Visitor Agreement.
when cold, then quitens down. Must be normal?
8800 miles and no problems except popping in
frontend/steering, but that's getting less
noticable. Best mileage to date is 18mpg hwy.
But usually around 16mpg. Since gas prices
have dropped, I've tried 89 octane midrange
several times, a little better performance,
mileage? Or is it just me?
Bedliner? I use a bed mat, I like to see the paint. If it gets too bad then I'll cover it
with "x-line".
Truck is a year old now...Happy Birthday!
Brought the truck in for the 6000 mile maintenance interval and had the front seatbelt anchor bolt recall taken care of.
Been running fantastic. Gas mileage is about 16 mpg, mostly local driving.
I am still unemployed since 6/11/01. Unemployment has almost run out. Have been doing some construction work jobs on the side, and looks like I will have more of that work in the future.
Quite a difference from the electronics technician work that I used to do. Sleep real good at night though. Looks like I will be changing careers, at least until I find another electronics job.
Take care all,
Bob
We didn't HAFTA have NAFTA!
Good luck and best wishes to you in finding work. Now is a horrible time to be unemployed thats for sure.
As for brakes, the dakota is narrower than a full-size pickup, and is shorter length than several xcabs and 4dr models but a lot of it depends on the particular truck. Most full-size trucks have larger brakes. Electric brakes are great. I even changed the surge brakes on my boat to electric when they came out with a marine version, but they are no guarantee in all situations. I have seen trailer brakes freeze and lose capacity in the right conditions.
The main rule about towing with any vehicle is never tow within 10-20% of the towing limit except under rare conditions and never tow the limit or higher with any truck, period.
Greg
after 3 trucks done similar i have never had any rust or corrosion on the bed.
over the rail allows me to throw junk into the bed without fearing a dent or ding.
over the rail may rub the paint on the top rail surface if it is not protected with a foam strip.
there's my 2 cents!
Bookitty
Have been doing some construction work until another electronics job opens up.
Hope you, the Mrs., and Boo are doing well.
Bob
It has slowed down a bit.
Here's one!
Early next year I am going to get a Line-x or Rhino liner sprayed into my QC's bed. I am thinking about spraying the lower rocker panels/fenders/doors (maybe even up to the crease/styling line). Has anybody tried this? What about spraying that stuff on the underside of the sheetmetal? (where the fenders etc. are spotwelded to the floor pan piece)
I was going to try to put the clear plastic film on my rockers, but I will have to wait until it gets real warm or I find a nice big heated garage. The film cannot contour like the spray on stuff either. I think it may look cool, so I am going to use Photoshop to simulate it. I doubt that spray stuff would ever allow those pesky rock nicks, chips and rust spots. I think you can get the color custom mixed now too.
Any thoughts?
i'm off to find tires but wish all of you the best.
stephen
Quick answer.... the hi-tech oiling system tends to hold a lot of oil in the hollow camshafts and such... Engine must VERY hot and allowed ample time to drain...
If you want more specifics... please ask in the Dakota Maintainance area.
Any ways that has me noticing as I step out directly onto the ground off my seat edge. Particuarly the left 1/4 side seems like it may be sussepable to accelerated wear? I started sitting on a black towel to slo the abraision. (I have the stock gray fabric bench seat.
Underneath, while changing oil, I noticed the bushings that hold the front suspension A-frame arms (4X4). For a truck that was built in May, these black rubber bushings seems cracked and over squished (deteriorated?). Much like you would expect to see on an older car. Any one else see these? Are they major issues- hate to have dealer rip apart front end as I don't have much faith in most dealer techs.
I guess in a month or 2 I'll see dealer about my small issues.
Anyways, sorry for the ranting and raving , the other 95% of ownership experience is good. I guess I'm a little anal about my vehicles (but, I guess some others are here too.) If anyone has comments or advice on what I've said please respond.
Happy and Safe holidays to all.
Thanks, Tom.
Thanks for your help!
over some bumps and "CLUNK" ! Wow , it was loud! Didn't try to reproduce again at the time, had errands to finish..Gonna have to look underneath..Any suggestions? Will mention to dealer when I go for checkup on Jan10th.
Happy holidays to all the Dakota gang!
KarenS
Owner's Clubs
Bookitty
My update. Turned 40K on the way to the airport 12/10. The truck still hasn't had one real issue yet. Still averaging over 22+ MPG life avg, but it's winter here in MI and I'm having troubles even getting 22 MPG now. Same as last winter. Cold MI air cuts between 1-2 MPG. I haven't washed it in over a month, so now that I'm off for Christmas break AND it's suppose to be sunny and 36 degrees tomorrow. I think I give the QC a good wash.
