Dodge Dakota: Problems & Solutions
1525355575887
  • dustykdustyk Member Posts: 2,926
    I think your private mechanic is misinformed.
    Chrysler specifies that Hybrid Organic Additive Technology (HOAT) coolant must be used. This is available as Mopar Antifreeze/Coolant MS-9769 and is a 100,000 mile coolant. This is what the factory used on your Dakota and it is green in color.
    Typically the coolants that are orange are HOAT, however the DexCool and the Toyota equivalent are a different formula than MS-9769.
    NOTE: Chrysler permits a 50/50 mix of Ethylene-Glycol and distilled water as long as a HOAT additive is used.
    You don't say how many miles you have on this vehicle or how many miles you've gone since the flush. My first suspicion is that non-distilled tap water was used, the incorrect coolant, or a HOAT additive was not installed, or both.
    Dusty
  • waynesan2waynesan2 Member Posts: 5
    I also have a 2001 4.7L Dak 38K and was planning on changing the coolant. I went to two different Dodge Part Depts; both asked if my coolant was green, which it is, and sold me their overpriced MS-7170 (3 Year Formula.)
    The 2001 Service Manual states:
    "Note: Refer to the vehicle's coolant bottle cap to identify HOAT or Non-HOAT coolant. Non-HOAT coolant is green in color."
    My coolant cap does not indicate the coolant type. Do I use MS-7170 or MS-9769?
    My 2003 Dodge service manual says the same thing. The paragraph following, however, confounds the issue:
    "The use of aluminum cylinder blocks, cylinder heads and water pumps requires special corrosion protection. Only Mopar(R) Antifreeze/Coolant, 5 year/100,000 Mile Formula (glygol base coolant with corrosion inhibitors called HOAT, for Hybrid Organic Additive Technology) is recommended. This coolant offers best engine cooling without corrosion when mixed with 50% distilled water to obtain a freeze point of -37C (-35F)."
    This is prefaced by the following caution statement:
    "CAUTION: Mopar (R) Antifreeze/Coolant, 5 year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze. Mixing of coolants other than the specified (non-HOAT or other HOAT), may result in engine damage that may not be covered under the new vehicle warranty, and decreased corrosion protection."
    I believe that the factory coolant was HOAT, even though it is green. The MS-9769 coolant is a very specific material, different from other HOATs because its glygol-based.
    I think you need the MS-9769 version.
    Best regards,
    Dusty
    Dusty, thank you for your reply. Since the MS-9769 coolant is 5 year/100,000 miles, I think I will hold off on the change until I get further clarification as to which coolant is in my Dak.
  • arrangerguyarrangerguy Member Posts: 18
    Hey guys, im a new dodge dakota owner!, i have a 2000 4.7l 4x4..auto transmission with 62k on it. I have the SLT package. I dont know much abut dodge so here it goes! First off, my truck idles around 500-575 rpm, normal or bad?...2nd..the brakes suck, and suggestions? 3rd, i have clunking noises coming from the back of the truck, any ideas?...and one more thing...i have a weird noise coming from the dashboard when im stepping on the gas pedal, anyone had this problem? So far i love this truck, but want to make sure everything is in check before my 30 day warranty goes bye bye, if you guys could help that would be great...oh and one more thing, i notice sometimes too when i am stopped at a light, the truck will jerk sometimes...like, someone softly hit me from behind or something
  • ford_biiford_bii Member Posts: 120
    1. Idle speed of 500-575 is normal
    2. Brakes... do a search on this forum for "brakes". You will get all the info you need about what people have suggested.
    3. My truck has 37k on it right now, and it is screechy/squeeky underneath. I'm not sure what to tell you on this one.
    4. "Weird noise" - need more description. Does it only happen under hard accelleration? It could be the valves tapping a bit.
    5. Next time you feel the bump, see how much gas is in the tank. If it is at around 3/4 - 7/8 full, this will happen. I get it too. There must not be enough baffles or something in thet tank that causes the fuel to slosh back and forth when stopping which causes the feeling like you got tapped.
    >>>my truck idles around 500-575 rpm<<<
    Normal when not in defrost or air condition mode. Slightly higher when the air conditioning pump is engaged or just after a cold start.
