Dodge Dakota - Quad Cab
Regarding the front end noises, I recently read on the DML that there was a recall or something to that effect for this problem on 2000 QC's. Don't know if this is true and whether this applies to 2001 QC's as well, but you might check this out.
trglick
The second problem is alittle more troublesome. Again, this problem didn't really surface for a couple days after delivery. After the truck sits for a couple hours. It stalls when I put it into gear. ?????
Has anyone else noticed these problems? Does anyone have any ideas why my truck would want to stall?
Help. Is this live and learn or do I have something to stand on. Holdback ???. Before I go and see the dealer I would appreciate your remarks.
Just hit 3k on my 2001 QC SLT+ 4.7 auto. w/ T&H pack. Love the truck; drives great. Would not want another brand. However, the front end pop or creak is getting old.
I just read the other posts about front end noises; especially "mrquad"'s. I found a NHTSA post about a 2000 Dakota at Item #: SB610019. No other results or followup.
A while back, I posted that my QC makes a popping or creaking noise when making a slow right turn with brakes applied. It also makes the noise going over small speed bumps.
My dealer said it is "torque steer". I discovered later that t.s. would not apply to a QC FRONT end problem because it is a REAR-wheel drive!!!!! DC confirmed it in a response to my e-mail question. I'll be back @ my dealer within a few weeks for 1st oil change; will revisit the problem then.
If MRQUAD, or anyone else, has gotten theirs fixed, please post it for the rest of us.
PS. I have the folding metal (locking) tonneau cover. It's a good thing - and removes easily. I put marine weather stripping at critical points, but it still leaks a little. In case anyone is interested, I would highly recommend it.
THANKS,
GATOR72
After I noticed that my new Quad (which i love) didn't have a $5.00 underhood light, I installed the recoil light that I had stripped off my '78 before I junked it. You can get this light through Mr. Goodwrench (sorry guys) or your Case International Tractor dealer. I don't have the PN#. Since room was tight, I installed mine on top the fuse block cover. The wiring is simple if you know what is going on.
As for the shift light. The only time I see mine is when it does the bulb check at start up. Kinda glad it doesn't work, I think we all know when it's time to shift and don't need an idiot to tell us when they think it needs to be done.
Don
Bookitty
Carl
Yours is the second post I've seen regarding an increase in price between order and delivery. The first post had a $1000 price increase vs your 700$ price increase. The main question is where the price increase hit - the base price or the optional features. I'm assuming any price increase would be of the base vehicle itself, and should be uniform across the board. In other words, I think the dealer is trying to screw you. Why would DC increase the price of a vehicle they can't seem to move in the first place? My advice is to let the dealer know you'll walk and stick him with a truck he has to sell off the lot. Of course, if you put down a deposit, that might not be the best option. I ordered my Quad Feb. 10th, and did not sign anything (nor was a deposit required). I can't wait to see what the dealer says when it comes in. Good luck.
J
I have a 2001 QC, 4x4, 5spd, TH, Skid, etc...
Is there a way to put a tow hook(s) on the front of this truck?
I cannot believe that Dodge eliminated them!!! What stupidity is this??
If anyone knows if this is possible please share the information.
I agree this is stupidity not to have them. Is this Dodge's way of cost cutting?
The dealer wanted to split the difference of the increase at first, but then conceded to absorb the total increase.
I am not sure how to handle your dilema, as if I read correctly, that you did not sign for a specific dollar amount. If you had a signed invoice for a specific dollar amount, it would give you a little more legal leverage.
Good luck and tell us how you made out.
Bob
No squeaks, popping noises, or whines.
Only hear the very light clunks when shifting, which corresponds to clutch engagement/disengagement.
Only had one incident with the engine, it cut out for a second and triggered the MIF. 4 restarts later the light went out and has not returned. Dealer found nothing wrong of course.
Still waiting for the replacement window regulator part to arrive, so the driver's side rear window can be fixed. It would roll down smooth as silk but would jam trying to roll up.
- Dodge never really eliminated the tow hooks. They never offered them as a option. Even though Dodge designed in openings in the facia The only way to get them thru 2000 was as an accessory. Hooks for 2001 have not been released yet. If you really want some, I would talk to a shop that specializes in metal fabrication and have some brackets made. I know of no aftermarket kits to fit the 2001.
I picked it up the day after it arrived at the dealership. It was snowing quite heavily the day it arrived, so I doubt a potential customer took it for a drive.
I believe the dealership may have put some of those miles on it in order to check it out and make sure it was working properly. They had to at least drive it to a gas station, as I picked it up with a full tank of gas.
may want to call D/C customer service @ (800)992-
1992.
Bookitty
Just my 2 cents worth!
You might want to check and make sure that it is not the bed that is out of alignment. It is well known on this board that Dodge seems to install most of their pick-up beds crooked stating that they are "within specs." Seems silly, but that alone would make your axel look crooked.
