2008 Chevy Cobalt Manual door locks - door panel removal?
Chrisb0923Chrisb0923 Member Posts: 2
edited December 2020 in Chevrolet
How do I remove the interior door panel to replace the manual lock top which broke off?
Best Answer
  • thecardoc3thecardoc3 Member Posts: 5,852
    Answer ✓
    There are some hidden screws. One is in the door release handle under the little square cover. There are two in the door pull under a little cover in the bottom. After that it's all push clips that have to be pried from the door and then once the panel is completely loose, lift it from the top of the door window channel.
Answers