    >>>brakes suck<<<
    Being a little more specific would help. But if this truck doesn't have clean rotors or punky pads were installed at the last brake job, this could give you the impression the brakes are not applying forcefully enough. Dodge trucks have a long history of not over boosting their power brakes. Depending on what vehicle you've been use to driving, this may take a little getting use to.
    >>>clunking noises coming from the back of the truck<<<
    Loose or worn u-joints, especially at that mileage. Loose shock(s)(?). Spare tire loose(?). Squeeking noises on Dakotas are usually associated with the rear sway bar bushing. Fronts too.
    >>>a weird noise coming from the dashboard when im stepping on the gas pedal<<<
    As _bii_ said, we need a little more info on this. Is it like a single click sound?
    >>>sometimes too when i am stopped at a light, the truck will jerk sometimes...like, someone softly hit me from behind or something<<<
    Yes, this is as _bii_ said. I think you'll notice that it doesn't do this the lower the fuel level in the tank.
    Best regard,
    Dusty
    thanks, i did notice that when i put my defroster on my rpms were around 700-725...for some reason i think 500 is a little low, but oh well. I have been hearing that the dakota 4.7's are known to stall? if you guys know anything about that please share what ya know...and also, has anyone had alot of transmission problems? mine seems okay...not really sure though what the life expenctancy is?
  • scruplekscruplek Member Posts: 33
    Dusty,
    I think I used the wrong wording in my question because I termed the red coolant as Dexcool when I should have termed it as HOAT coolant. Sorry, I am ignorant on all this terminology. Basically this is what happened: June 2003 got flush at 67,500 miles. Receipt says used GREEN coolant with part number 4267020-AB. 2/2004 heater core goes out. Dealer says too bad. Has nothing to do with anything they did. Wants 800 bucks to fix it. Private mechanic fixes for 400 bucks. Replaces with green coolant cause that was what he drained from it. 4/2004 (2 months later) heater core goes out again. Something cannot be right. This is just too weird. Mechanic contacts a friend who works for Dodge. Gets hold of data sheet from dealer connect site. Sheet says specifically HOAT coolant should be used which is MS-9769. It specifically states that NON-HOAT coolant is GREEN. We bought another heater core and bought the MS-9769 coolant. IT IS RED NOT GREEN. So my beef is, did the dealer put the wrong coolant in it when they did the flush and cause the corrosion???? The truck now has 87,000 miles on it.
    Scruplek
    Arranger, yes the 4.7 does idle low for a engine nowadays, especially for a smogger. As far as reports of stalling, I think this is like the reports of Chrysler automatic transmission failures. One stalling 4.7 has turned into thousands by continued repeating of those glad to spead the negative word.
    My 2003 has never stalled at nearly 24,000 miles. I've talked to several dozen 4.7 owners and they all have had nothing but praise for how the little 287 runs and no reports of stalling. I believe there was a Chrysler TSB that addressed some idle issue back in 2000, and I think there has been two PCM reflashes that were issued for the 4.7 since its been introduced.
    What you might experience is an inconsistent idle at times. As I approached 12,000 mine would occasionally idle a little rough, especially in the extreme cold weather months. Most of the time it idles very good. Some have reported changing spark plugs and resolving the issue. I removed the factory Champions and installed Bosch+4s. The first few days it idled like glass, but within a month I experienced one rough idle day. In all cases, moving the heater control into a defrost mode would smooth out the idle. Depending on fuel quality, the idle air port in the throttlebody can become gummy and cause irratic idle. I've never done mine, maybe because I use nothing but Mobil gas. I did do one a while back on a 2001 Dakota. I removed the Idle Air Controller Motor, spray cleaned the port and neoprene pintle. That did resolve the issue on that vehicle.
    Chrysler has decided to idle the 287 engine quite low and I suspect it wasn't just an arbitrary thing. My guess would be to meet emissions. I have the California emissions version. In warmer weather it idles fine. I would guess the 4.7s with federal emissions package are less finicky. I've talked to the Dodge technicians and they report "only a couple" of 4.7s with complaints of actual stalling, both on vehicles assembled before December of 2002. None since.
