So while there aren't exact equivalents, the new X would fit between the old X and XS, and the new Limited would slot above the XS.
I'm not 100% sure but I think torque is unchanged, or at least not yet published. HP is 173 for the base and 230 for the turbo.
-juice
IIRC, they post financials on the web page and you can check to see how well they are doing.
IMO, being diversified and global is a good thing. The US market is not as emerging as one could want for best returns.
John
There's a ton of information about stock here, at FHI's site: http://www.fhi.co.jp/fina/english/share_info/stock.html
Also, Forester X is back to DOHC from single, as on the XT. I wonder if that means back to interference design.
I remember that my old Volvo 850 had a torque peak in the 4000+ RPM range, but that engine produced 80% or more of it's max torque from 2000-5000 RPM. So the actual peak was unimportant.
Sly
Bob
The new 2.5l will have AVCS plus more precise valve control with the double cams in each cylinder bank, so I bet it will be peppier.
-juice
The gray one is too mish-mash, they'd need to sort out the lights better.
-juice
And no, nothing of interest to translate on the covers.
Ken
But as Ken noted, even though they are similar, there's a world of difference in the details; which just goes to show that there can be a huge variation in how different artists "interpret" the basically same information.
Bob
Rather than a Spec B, those black & red seats may indicate a Legacy B4 Blitzen. Subaru is allocating a few to New Zealand this year, so maybe they're looking at the U.S., too. That would be a nice change. Sign me up for the sound system in this thing.
http://www.scoop.co.nz/stories/BU0504/S00242.htm
Bob
Also noticed that a face lift for the Legacy other than the US is already slated for next year!
Ken
Bob
The GC8 Impreza, IIRC was basically a shortened Legacy. Solid, but heavy for it's size. I wonder if weight is considered an issue with the next gen Impreza.
Ken
Much in the same way as the new Jetta and upcoming Passat are based on the same platform but they are very different autos.
What's even more interesting is that Toyota is using NiMH batteries right now for the Highlander hybrid, yet that article mentions FHI will supply Li-Ion batteries to Toyota. Those are better batteries, note that notebook computers made that swap a couple of years ago.
I think that chart is already outdated. Saab probably will not get that crossover.
Platform sharing is a funny thing. The Volvo P2 underpins the S60, V70, XC90, S80, and now the Ford Five Hundred and Freestyle! Top it off most offer the same Haldex AWD system. Yet they are remarkably different.
-juice
Bob
Bob
My guess is all performance aspects will be improved somewhat, much in the same way that just single AVCS improved on non-AVCS motors. I think what held this back from the US-market until now were emission issues. I guess they must have solved that. Dual AVCS has been used on JDM STis for a while, now apparently it's coming over here.
Bob
cam timing devices dont really add power, they just shift around the power band of whatever the profile cam your running by changing the amount of overlap thats present at different RPMs. To make more power, regardless of AVCS, you need bigger cams, turbo, etc.
Ken
Dual AVCS = Double VANOS
-juice
it probably will only help emissions and low- to mid-rpm, but it is possible that the change would allow Subaru to get aggressive with the high RPM performance and maintain good low-end tractability.
honestly-- I doubt they'd do that. but who knows.
~Colin
ps, haven't read the thread on nabisco yet
http://vocuspr.vocus.com/VocusPR30/Temp/Sites/1571/28f3cb03106d46359ba57ce82317cc1a/06_For- ester_Release.pdf
if the naturally aspirated 2.5L made more power I could kind of see this. but the gulf between the XT and other trims is too great not to offer a cloth model.
~Colin
I also see that the 5-speed gets dual-coned synchros on first and third. The same ones that were toasted on my car.
-Dennis
If so, I am glad I bought the XS as we did NOT want the moonroof. But the other features are great (alloys, rear disc, heated seats, 6 CD, etc.).
I understand the need for efficiency, but I don't understand how forcing buyers into packages makes for more sales.