If you ask, you will be surprised how many people on this board have this allignment problem you describe.
Just thought this might make you feel better.
Good Luck
It was disappointing to learn of your dissatisfaction, and understand
how this might cause you inconvenience or concern. The situation
written about is a function of your vehicle's design and is not a defect in
materials, workmanship, manufacturing or factory preparation. These are
the only types of defects covered under the new-vehicle limited
warranties. Therefore, there is nothing that can be done to "fix" the
situation described.
Although a more favorable reply cannot be provided, we do appreciate
your sharing your concerns with us.
My QC is due to arrive in a couple of weeks. The more I read the more trepidation I have about this. I'm pretty much commited to the deal already, and the truck is PERFECT for my needs, but....crossing fingers toes and eyes.
Best of luck to ya, slick. At least it sounds like your dealer is OK.
Are there better bed covers out there that one person can install? Does a leather/vinyl cover hold up well long term? Appreciate any comments.
My ONLY complaint is the sloppy way the dealer installed it. They had to drill 2 small holes on each side to bolt on the frame. They left the fine metal shavings on the bed floor and caused small specks of surface rust; (white truck). When I discovered the rusting shavings, I swept them out and waxed the spots to get rid of the rust.
The folding cover can be removed by unclamping both sides. But, you'd better have a strong friend nearby to grab the other side when lifting it off. It weighs about 80~90 lbs.
It IS made of aluminum; BUT, it is STRONG!!!! I constantly set stuff on it and it has never scratched or bent. My folding tonneau cover has a black painted surface that is extremely hard.
It does leak just a little; about a cup in a heavy rain. But, none of the other folding brands guarantee "no leaks". I have minimized the leaks in mine by installing marine weather strips along the front and rear lip of the cover.
I recently bought the QC rubber bed mat. It's heavy, but removes easily for washing, etc. It is better than a plastic bed liner because once water gets trapped underneath bed liner there's no way to get it out. Rust City.
My recommendation - Get the DC/QC folding tonneau cover. Protects your stuff, looks great and prevents the wind-pocket drag. If I had a website I'd post some pics for you. Is there a way to post pics here without having a website???
GATOR72
is nothing but BS written by a remote controlled idiot trained to answer as such. You should write back to tell him or her that "Dr. Frankenstein called to say your brain was in and please make arrangements to pick it up as soon as possible."
Bookitty
Mark
Mark
For any of you that are really interested/concerned about this subject, here is the list of "useful" threads over at MoparChat.com which I have collected since last October on this subject:
http://www.moparchat.com/forums/showthread.php?s=&threadid=11593
http://www.moparchat.com/forums/showthread.php?s=&threadid=11662
http://www.moparchat.com/forums/showthread.php?s=&threadid=11822
http://www.moparchat.com/forums/showthread.php?s=&threadid=11911
http://www.moparchat.com/forums/showthread.php?s=&threadid=21296
http://www.moparchat.com/forums/showthread.php?s=&threadid=22900
2000 2wd Quad 4.7 5spd 3.55lsd heavy duty loaded.
Not ONE trip back to the dealer, and no reason to make one either. I have been very happy with this truck. My '96 Grand Caravan had been in 4-5 times in the first year.
23,454 miles
AVG MPG 21.6 (max 24.2 min 15.3)
1,085 gallons of gas for $1,592 (in gas)
AVG $/gal 1.459 (max 1.999 min 1.179)
It still looks great (when clean). Right now it's covered in salt and sitting in 2" of fresh snow.
www.geocities.com/tbsbbishop/index.html
Boo must be getting close to his birthday too!
Cab. I took delivery of my Quad in may, with the only one trip for . This was a sensor/relay for the airbag light which came on inappropriately. My
first Quad if you remember arrived with the wrong axle ratio(s) and I refused delivery. I am really very pleased with my Dakota Quad Cab. I continue to receive compliments upon it, one reason being that the Amber Fire Pearl stands out. Guys like it and women seem to love it. Then there are those who absolutely hate the color. We have three
birthdays to celebrate in May. My beautiful bride of almost 43 years, our kitty, Boo and of course the Quad.
Bookitty
Glad to hear someone has a truck without problems. This message (complaint) board can be scary at times when reading about issues people have had with their vehicles.
My problems have been minor at least. A bad window regulator, still waiting for replacement part. MIF light went on once, problem has not repeated.
I really love this truck. My first brand new vehicle ever. The first V8 powered vehicle I've had.
That V8 rumble is music to my ears.
This weekend will be the 4 month anniversary. 2200 miles so far.
Happy Quadding.
Bob
HAPPY BIRTHDAY TO ALL YOU QUAD CABBIES!
"Oh, say can you see, by the Quad's dashboard light..."
