MF and RF
McNicMcNic Member Posts: 4
edited July 2021 in Jeep
Any updates MF/RV on Grand Cherokee L Limited?
  • kyfdxkyfdx Moderator Posts: 273,875
    Which trim?
    2WD or 4WD?
    Term and mileage allowance?
  • McNicMcNic Member Posts: 4
    Both trims 36 mo/10k
    There are five trims available. Pick one.
    Also, 2WD or 4WD?
  • mrtrace1mrtrace1 Member Posts: 21
    edited July 2021
    Good evening. May I have RV and base MF for Summit Reserve trim (4wd).
    Zip code is 11434. Also, any rebates?
    Looking for 36 months/12k and 36 months/15k. Thanks!
  • MichaellMichaell Moderator Posts: 269,723
    .00029 MF and 47% RV
    $4080 incentives
  • edmundscomincedmundscominc Member Posts: 1
    Hi Mike, may I have 24/10K and 36/10K RV/MF/Rebates for Laredo/Limited (All 4WD). Zip: 02184. Altitude is based on Laredo, so the same as Laredo? Thanks a lot!
    Standard MF
    LAR / ALT - 73% / 64%
    LTD - 68% / 59%
    edited July 2021
    $4080 incentives
    Thanks. That is 1 low residual value.
    May I have for 36 months/12k miles?
    Also, are you able to provide breakdown of incentives (not certain if you guys do such on this forum)?
  • SEMI_345SEMI_345 Member Posts: 54
    Hey,
    2021 GCL overland 4wd v6
    MF RV and incentives please
    Zip-10549
    2021 GCL Summit 4wd v6
    Zip-10549
    Thank you!!
    $4080 incentives
    +2%
    SEMI_345 said:
    Hey,
    Zip-10549
    Zip-10549
    Thank you!!
    Standard MF and 57% residual
    Either trim
    Either trim
    What's standard MF?
    Also no incentives yet?
  • WilkenjaWilkenja Member Posts: 9
    Hello, looking for figured on a 2wd/ 4wd GCL Limited for 36/12
    MF
    Residual(s)
    Incentives?
    Either trim
    What's standard MF?
    .00180 MF
    No incentive info on the L model
    MF
    Residual(s)
    Incentives?
    Standard MF and 58% residual
    Either drive
    No incentive info
  • Stevew612Stevew612 Member Posts: 2
    Hello-
    Grand cherokee L Summit reserve 36/12k & 48/12k for 44230
    Stevew612 said:
    Hello-
    Standard MF
    56%/50% residual
