can't identify light blinking in dash
Hi. 2008 Aveo. Changed timing belt, cam sensor. Went well. Have service manual, but it doesn't identify a red light blinking in the dash between the seat belt warning and air bag warning. page 3-43. Car has no spark & no gas flow, but fuel pump 50 lbs. Might this be an anti-theft thing like on Chrysler-made cars ? Can it be reset ? Thanks for your time. Greetings from Northeastern Québec.
The next question is, have you attached a scan tool and tried to pull codes from every module on the car?
Once that is done post every code and which module the code was set in.
Hi. Thank you for your time. My name is Gary. I am acting as a translator for a retired Chrysler mechanic who is trying to help a friend. We are 1 hr N-E of Québec City, and 1 hr away from a GM dealer. Manual I found is not the real GM book. Only shows how to replace components. Only code obtained with non-dealer code tester was cam sensor. Was replaced. Coil too. Checked if dud key for doors only.No. Replaced melted resistor under battery support. Not even dealer can tell us what that flashing red light is between seat belt and airbag warnings on small dash. All fuses good in panels. Once in a blue moon, while starting, will fire for split second and die, but not every time. Not a backfire. Normal sound but very very short. Looks like trip to dealer is on the horizon, as he can't pull every code in different modules with poor man's tester. Thanks again ! Gary Callaghan, Baie-Saint-Paul, Québec, Charlevoix County, Canada. finepiontegm@gmail.com
Can you tell me the exact code number? (PXXXX) Codes don't tell you what part is bad, they tell you what test failed. Which means just because the words "Camshaft Sensor" are in the description that doesn't automatically mean that it is bad.
If the security system was causing a problem you would need access to other modules on the car both for pulling codes as well as more advanced procedures.