John
It will be interesting to see how sales pan out, although none of will really know if the monthly sales reports continue to be issued in as confusing a fashion as they were last month.
All of this and plus we lost Patti as the Edmunds.com contact.
Is anyone behind the wheel at SoA? Remember the company wants to hit 250K units sold in calendar 2006. Holding Impreza, Legacy, and Forester sales flat from last year, the Tribeca will have to make up about 70K units to hit that. Uphill battle?
Joe
Just a quick few notes before my laptop battery dies.
Photoshops are dead on for the Impreza. THe 06 impreza has the new front grill. THere is also a "TR" version or "tuner ready", it has 230hp 2.5l turbo, leather, and the STi brakes from the years past STi's (not the brembos, the regular 4-pots)
theres also a limited production Spec-B legacy GT with the 2.5T motor, not the flat 6 that europe gets. We do get the 18" rims, bilsteins, and red leather interior, with nav and sport pedals... one color only.
The new foresters are nice, great face lift.
The B9 through the hills of sanfran is amazing. Took every corner like a champ! I hammered it. It took everything I threw at it...
Pics to come!"
Bob
That way I can end up with an even better car without having to put up with a moonroof and other stuff I neither want nor need.
Now to do some research to see if the reported beefed up rear cross member is a bolt-on as well . . .
however the neglible gain in HP definitely is not worth installing a new ECU and possibly (probably?) new wiring harness.
~Colin
For the OB, though, you can now get the H6 with cloth. It's just a change of strategy. The turbos were more popular, so they put them on the more profitable models. What Colin said.
Spec B with a 2.5T 6-speed sounds like a dream! Think of it as a luxury STi.
Now I want that Spec B. I might put my wife in one just to see...
-juice
-- monotube blistein struts (hopefully springs too, at least a little stiffer
-- older STi 4 piston brakes... not the huge red brembos from the current model, the black SUBARU emblazoned 4 pots.
-- six speed manual... subaru sure is stingy about deploying this gem of a transmission.
-- unique seats and interior
that's about it
~Colin
And no, you are not "most people".
-juice
That assumes that the old 4speed auto half shafts bolt right up to the new 5speed auto, which who knows when we will see that? Motor mounts are likely to be different too.
Unfortunately it isn't like the good old days when we could plug and play.
John
I see your point about the shift console being different for the 5-speed auto tranny, but any changes in the engine control should be able to be accomodated by a change in the brain box. In fact, I'll bet the touted improvements in the transmission come about only from reprogramming the control, not from any mechanical change within the just redesigned transmission itself.
And FL doesn't have any sort of vehicle inspection, at least not in my part of the state.
As I said, it might be fun to spend the thousands I would lose in depreciation in trading it in for a car that has things I don't want in making it into an even better version of what I already have and like pretty well.
A lot will dpend on what Subaru does for the next major change in 2007. I know I would never go up to a Tribeca and I don't like the station wagon type body of the Outback/Legacy - more weight and size with no real advantage in interior room.
I suspect Subaru will have to change their content (again) in 2007, this 2006 Forester lineup is very restricted. We were crying for changes in the FXT (eg manual with premium) etc, but it looks like we have compromises all the way around instead.
John
He said the '06 STi was dead on to this pic:
Also, a "battleship gray" (how he described it) will be available on the Forester.
Bob
Bob
~c
It will successfully bridge the gap between the Legacy (headlights) and the Tribeca (grille). Perfect strategy to get people used to the new look.
I like that better than the current STi, though the 9-2x is arguably the best looking WRX. :P
-juice
So they are importing just the Bilstein shocks? That's it?
The trans was the biggest upgrade.
-juice
As Colin said, it's primarily a sport suspension and appearance package, nothing more. I heard it was coming only in one color too, but I don't know what that is. Finally, I think there will only be 500 Spec Bs offered this year.
Bob
Hardly seems worth the effort. I like the seats, rims, even suspension, but does it go far enough?
-juice
Bob
