Visitor Agreement.
FWIW, I had heard it was Outback's body that would differentiate from Legacy more than current models do. Same Legacy chassis/internals, however. Though Outback may not offer an XT to compare with GT, perhaps only 2.5 H4 & 3.6 H6. I think that Legacy design concept will look better as an Outback than a Legacy.
This bodes very well for the new Outback and Legacy sales...
Agree with the comment above about Nissan tuning CVTs well. Mitsu does not, so I hope they do perform like Nissans do.
Subaru has said the 5EAT is 4EAT JATCO guts reworked by Subaru to add a gear. Unless Subaru is being heavily subsidized (by whom?) in-house CVT development seems very unlikely. I presume even Toyota uses JATCO CVTs...Note that Nissan (JATCOs parent) uses Toyotas hybrid system. You scratch my back; I'll scratch yours.
Bb
But the 5EAT story came from Automotive Engineering quite some time ago with official Subaru source. That same article noted the costly mods by Subaru and the increased transmission weight that ensued...I recall 56 pounds.
For those who do not remember the close relationship of Subaru with Nissan there were hand-me-down Nissan body dies and even a Nissan model with Nissan engine and Subaru AWD and body. That Japan-only wagon model was called a Stagea.
Where ever manufactured a more expensive, heavier trans would be hard to justify for the lower end Subaru models, but eventually pressure to improve corporate CAFE will mean a CVT.
Yes, but those trans were for micro cars. More heavy duty shared CVT designs are already in use at Nissan and Toyota; why would Fugi waste the development money? With shared switches, etc already from Toyota, shared purchasing power for transmissions makes sense. Expect to find lots of shared pieces in the future.
http://www.legacygt.com/forums/showpost.php?p=2347041&postcount=3482
Outback
http://www.legacygt.com/forums/showpost.php?p=2347042&postcount=3483
I think it's safe to say that US-spec models will be similar—but not identical in terms of package content. Interesting that the cars now get an auto-up driver's window (finally!) and a rear camera comes with NAVI.
Also, it looks like the Legacy GT may be 6-speed only?
Bob
FWIW, I still stand by my long ago assertion that outsourcing the CVT seemed more sensible. If FHI is developing the new unit, it just seems less ill-advised if they have a history.
Bob
If they are using the unit from the mini car, I would worry about trans longevity. Let's see if there is a tow rating for the auto trans models.
If the fuel economy increase with CVT/3.6 liter is not significant over 5EAT/3.6l , there is no reason to choose a probably more costly CVT.
Bob
Agreed, but if the CVT is the old Subaru unit designed for a very small engine and vehicle it probably can't be used with the 3.6l. If the power of the 3.6 has been increased with direct injection to 280-300 HP, the limits of the Murano's trans may even be exceeded.
http://www.edmunds.com/insideline/do/Drives/FirstDrives/articleId=131970
Where did I see 30mpg? That's amazing numbers with the revised EPA rules. 2.5i of course.
From the US-spec model.
Bob
I think that is great. I averaged 20.3 in my '08 Outback over a winter (October to February). Other than weight, the only real difference was mine as auto versus his as manual.
Bob
Even so, 28 is fantastic for the winter months around here. My Escort is giving me about that over the same winter!
EPA numbers are similar, but in real-world driving the manual seems to win most of the time.
2.5T 291 hp 289 lb-ft (all-new engine)
3.6NA 252 hp 253 lb-ft
Sweet, even the base engine should be adequate. Look at the torque...
It is very likely the car will gain some serious weight, so the increases in power will keep performance in line with the current models.
That's 17% more torque than our 2002 had and I doubt it'll be that much heavier. Probably more like 8-10% heavier (300 lbs or so).
There will be some "official" news coming next week. How much, I don't know.
Bob
Now that Legacy is 72 inches wide I'll have to consider an Impreza or Forester for next time.
So much for the rumoured extra ponies in the 2.5i. Hopefully the modest weight gain will be offset by the CVT's efficiencies.
Bob
Now maybe they've just slapped on a highway overdrive a la Corvette but guess we'll have to see. I'd certainly like that in my WRX - I do find 5th a little short. AND I'm not bitter.
I have a 6MT Miata and 6th gear is actually slightly SHORTER than 5th gear on the 5 speed Miata.
Basically the ratios are all much closer together, and 1st and 2nd especially are much shorter for acceleration.
I'm getting used to it, 1-3 is fine, but 4-5-6 are so close I sometimes wonder if it's worth the extra effort for the extra shift. Go from 4th to 5th and RPM only drops about ~500 or so, same for 5->6. I end up skipping gears once in a while.
How they gear it is what matters most. Keep the 5 ratios where they are now and add a tall 6th, maybe, for cruising only.
Keep in mind—it is a sports car; and as such, Mazda geared it thusly.
Bob
http://www.autoblog.com/2009/04/04/v...o-from-iphone/
http://blogs.cars.com/kickingtires/2...oth-audio.html
This works with the iPhone 3.0 upgrade that's coming this summer, and will work with Bluetoooth-equipped (meaning NAVI-equipped) 2010 Legacys and Outbacks.
Bob
The new 6MT provides excellent fuel economy and
improved driveability, as well as quieter rides in high-speed ranges, thanks to its wider ratio coverage.
(from the press release in the jalopnik article)
And I also eagerly await the introduction of the 6MT to the Impreza (and Forester) line.
My guess is you won't see this before 2011—but I'm sure it's coming.
Bob