    As to transmission problems, if you have the 4.7 in a Dakota you have the 545RFE transmission. I have heard of two complete failures in a Dodge truck and both within a very short period of time od sale. My Dodge technician said they've only ever seen one apart and that was in a 2000 Grand Cherokee. The 545RFE is a fabulous transmission and it has a reputation so far of being almost bulletproof. Perform all required maintenance on it and I'll bet you'll never have it apart.
    Always remember one thing: never use Dexron-Mercon ATF in a Chrysler built truck automatic.
    Good luck,
    Dusty
    Please don't feel embarrassed at not knowing something. You'd be surprised at how many people are suppose to know that don't or don't know and won't admit it.
    Here's what I know.
    The type of coolant that is prescribed by Chrysler for use in 4.7 (287cid) engine-equiped vehicles is technically know as G 05. This material was developed by Valvoline and is currently supplied to Chrysler by Zerex as Mopar(R) MS-9769. This is a phosphate free, low silicate, ethylene glygol-based formula. This patented material also contains a defoamer and various corrosion inhibitors. It was designed by Vavloline to be a universal coolant, meaning used in a wide application range. It has a much broader freezing and boiling range than conventional glygol-based materials (50-70%). The additive package is listed as Long Life Specification, Automotive Specifications (ASTM D 3306), Universal Specifications (ASTM D 3306 & 4985), and the Fully Formulated Precharged Specification (ASTM D 6210). Mopar MS-9769 is the specified coolant for Cummins equiped Dodge trucks and Mercedes cars and approved by Ford North America for all newer models.
    It is a hybrid technology known as HOAT or Hybrid Organic Additive Technology, as opposed to Organic Additive Technology, known as OAT. Dexcool (GM) and Toyota coolants are examples of OAT. These two types should never be mixed. In addition, ethylene glycol (EG) and propylene glycol (PG) mixtures should never be mixed.
    There are different colors used in automotive coolants world wide: green, red, pink, blue, yellow, and gold. Color cannot be used to determine the coolant formulation.. The best example is Chrysler's use of green for its HOAT.
    From what I can tell the only safe material to use in a 4.7 Dodge truck is the Mopar MS-9769. I cannot tell you at the moment if the 4267020-AB is or is not HOAT. It could be. I do suspect that the coolant you're independent technician used was incorrect since a conventional ethylene glygol-based coolant would be aggressively corrosive to an aluminum system if it did not contain the anti-corrosion additive package. What usually happens is fine aluminum particles clog the heater core. I have been told that the additive package is available aftermarket and can be added to conventional ethylene glygol antifreeze, but I've never seen it.
    It is possible that you now know more than either your dealer's service staff or the independent technician.
    Bests,
    Dusty
    % antifreeze = freeze point = boil point:
    40% = -12F = 260F
    50% = -34F = 265F
    70% = -90F = 277F
    Maximum corrosion protection of MS-9769 occurs at 70% when mixed with distilled water.
    thanks for all your help. I have always spent alot of money on vehicles and have been lemons. I went against what my consumer reports said when it put the dakota on the "used cars not to buy" list...im hoping my insincts were right. i bought a 2000 dakota slt 4x4 4.7l v8....with 62k miles on it, with the auto transmission, infinity pack...new tires and blah blah. I got the truck for 12,500, and i put a warranty(powertrain) on it...i got it for 14,500 with tax and liscence(im in minnesota btw)...good deal? any more suggestions on how i can maintain my dakota would be great guys!
  • mopar67mopar67 Member Posts: 728
    "Arranger, yes the 4.7 does idle low for a engine nowadays, especially for a smogger. As far as reports of stalling, I think this is like the reports of Chrysler automatic transmission failures. One stalling 4.7 has turned into thousands by continued repeating of those glad to spead the negative word.
    There's lots more than just one. Well one if you just count me. But during my struggles with this, the service manager told me it was affecting Jeeps too. Enough that a TSB was put out to address that. I don't honestly feel a multibillion dollar company would go to such lengths just for one person.
    Likewise with their awful 604 Ultradrive...it was so bad it got black marks from CU, Motor Trend, and C&D.
