over heating, coolant not circulating
i have a 2005 dodge dakota. it over heats idling and driving at any speed. fan is pulling air just like it's suppose to. i have replaced the water pump, thermostat, flushed radiator and engine and still can't get coolant to circulate. the radiator is only 3 years old and the flush came out as clean as it did going in. one mechanic still says it't the radiator because the truck sat idle for about 8 months. another says no it's not the radiator but wouldn't give me his diagnoses unless i paid him $100 up front. all suggestions and opinions will be greatly appreciated. please help
My 2005 Dodge Dakota gets hot while driving w/ no A/C and in park while idling. It manages to stay at 180-195 right below mid notch when starting the vehicle and driving for about 30 mins then it starts getting hot gradually. When A/C is in use the cooling system simply can’t keep up cooling her down. I’ve replaced the water pump, radiator, fan clutch and thermostat. My guess there’s obstruction in the channel of the block of the engine or who knows??? I’ve opened rad cap to see if there’s circulation at its operating temp but all I’ve seen is just rising coolant more than moving fluid. I’m at lost with this truck and I’m trying to sell it. Any feedback would much greatly appreciated!!!