Have a merry Christmas everyone
Boo - I was in Hazleton, PA last week. Really enjoyed the mts.
Bookitty
2nd question concerns a recommendation in the break in section of the manual. It says after the initial 60 miles "while cruising, brief full-throttle acceleration, within the limits of local traffic laws, contributes to a good break-in." Hoping not to sound ignorant (I am a very conservative driver), can some one explain to me what "brief full throttle acceleration" is? Pedal to the floor? How brief is brief?
Thanx again for all the help.
PS: Reasons why I chose Dakota over Tacoma.
1. No available manual on the 4dr. Taco.
2. The Dakota flat out, hands down, no
contest is the best looking 4 door truck
out there (even better than the 02
Ram). The front grill on the Taco 4dr.
killed off any chances of me buying for
the oft stated quality Toyota engineering
(what were they thinking when they added
that thing?!)
I just hope that 5 years down the line I don't find myself saying "I guess looks aren't everything". Time will tell.
Question 2..."brief full throttle acceleration" ...To me this means pedal to the metal.
"How brief is brief?" ...the time it takes the truck at full throttle to get up to the speed limit. A good way to do this, is when entering a highway, go for it! Wind that puppy up! Rev it up a bit to say 4k rpm or so. There is a rev limiter so the engine won't blow up. You'll note that once 3nd gear is wound up, it is past 55 mph.
Good luck and enjoy,
Bob
1)During "break in", use the recommended shift points. The intent is to NOT lug the engine for some number of miles. As you "learn" the vehicle, you should start to naturally shift as bobs5 has suggested. If you have to think about it... you need more time behind the wheel. (get some more milk ;-)
As the engine sees some miles, it will run smoother and the MPG will improve. (Most folks report this takes over 10,000 miles for things to settle out.)
2)Do not forget that that "Full throttle accelleration" MUST be followed by decelleration in gear.
The intent is to "seat the rings" and it is the decelleration that provides the necessarry forces on the rings to allow proper seating.
Does that mean that after the break in period it will be OK to shift at lower speeds?
And if you don't mind a few other questions.
1. From the manual: "Drive moderately during the first 300 miles. After the initial 60 miles, speeds up to 50 or 55 mph are desirable." Does this mean I should refrain from driving above 55 mph during the first 300 miles?
2. What brand(s) of oil filter do you recommend?
3. I live in east central Florida. Generally moderate temperatures year round. A few rare freezes in winter, summer can get very hot occasionally hitting the 100 mark. Engine oil viscosity: Should I stay with the "preferred" 5W-30 or would 10W-30 better suit my conditions?
I have the 4.7 5spd 2WD 3.55 LSD with the P215-75R-15 tires. Under normal driving conditions (EMPTY), I start in 2nd gear, shift into 3rd at 2,000 RPMs then shift into 5th at around 2,100 RPMs. I've had my QC for almost 2 years and 40K miles later this pattern works great for me. I use to drive a E-150 6 cyl with the "3 on the tree" shifting. My 2nd, 3rd, 5th shift pattern is just like my old "3 on the tree" shifting. When I am towing the camper or utility trailer, then I use all 5 gears and shift closer to 2,200-2,400 RPMs. If I need to "move it" (as we all due from time to time), I never get it out of 3rd by the time I have to slow it back down.
ABSOUTLEY!! This critical part of an engines life is when all of the newly-machined surfaces are rubbing on each other for the very first time.
There is a lot of friction in localized areas generating excessive heat in those areas. The microscopic "high spots" will smooth down quickly (within 300 miles) Driving at high speeds (above 55MPH) can change the "temper" of some critical engine components due to the localized heat buildup. Slower engine speeds allow the heat to dissapate adequatly.
2)What brand(s) of oil filter do you recommend?
Any brand-name oil that meets the specifications is fine. (I prefer Castrol myself) As for FILTER, please review the oil-filter-study web site.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
3)Should I stay with the "preferred" 5W-30 or would 10W-30 better suit my conditions?
5W-30 is the reccomended oil. Do not try to second-guess the manufacturers reccomendation. Your "conditions" will rarely test the "5W" part of the specification anyway.
Here is more about OIL.
http://www.fernblatt.com/longhurst/engineoil_bible.html
Usually shift at about 1700 - 2000 rpm through all the gears.
Guess every driver finds what works the best for them.