    My comment wasn't meant to imply that there was only one owner of a 4.7 that had a stalling problem, but that one report generates the perception of many after being repeated so often.
    I have yet to talk to any owner in person that has experienced this on their 4.7. The techs at my dealership seem to indicate that, yes, they've had two but that's two out of a couple of thousand 4.7s they've sold. That's .1% Maybe there are geographical or environmental conditions that are present with this issue that explain a difference. I don't know.
    Unfortunately I see no evidence that this stalling issue was prominent in 4.7s, at least around here. Even in the Edmunds forum I can only recount two or three.
    As far as the A604, can't agree with you more.
    Best regards,
    Dusty
    Well, for the Western New York State area I think that price would be a little high. However, some of this depends on the equipment your Dakota has. Also, if you got the extended warranty that could explain the different. Some of those get to be pricey.
    In October of 2002 I paid #13,700 (+ tax) cash for my new 2003 Club Cab Sport Plus, 2WD, 4.7, auto, Air, PS, PB, PW, 60/40 seating, AM-FM/Cassette/CD, sliding rear window, limited slip, off-road package.
    Your's has the SLT package, which I think in 2000 was all the chrome, side moldings, and leather interior (or was that the SLT+?). Four-wheel drive added about $1500, I think, onto the new price.
    Value can be somewhat subjective. I'd give more for an especially clean vehicle or one that I thought was in better that average condition mechanically. If your's was a one-owner then they must have been pleased with it enough to keep it 62,000 miles. That's generally a very good sign. Real low mileage for the year could indicate a repo, death, just not happy, repaired after a wreck, or an issue that can't be resolved.
    I guess you're in Minnesota. One thing, despite any flaws in the Dakota perceived or otherwise, they are one of the last to show signs of rust. I live in the "salt belt." The winters here are probably somewhat more docile than yours, but ten-year Fords and eight-year GMs are usually popping a hole somewhere on the body. S10s and Toyota's small trucks disintegrate so quickly that on a quiet night you can hear them rusting.
    I think you will find that the Dakota body will be with you longer than most.
    Best regards,
    Dusty
    After I got the third and final update to my PCM, the stalling and low idle problems went away.
    And, contrary to reports, fuel mileage did not go down and at no time did I have issues with spark knock.
    Hey dusty, lets petition DC to bring back the 727 ok? Oh, how I miss that transmission! Durable, reliable, easy to service, and very forgiving of a lead footed teenager, its the finest automatic ever built.
    Actually, the A-727 lives today in the form of the 45, 46, 47, and 48RE. There are of course some differences but the basic architechure is still the same. The A-727 and A-904s were strictly hydraulic shifters without an overdrive. I think the ratios are even the same in some versions. And there have been some refinements. But there most certainly was never a simpler and more durable transmission ever built by anybody, that's for sure. A-727 TorqueFlites are still used in racing and at least two companies are making them new.
    Unfortunately the A-727 would be considered outmoded by today's standards. The beauty of the A-727 was it's ruggedness and simple design, less to go wrong and far easier to repair. But it's beauty of the 1950s - 1970s would be it's downfall today. It would be criticized heavily for being unrefined against newer designs.
    If you accept the concept of electronically controlled engagement and shifting, the current "RE" series is just as robust and durable. They will be less tolerant of irregular maintenance and being more complicated will be more likely mathematically to have a problem. Heck, a friend of mine was ready to spend $1800 on a 46RE in his '99 RAM a while back until he found out that bad plug wires was causing his problem. You didn't have things like that facing you in the days of the A-727!
    Bests,
    Dusty
    who'd a thunk that plug wires could be a problem.
    I guess my complaint with the 45RFE is it simply never shifted properly from the get go. Not sure why or what because I never could get the dealer to understand my problem. All I got was, transmission functioning as designed. Well, I beg to differ. Any tranny unless it has a B&M shift kit that shifts so hard that it rattles the ring and pinion and makes the driver think he hit a pothole, has a problem somewhere.
    I even printed out the TSB on the harsh 2-3 upshift and I got blank stares. Seems no one at the dealer wanted to admit this was a problem.
    Well its all history now anyway. I do hope DC did get its act together on this because transmissions were Chrysler's ace in the hole.
