Visitor Agreement.
Jim
Can anyone tell, from the pic, if the rear suspension is changed? All I can see is a lower link, but I can't tell if it's different.
--Bart
The Headlights are very very similar to the Trailblazer's as far as looks. Not a good sign IMHO.
-mike
It could have been *much* worse though, like that alternative design presented in that German magazine. But it's not too bad. Nice, even.
--Bart
• So far so good, need to know what's under the skin. There, frankly, I don't think it will change a whole lot. It's still got the 2.5 engine.
• "XS" I'm sure replaces the "S Premium" model. The pixs show a moonroof, leather and monochromatic paint.
• Tires appear(?) to be the same size, but a different version of the current tire. I'm hoping they'll be the same size found on the Outback, but it looks doubtful.
• No hood scoop means no turbo, which we all knew. That's coming in '04.
• Mag X sketches really did capture the "essence" of the new model, even if the details were not quite right.
• I really like the rear styling. It looks like there is no keyhole for the rear hatch; at least I can't find one.
Bob
I don't think we'll see a turbo here, we'll likely get the H6 when the time comes for more power.
-mike
-Brian
Bob
-Frank P.
-mike
-Colin
o Rear is much more tapered than the current one
o Rear doors appear to be smaller than the last ones as well as the rear windows on the sides.
o Definitely appears to have more ground clearance than previous model
-mike
Details I noticed from the front:
* foglights are recessed, a bit overdone
* grille looks more modern
* headlights are flared, more aggressive
* profile is almost unchanged
* gas cover must be remote-operated - no notch for fingers
* front flare looks more built in, nice
* rear flare flows back like the Baja's, looks better without cladding
* more space in the wheel wells
* more integrated roof rack
And from the rear:
* nice how the front fender flare flows into the door, very nice
* D-pillar has a kink in it, a la Lexus GX470, nice
* roof line does taper down, like the Matrix
* I don't care for the wheels much
* hatch looks much better, gives the whole look its biggest "face lift"
* nice blacked out trim
* nice triangular tail lights
* looks 2" higher off the ground (good catch, paisan)
Bottom line? Thumbs up. Looks familiar, but updated, taller and less "wagony". I does not look bigger, but we'll see how it is inside.
I'm much happier with the 2003 Forester than I am with the Baja, in a big way.
-juice
Bob
So will the NY auto show get the Baja, redesigned Legacy and the new Forester?
-Dennis
Bob
-Dennis
All in all, the more I look at it, the more I like it. Clean modern look, yet I can see familiar "foresterish" lines. Good job, Subaru!
Good catch, Kate, noone had mentioned the tint.
I'll add the angle of departure, which now looks really good. The approach angle is about the same, maybe a little better.
-juice
Re: the tail lamps: I find them somewhat Mercedes ML-ish
juice, I agree on the wheels -- I'll pass. But they look easy to clay.
paisan, I agree with you on the rear slope; it looks nice but IMO not worth the sacrifice in interior room. Same with the Legacy (GT in particular); the rear looks sporty but I wish it was squared-off for functionality.
..Mike
..Mike
BTW, that looks like the US-spec model, because it has cross bars.
-juice
Bob
Bob
The new wheels are more playful and stylish, so they do go with the overall look.
Gotta have cross bars - I use mine often. No cost cutting, please, Subaru. I will definitely notice if you remove things like the carpets, mud guards, fog lights, and cross bars. This level of content is really the last major advantage that the current Forester holds over the RAV4 and CR-V. It is crucial to keep prices reasonable and content high.
-juice
Bob
Ken's translation earlier mentioned 2" more length. I don't see it - unless the whole thing is scaled bigger, it does not look longer. The rear overhang actually appears shorter.
-juice
I have mixed emotions about stock cross bars, at least on the Legacy. Not having sufficiently researched cross bars, I bought the Legacy aerodynamic (not round) cross bar/carpet mat package (saving a whopping $10), which have fewer options than the round cross bars. The aerodynamic bars are quieter so I leave them on for impulse buys (which means I never use them). I use the round cross bars (Yakima) to carry bicycles.
So I'd rather buy aftermarket round cross bars that are IMO more functional than be forced to buy the default Forester aerodynamic cross bars.
I do understand your point, it's one more thing for the consumer to research and buy, and reduces functionality off the lot.
..Mike
..Mike
-juice
Ross
Bob
Bob
The premiere was supposed to be at 10:45, right?
-juice
-Dave
Bob
I can't wait to hear more on this.
Jim
edit: here's the link http://www.autoweek.com/cat_content.mv?port_code=autoweek&cat_code=autoshows&content_code=00145362
-juice
..Mike
I wonder what that "uprated" engine is -- could it be AVCS?
Ken
-juice
Bob
I think that's great. That means when the turbo arrives, the AVCS may trickle down the lineup!
-juice
Bob
I like Xtra Strength, though.
-juice
Interesting that SOA would offer a new 2.5 here when SOJ no longer plans on the 2.5 engine in Japan.
juice -- I just re-checked the article. It says that the overall body length increases only by 10mm but the interior cabin space increases 40mm in length and 20mm in width.
Ken
-juice
Sil
