invention of the sparkplug... and BOSCH was the inventer!!
I've read enough from this site to understand the brake problem needs new, good quality rotors to cure. My current problem is seemingly intermittent low beams. I accidently found that it occurs only when I bring the tilt steering wheel down to normal drive position. Wheel up, low beams on, down just a little bit and lights off.
Does anyone have any history or memory as to whether this might be a switch, or a wire harness problem? I thought I'd ask before I get into it. Electrical problems are hard to trace and any suggestions would be appreciated.
I can provide information on TSB for those who ask. I have a subsctiption to alldata.com for the next year.
I cannot offer up anything for 1999, 2001, or 2002 as TSB tend to be model year specific.
FYI....900 miles on the hamster and she's chugging along...I miss the v-8 sometimes though.
(sacprof) When my 2000 Dak was two months old I developed a scraping noise within the steering wheel and a week later my cruise control wouldnt work and the airbag light came on..The problem was the clock spring so give that a shot first.
Thanks all
John
Post install test drive and it idles even better.. more power at lower RPMs (to me anyway) and feels better at highway speeds too... definitely the plugs to use in the 4.7..
How many beers do you rate this job?
My zuki will be less cause its only got four plugs to monkey with!
but you will be monkeying with the zuki as soon as you can, Im sure ...
Not much on there that looks like it could be modified save for the air intake and the throttle body. At least it has coil on plug ignition.
Heck, I might get bored and throw a catback on there, some headers, and some hi protein feed for the hamster.
I would bet that using the iridiums would be like using a little higher performance ignition. Everybody adds MSD coils to their non coil on plug systems to bump up the voltage and create a better spark, so why wouldn't a plug that sparks with less voltage be any different?
Happy motoring and keep us informed.
Blue!
The truck runs pretty good but new plugs won't hurt.
More in a couple of weeks when it all settles in better. I'll admit though that I am once again enjoying the drive!
John
The service person says it might be a leaking intake manifold. Any suggestions? Has anyone had a similar problem? Otherwise the truck runs fine; I really hate to bring it in. Thanks.
Robert
I too, have some ceramic pads on order for my 2000 Dakota (I allready have the powerslot rotors waiting to be installed.) NAPA tells me that the ONLY place they could find Ceramic pads was in Dallas. (I am in Vermont)
Here is the URL about properly seasoning the rotors and then bedding the pads.
http://www.shotimes.com/brakes/part1.html
I really got a run around getting the pads but finally secured a set from an auto parts store in PA. The store is AA auto and when I get home i'll post the number. So far 800 miles and they seem real smooth and Quiet. It dosent eliminate the dust but is much better. I'm running them on a set of Raybestos PG rotors so I'm hoping they hold up better than stock. I think I probably should have went with a pair Powerslots like yourself. Oh well. Back brakes will be next.
Thanks for the reply
John
While it was there I also had them change the transfer case fluid (didnt have any allen that would fit) and flush the tranny with Amsoil ATF+4 approved fluid. I had already changed the fluid in both differentials and I have been using synth in the motor already so now it is all synth.
Well, the next day when I went to work I noticed the tranny seemed to slip a little and I also needed gas so after I filled it up with fuel and checked my fluids, the tranny dip was dry as a bone. I happened to have a quart of the Mopar ATF+4 under my back seat and I dumped it in and it was just showing up on the dipstick. Well luckily I was near my Amsoil guy so I went to his place and we took a sample of the transmission fluid and topped it off with another quart. I hope there was no damage to the tranny and the sample should show if there was.
Well, I called the service manager at my dealer and left him a message as to what had happened and told him I would get back with him after I got the results back. (My luck huh?) Luckily the tranny feels great with it full of fluid so I hope no damage was sone.
Well anyway, I am thinking of changing the plugs to the Bosch +4. Anybody have anything negative to say about them? I think maybe that might help with my pinging issue, any ideas?
Sorry so long but you know me, always a soap opera in my life.
Good luck all,
Robert
When you get back, I'd roast the a*hole who "forgot" to refill your tranny. That's crap, just total crap! Which makes me believe that there simply ain't much to those ASE patches "technicians" wear these days.
Disclaimer: This post was in no way meant to hurt anyones ittle wittle fewings about the ASE patches. Just a Joke! hehehaha LOL... and so on
Robert
Not that DC is alone in this, I am sure it exists across all makes and models these days.
Well glad to hear your rig is running good for you anyway.
See this link..http://www.dakota-truck.net/faq/Chassis/gen3_turning_noise.html
'01 quad 4.7L 3.92 lsd. DodgeTrukn
Bookitty
Idles a little better at 500 rpm though. He said he hasn't seen anyone do below that. So I'm not as concerned as I was. The trip was with close to needing an oil change, trans flush and axle oil. (And truck un-waxed.) The next time I go on a trip (2-3 weeks) should decide if these Iridium plugs were a good choice as I'll do the new oil soon before any trip.
So far at just 1k, my Dakota '01 4.7L 4X4 QC runs great with the Danso Iridium plugs. No problems. Incredible pick-up. Do recommend.
Well I am moving to Fremont California in a month from Northern Virgina and I hope some of you know of a good dealer out there. Do ya? As you all know I am on a first name basis with 2 dealers here in Virginia and with the D/C reps. So it would be great to have a good contact in Cali so that after I tow my wifes car over 2800 miles I am sure I will be visiting the local dealer there with my track record on these dakotas, on my 3rd by the way. Did I mention that already? I cant remember its been so many! LOL....
Sorry I dont post alot of upgrade stuff but I can tell you how many beers it normally takes for most problems if any of you ever need that info.
This problem is a 3 beer job since it also started raining when I got to the store and I was scared about the window not rolling up so it earned 3 beers.
Sorry so long just kinda happy now that I have had my drinks.
Robert
I once had a shifting problem in my '93 - happened twice I think - and then never again...
I stopped - shut down the engine, restarted and problem went away.
We have a lot of computer glitches at work - I should be thankful these trucks work as well as they do with all the electronic systems involved.
Bookitty
On mine it is an intermittant problem so it is hard to track. I have been trying to pay attention to when it happens, and of course it hasn't been since I started watching. But, my question is, could there be a relationship to the weather? was it raining or humid when it occured to you guys?
PS: I am going to go visit Bookitty and drive his truck before I move so he can take over my Luck/Position as the D/C Lab Rat in the NE!!!!!
Thanks to everyone for your responses.
Robert
KarenS
Owners Clubs
http://detnews.com/2002/insiders/0205/13/insider-486681.htm
Happy reading...