When I have to "move it", such as getting on the highway, once third gear is wound up, it is at highway speed and then some.
Can that power increase be made to the 01 4.7L?
The simple answer is NO... we cannot "update" our existing 4.7L V8 hemi engines. To get the additional power, DC had to change several INTERNAL engine parts such as cams, conn-rods and such.
Do purchanse the parts from your dealer and install them would EASILLY cost over $1500.
Instead, buy a superchargher kit for your 4.7L V8 hemi. You will get MORE than 260HP.
After 10 months I am very happy with the Q/C (my first truck). When we were looking before placing an order for this truck, my wife informed me that I could buy a Tacoma, but it was not comfortable enough for her to ride in for more than a few miles. She likes the Q/C.
After 10 months I also have only 5400 miles on the vehicle. (Retirees do not commute and my long range travel is by air). Perhaps by the time the one-year anniversary is reached, there may be a 6000 mile report. Generally my gas mileage has been lower than I have seen posted here, primarily because most of my trips are very short. And at this point I have heard not transmission whines, steering clunks, or other weird sounds such as those reported here. Either it is a good truck, or my poor hearing and good CD player make it unnecessary to worry about strange sounds.
Now that I have done my bit to speed up the slow down, Happy New Year to Karen and all members of this forum.
Your diagnosis of a headwind causing the difference certainly contributed to the difference but I suspect there is more to it than that. Was the outside temperture significantly COLDER during the return trip? Did you have the AC compressor on during the return trip?
Your understanding of the operation of the 45RFE automatic xmission is incorrect. It is a 4-speed tranny with 2 "second" gears.(SURPRIZE... it is a 5-speed) One of the second gears is used ONLY during initial accelleration from a stop while the 2'nd prime is used therafter as the "kickdown" gear.
You describe what gear the tranny is in and torque-converter condition pretty specifically... How do you know all of this information?
I guess what I am trying to say is that perhaps you are trying to compare this "state of the art" automatic tranny to other xmissions. You are fooling yourself. The 45RFE is so far advanced beyond the older transmissions that it takes a computer JUST TO CONTROL THE TRANSMISSION FUNCTIONS.
Example... the input and output shafts are constantly monitored and if any slippage is detected within the tranny, more pressure is applied to the clutches until the slippage is no longer sensed. As for your torque-converter lockup... the computer constantly monitors its function to provide the following 4 functions
1)No EMCC
2)Partial EMCC
3)Full EMCC
4)Gradual-to-no EMCC
(EMCC= Electronically Modulated Converter Clutch)
I submit to you that you CANNOT determine which of these 4 conditions that the computer is telling the TQ to do at any specific instance.
Why is yours not doing this?
GOod question. Welcome to the 45RFE world of wonders. Wish I had an answer. Then I would re work mine so I can cut my dry cleaning bills.
(2000 QC 2wd 4.7L 5 spd 3.55 LSD loaded)
Started the year with 19,410 miles and ended with 40,714 (21,304 for the year).
Purchased 959 gallons of gas (min $.99 avg 1.41 max 1.94) for a total of $1,353. Good thing I make more than minimum wage.
MPG (min 20.4 avg 22.2 max 24.3) Pulled the camper only twice this summer. Less than 75 miles each time.
Only maintenance cost was for oil etc. (40K trouble free miles)
Hope everyone had a great Holiday.
The truck is nice but the transmission is going to be the reason why I have the truck for a long time or not. So many of you have good things to say about the trans and I sometimes too have it run nice. It has been back to the dealer once and need I say more to that. I want to take it back again and I am almost ready to tell them to put a new one in but i know what they would tell me. Maybe if I had some more info on it I could "technically" blow their hair back and finally see some improvement.
http://www.atra-gears.com/gears/mar01/24_dr_dr.html
This is from the Automatic Transmission Rebuilders Association. Happy reading!
I was rather surprised when they said the repair wouldn't be covered under warranty. Evidently there's a 12k mile cap on brake-system wear items. I pointed out that their own technician confirmed I still had 8/32 of front pad left and that there was a fairly well documented history on the internet of other folks having similar premature failures on the rotors. The Service Manager, bless his heart, said that had I bought the truck at his dealership he might have considered a goodwill repair, but since I didn't... tough luck.
I am wondering how irritated to be about this. Other than going through this forum to tally up the number of folks who've had warped rotors, are there any suggestions? Is there a Dodge TSB or other official doc pointing to the rotors as a weak part?
Any advice is most welcome. Thanks!
twj
Jim