    Yes, the 727 was outdated. But it worked. No fuss no muss. It just worked.
    thanks for your help...right now im going to take my truck in to figure out what that clunking noise is in the back. Its not the spare tire, i checked that. Its not even really a clunk or anytyhing, i cant describe the noise...i'll keep you guys posted. Yes this was a one owner truck btw, and it does have crhome package, sliding rear window...its fully loaded so to speak
    sorry to keep bugging you guys, but im afraid im annoyed by the 500 rpm idle...if i go to the dealership, is the flash for the PCM free since its their fault? or do i have to pay? mine is an 00 with 62k on it...do you guys know if its even worth it to get the flash? does it really help? i keep hearing 500 is normal...but some say 600-700 is normal...ugh it bugs me!
  • slickwilliedjslickwilliedj Member Posts: 252
    Experencing a slight squeaking/rubbing sound coming from the rear of the truck only when making slow parking lot turns or after coming to a complete stop and turning a corner. This seems to occur after the truck has been driven for approx 3 miles and is warmed up. Will not occur when its cold.
    I recently had a front brake job done and they adjusted the rear brakes. This noise seemed to start shorly after this service. I've driven the truck approx 2,000 miles since this brake job. The noise has not gotton any worse or better. Today I took the truck to the same facility which did the brakes and explained noise and took the tech for a ride. They reinspected the rear brakes and found they are fine and not sticking, rubbing etc and the noise I'm hearing is not coming from the brakes. Thus the tech suggested that the clutch plates in the rear end may be making some noise and recommends just dealing with it or adding some friction modifier and seems to think its nothing to worry about that some vehicles with lsd's make some noise once they have some miles on them? any one else experence something similar?
    fyi 01 q/c sport plus 4.7l auto, lsd 3.55,33,000k
    The symptom you describe is very typical of a limited slip differential with the clutches chattering. I suppose you could just add some friction modifier, but I would strongly recommend doing a complete drain, clean, and reinstalling new lubricant and friction modifier.
    The recommended maintenance cycle for the rear axle is 36,000 miles anyway.
    Best regards,
    Dusty
    is it free, or what do i do to go about it, is it worth getting?
    thanks for the info dustyk. I'm considering doing just what you suggested with servicing the differential. However, my mechanic seemed a little hesident on if he wanted to perform the job and recommended I take it to the dealer for a second option.
    are u sure on the recommended maintenance cycle?
    is this 36,000 miles for severe service?
    I thought I read that DC does not recommend changing the rear axle fluid unless you do alot of prolong trailer pulling for long dist then they recommend switching to synthtic fluid.
    If I do end up having it serviced eventhough I dont do alot of pulling I will have the synthtic fluid installed as an extra measure of protection.
    Does dc have a special part # for the synthtic differential fluid?
    Arranger, I think if your vehicle is still under warranty its free. Out of warranty I think they'd charge you a flat-rate. You might want to consult with a Dodge service manager to see if any apply. I don't believe there were too many PCM updates issued for the 4.7 and I think they all addressed very specific symptoms.
    Best regards,
    Dusty
    Well i heard they came out with a flash for low idle speed...thats what im trying to get done, and my vehicle is not under warranty...im going to call the dodge dealership on monday
    The 36,000 miles is based on schedule "B." I keep forgetting that schedule "B" occurs first in the service manual, then schedule "A." Changing the rear axle lubricant does not appear on the Dakota schedule "A," so it appears that its not required for "normal" service.
    In all my years experience, however, I can't remember a limited slip differential going 75,000 miles, much less 120,000, without needing some attention. I have a neighbor who just changed out his differential lubricant on a 2003 GMC at 13,000 miles because his limited slip clutches were clanging real bad. And he also found a quantity of metal grit in the case, enough that suspension carrying them around in the gear oil would definitely damage gears.
    I don't think that Chrysler recommends against lubricant changes for the rear axle. I think what they state is that regular maintenance is not required under "normal" driving conditions. You can't harm machinery by providing a higher level of maintenance. Besides, if you purchased this vehicle used you do not know how it was treated. I would change the rear lubricant just to be sure.
