Coolant Leaking, Please help, 150K
Please Help. 150k on a 2013 Jeep Grand Cherokee. I noticed a couple drops of coolant in the driveway and always ignored until now. The car heats up to 240 and the red coolant light appears on the dash. It continues to heat up to 280 degrees and then I get the red lightning bolt. I tried the pressure test and heard very faint hissing from radiator. Could that be it? Otherwise maybe water pump? maybe head gasket? I'm not sure and wanted to possibly not take in and instead fix myself but at this point I"m not sure where to begin. After 30 minutes of running or so, it starts to show smoke from under the hood but I can't place where it's coming from. Only couple drops of coolant on the skid plate. It's only about 30 degrees outside and I'm no longer driving it.
