looking for a part
dr_hmleedr_hmlee Member Posts: 2
edited June 2022 in Acura
Hope everyone is doing well.
I'm looking for a part for my Acura ILX 2021. It is like a cover for underbody (attached image). It is located to front area and it's underneath of a vehicle. If anyone knows info (name, part number etc), I would greatly appreciate it. Thank you.
  • thecardoc3thecardoc3 Member Posts: 5,862
    It would help if you could get a wider shot so that the entire location can be seen. Even so that is a skid plate. It is there to prevent damage to sensitive components and appears to have done it's job. You can replace it if you want to but unless there is more damage to it than what is visible it isn't necessary.
  • dr_hmleedr_hmlee Member Posts: 2
    Thank you for your info. I think the skid plate is right after I looked it up. Temporarily I aluminum taped due to vibrating noise. I have not found any vendors to sell it so far, need to further dig. Thanks again.
  • kyfdxkyfdx Moderator Posts: 271,300
    Have you tried the dealer? There isn't likely to be an aftermarket part for a 2021 model vehicle. It's basically a body-specific part.