    There are two types of Mopar(R) Rear Axle Lubricants: 80W-90 Gear & Axle Lubricant, pn 4874468, and 90W-140 Synthetic Gear & Axle Lubricant. Both the small case (8.25 inch) and large case (9.25 inch) rear axle assemblies take 4.0 ounces of Mopar Friction Modifier, pn 4318060-AB. There is no gasket on the differential housing cover. You'll also need a tube of the special sealant, pn 82300234.
    The 90W-140 Gear & Axle Lubricant is synthetic. I don't have the part number handy, my apologies. This lubricant is recommended for severe service: carrying heavy loads or towing heavy trailers more than 50% of the time; long-distance towing of heavy trailers or heavy loads, or driving at high speeds for extended periods. This lubricant is a heavier viscosity and its increased film strength will reduce gear wear when the vehicle is used to carry/tow heavy loads.
    One thing that I will caution you on is using the 90W-140 in extreme low temperature conditions, especially if you do a lot of short trip driving in the winter.
    Best regards,
    Dusty
  • datagurudataguru Member Posts: 95
    After logging 15,600Kms or 9,700Mi, I've encountered my first clunk noise in the front-end. I'm surprised because I thought the steering components had undergone improvements for 2003 and later models. Also, have noticed that the front-end steering has loosen up quite a bit since when the vehicle was new. The wheels are tracking straight and tire pressures are OK.
    I hear this noise just as the wheels are turned to the LEFT while going over a speed bump or a similar situation. It sounds like the lower control arm is scraping the steering knuckle area. Would this be a worn out Ball Joint problem or a worn out shock problem. I thought DC was using improved UBJs from another supplier? Could it be the shocks are collapsing? No signs of leakage is evident.
    Any suggestions on troubleshooting this one? Thanks in advance.
    dataguru
    Data, suspension components were upgraded in 2003.
    What might be the problem is the front sway bar bushings. You could have a loose shock, usually the problem is at the lower mounting.
    Some loosening of the steering over time is normal. If it seems unusually loose you might have a loose tie-rod end.
    Of course, there's nothing to say that you don't have a bad upper ball joint. I noticed on mine that the grease seals are fully collapsed as if it never left the factory with any grease in them. Mine's still tight at 24,000 miles. No noises yet.
    Best regards,
    Dusty
    >>>There are two types of Mopar(R) Rear Axle Lubricants: 80W-90 Gear & Axle Lubricant, pn 4874468, and 90W-140 Synthetic Gear & Axle Lubricant.<<<
    Slick,
    The part number for the Mopar Synthetic Gear & Axle lubricant is 4874469. Its listed as 75W-140. I guess the older stuff was 90W-140. My error.
    Anyway, over-the-counter price is $19.20 per quart.
    Best regards,
    Dusty
  • edunnettedunnett Member Posts: 553
    I've read postings here that others have had trouble finding it, but I'm under my husband's '01 Dakota 3.9L and there is this black plastic housing around the radiator that I think I have to remove but am having the darndest (sp?) time trying to remove it! Do I even need to do this to get at the drain plug for the antifreeze? I've changed antifreeze before but not on a Dodge. Any advice appreciated! Thanks! Elissa
    Ok, found the black plastic drain cock and rubber drain valve and tube. I turned the drain cock all it would turn - about a quarter of a turn - and nothing flows out. Do I need the engine running? I have my radiator cap off and my reservoir tank top off. What am I missing? -elissa (thanks!!!)
    Elissa,
    There's two possibilities. You were either very low on coolant in the first place, or you haven't opened the drain cock enough.
    If you weren't over heating before you attempted this project, then my guess is there was adequate coolant in the system. This leaves the drain cock not being opened. I have yet to have the experience of doing this myself so I'm not aware if there are any peculiarities with the drain valve.
    Someone else in here able to advise Elissa?
    Best regards,
    Dusty
    Thanks Dusty! Working like a charm now! My other cars only ever required partial turn for the coolant to drain so I thought I'd turned it enough. Lovely! Now if only I had the torque to loosen the rear diff screws that I siloconed on so well 30K miles ago... ;-) -elissa
  • bpeeblesbpeebles Member Posts: 4,085
    Elissa,
    Many folks have encounterd that plastic drain plug BREAKING OFF when they attempt to drain the radiator. Replacements are available at a reasonable cost. You were lucky.
