Toyota 2015 Highlander Engine Oil Leak ( timing cover) and Cost to fix it
NavgationNavgation Member Posts: 1
edited December 2021 in Toyota
First owner of a 2015 Highlander, just over 60k miles. Oil observed under the engine, no oil on garage floor. The service department at a Toyota dealer gave a quote of $5000 for front cover resealing. Leave as it is or need to be fixed ASSP? Where to fix it? Any suggestions? Thanks.
Answers
  • thecardoc3thecardoc3 Member Posts: 5,878
    The labor time guide estimates it to be 23.6 hours. The engine needs to be removed in order to remove the timing cover. I suspect the estimate isn't for just resealing the cover. Are they planning on servicing the timing components while this is apart?