    Do not forget that there is more to changing the antifreeze than draining the radiator. There is the engine, hoses and heater-core that all should be drained. Also, that plastic cover you mention contains the overflow tank. I have removed that plastic cover and hosed out the overflow tank with the garden hose. I seem to recall that there are 2 bolts holding that cover on.
    Elissa,
    Bpeebles is correct. There is a plug on each side of the engine to drain the engine block and most of the system. The drain plug has a flat top and is located very close to the top flange of the oil pan. On your 3.9 V6 they should be fairly close to the middle of the block.
    On my son's '91 Dakota they were fairly easy to see. Again, I haven't had the experience yet on mine or a newer style Dakota. They usually come out a little hard. Some sealant on the threads is recommended when they are reinstalled.
    Bests,
    Dusty
    Anybody that reads this, what does your 4.7l v8 idle at, mine idles at about 500-525, please let me know what yours idles at(4.7l v8 only)
    Thanks Dusty and BPeebles! THanks! I never really drain the engine any more when doing coolant drain/flush/refill... I broke a $5 aluminum 'bleeder bolt' on my '93 civic once trying to drain the core and it was a $100 tow and service fee to fix, as the system could not be re-sealed. Without the Chilton or Haynes on the '01 Dakota out yet, I'm afraid I'd do more harm than good trying to figure out which is the coolant drain bolt. Although your descriptions will certainly help!
    I satisfy myself with more frequent drains than a full drain. <shrug> I flushed it a couple times hoping I'd get like 75% of the old coolant out. Probably not, but it looked clean and good and I did get the overflow emptied and filled a couple times too (even if I couldn't figure out where the second of those two bolts were).
    Of course NOW I'm finding all these posts on the CORRECT coolant - yikes! :-)
    Elissa
    Of the 6 spark plugs that I replaced on my husbands' '01 Dakota 3.9L 6-cyl engine, one came out a little oily. :-( When I change the oil, we're usually down two quarts every 3K miles and have gotten in the habit of adding a quart now and then. Hm... Other than that, seems to have the usual power and no visible blow-by out the tail pipe. Anyone from California care to comment on the possibility this might hit me when we go to have it smogged? It's still under CA emissions warranty, but I'm trying to put off the $100 cost of a smog unless I know there's a chance it will fail. Anyone have experience with only one leaky piston/cylinder effecting emissiosn tests? Thanks!
    Elissa
    Dusty,
    thanks for confirming my thoughts.
    I'll check to ensure the tightness of the shock mounts, tie-rod ends, status of the ball joints, etc and lube the bumper stops and sway bar bushings. Again, thanks for your help.
    dataguru
    Elissa, these things are hard to judge without actually seeing the spark plug. Two quarts every 3000 miles seems high for a 3.9, to me anyways. My son's '91 has 270,000 miles on it and it uses less than a half-a-quart between oil changes. Most of the Dakota V6 owners I know seem to be reporting between one quart to none in 3000 miles. I may have run across somebody that used more.
    If the engine seems to run fine (ie: no skipping, plug fouling, loss of power) then you might be okay. Have a fresh plug in that cylinder just before you drive it in for the smog test and it might pass.
    In my experience on the 3.9s the valve guide seals get brittle after a while, with either high mileage, poor maintenance, long periods of misuse, or poor oil quality. I've seen some go 150,000 miles and the valve guides are still fine, but you could have a worn one. Not as common on Chrysler V8s as it is others. Clogged oil returns can cause this problem and an indication would be plug fouling on the rear cylinders first. Chrysler oil returns are huge compared to most, but I have seen it happen on a 318 many years ago (that was caused by someone disconnecting the PCV valve, by the way). If this vehicle has been neglected at all or used mostly in stop-and-go driving, You might consider pulling a valve cover to inspect the returns.
    If it's been run too cool or sat for a while, you could have a frozen oil control ring. Give it a nice long drive with a couple of passing gear tromps. Might loosen up.
    Compression and leak-down test are the only way to confirm the cylinder condition.
    Bests,
    Dusty
    hey guys, i just bought my truck a couple weeks ago and now im having trouble with the tranny, it tends to stick when im trying to slow down, and inbetween 2nd/3rd when shifting, it kinda seems like its grabbing..i have the 4.7l auto...anyone else have this problem, or know what i can do to correct it?
    thanks again for all the info... I think I will be servcing the differental and agreee that u really can't damage anything other then your wallet by over servcing a componet.
    Have you or anyone else performed the rear differental service before?
    How difficult is it?
    Is it worth doing it yourself or letting the dealer do it and keep your hands clean?
    whats the avg price for the lube and friction modifier?
    I've read in several other posts that some have changed and are using Red line instead of the Mopar brand. What do you suggest with brand Mopar or Redline or other brand?
    Anyone know who makes the Mopar lubes?
    Does it matter?
    If u can get that part number for the 90w-14090W-140 Synthetic Gear & Axle Lubricant u the man!
    *Is the friction modifier synthetic aswell or is just the gear oil? also is the friction modifier sold separate?
  • ron35ron35 Member Posts: 134
    slickwilliedj - I changed the rear differential fluid some months back and it is not difficult. This past weekend I did the front differential, the manual transmission and the transfer case. I have saved several past posts on this, which I can send to you if you like. In all instances I used Red Line Synthetic lube, in the differentials I used 75W-90 which already has the friction modifier in it, it was not necessary to add any additional friction modifier. I did use the Mopar sealant ($16.51) but you could probably use some RTV with just as good results. There was enough to do both differentials and have some left over.
    Ron
    Springfield, VA
    I just got done changing the rear diff fluid in my husband's '01 Dakota for the second time. I got sick of the thing leaking incessantly after a shop would do it, so I took over!
    You need the following:
    1) a 1/2 inch socket (i found having an impact wrench to be invaluable in removing the screws when they were over-tightened)
    2) mopar or other silicone RTV sealant
    3) mopar differential friction modifier if you have a limited slip rear
    4) gear oil (our truck takes 2.5 qts of 75W90 and I don't bother with redline or any synth)
    5) new rubber fill plug from dealer for $4 just in case
    If you don't remove the spare tire under the bed, you may also find a pump or siphon invaluable in getting the fluid into the fill hole also.
    Here's what I do:
    1) Assemble all materials and put drain pan and cardboard under the diff
    2) Remove spare tire for easy of access
    3) Remove all bolts on the diff
    4) Pry the cap off - it's siliconed on so may take some effort but it will come
    5) Let gear oil drain completely - it can be slow like an hour or more I like to wait
    6) While you are waiting, clean up the cap with brake cleaner - remove fill plug and check condition
    7) Clean surface of the diff that you will be adhering the cap back on to - make sure there's no gear oil left behind on that flat surface that will prevent the silicone from adhering.
    8) Apply gooey silicone (I wear rubber gloves for this entire process) all the way around the cap (note: the cap may be wider and larger than area you will be adhering too, check ahead of time for where the best place to apply silicone is).
    9) Carefully, put the cap back on the diff, lining up the screw holes
    10) Insert screws, hand tighten evenly around, make sure you have
    11) Let the silicone cure - I wait an hour or two
    12) Fill up to the fill hole with gear oil and modifier if required
    13) Pop new fill plug in - I like to silicone that on too to prevent leaking.
    You're done.
    The whole job takes me an entire afternoon that I can't drive the truck (because I'm anal and wait forever for the diff to drain and the silicone to cure) but only about one hour of actual labor.
    -elissa
    nobody wants to answer my question, so long
    Arrangerguy: which question did no one answer and why not just repost it to remind us - you've had 4 questions in the last week, so I assume you want to know where others are idleing?? That was your last question anyway. I have an '01 Dakota 3.9L that idles around 750 RPM. -elissa
    Elissa; guys, i do not mean to be a nusence, but i am a new dakota owner, i have never owned a dodge so i dont know anything about them. I was wondering what peoples 4.7's are ideling at, and also transmission in the 4.7...mine sticks when im coming to a stop...or feels that way anyways...anyone know a solution?
