Visitor Agreement.
The boxer engines should work fine in a truck actually now that I think of it. The reason they are pushed so far forward is that the front diffy is incorporated into the tranny. If they put a boxer with a traditional tranny and transfercase they could build em just like current SUVs are built, no?
-mike
But really, if the H6 fits in a Legacy, a Trooper could probably fit an H10 easily.
Maybe a gas 4l H8, and a diesel 5l H10 for heavy duty applications. Can you imagine?
VTD AWD, beefed up of course. Keep the TOD power split display and maybe even add the ability to lock the axles together. Better yet, let the driver adjust the settings manually, anywhere from 20/80 to 80/20. Set it to 50/50 and they lock together.
Sound good?
-juice
Bob
Noone has a boxer engine in an SUV, right? Even Porsche is using a front mounted V8.
Sacreligious, but I digress...
-juice
Bob
Ed
Bob
Also they'd need to tune the engines for much more low-end grunt. Even the 3.0H6 doesn't have a low-enough torque curve, IMHO.
I'd see more of the styling cues of the subarus ported over to the Subazu truck line, AWD/TOD on all the SUVs with the TOD Low-range, and on the Axiom an Indy rear. Rodeo I'd convert back to 2-door with soft and hard tops, and solid front axle with lockers front and rear. Subizu could make it into a Jeep Rubicon Killer. Subizu could make a wider longer version of the late 2002 Trooper and set that up as a TLC killer.
I'd conceed the V-engines for H-engines if they'd conceed the all-in-one transfercase and solid axles.
-mike
So by the time any SUV came out, we'd be talking EZ series. That's why I scaled up from the 3.0l H6, to H8 and H10 configurations.
-juice
Maybe for the HD line. At least one "mainstream" model (I guess Axiom) would have to go soft, to pay the bills.
-juice
Just as Toyota, Honda and Nissan has done, they draw their core buyers from existing customers within their respective brands. In order for Subaru to be successful, they would have to do the same thing. They wouldn't count on many (if any) solid axle Dodge Ram customers to come aboard the Subaru truck-train.
Bob
-mike
-mike
sounds like you read the thread Bob linked to last week on the iClub where "Jon [in CT]" presented his own theories in such a way that they might have seemed like fact.
I seriously doubt 2.5L H6 is in the works. I doubt even more that if a >2.0L turbo is in Subaru's immediate future that a 2.5L H6 would be the choice. I suspect he is basing his ideas on the fact that VW/Audi's "inline vee" 18-degree 2.8L V6 used a few millimeters smaller pistons for the 2.7L biturbo version. While it is definitely a narrow bore-spaced block just as Subaru's 3.0L EZ30, I hardly think it wise to assume Subaru would *NEED* to reduce displacement to make that engine viable for turbocharging.
I could go on but I've got work to do, apparently. *sigh*
-Colin
The car that busted Subaru out of its niche was the WRX. That's good and bad, of course, our community isn't as tight nit as before, IMO. Plus lots of young punks are crashing and increasing insurance rates, not to mention eating transmissions for lunch with high rpm launches at the track.
But the WRX follows all the Subaru characterisitcs - boxer, AWD, full indy suspension.
-juice
Questions is, how will they get more torque out of a 2.0l EZ series engine? Twin turbos, maybe?
The EZ series is very compact, the H6 is about the same length as the old H4. That might limit displacment in future models.
-juice
Bob
The current Rodeo is 106.4", the Troopa 108.7". Those are more capable of underpinning a large truck. Again, no overlap.
-juice
Bob
-mike
Bob
-mike
-mike
It may(?) happen when Hummer offers their H4*, a few years down the road. Could it use some Subaru running running gear? I wouldn't rule it out.
* = the next Hummer is to be the H3, which will use some Trailblazer stuff. It's rumored that a smaller still (Wrangler-like) H4 will follow.
Bob
the driver looks remarkably like you.
Bob
But anyone who knows me knows I wouldn't be caught dead in an exploder!
-mike
The first time I saw that commercial, I screamed: "PAISAN!" Then I realized it was a Ford, and said "Nah..."
I think Subie marketing folks have been hanging out here at Edmunds...
Bob
Dodge and GM trucks are still traditional. Only Ford has gone indy, and even then it's still full-framed. Toyota is mostly traditional, too, except for the DOHC iForce engines.
So really, Subaru wouldn't have much competition. They could capture the entire import segment for non-traditional trucks.
I find that commercial hilarious. They're really only arguing that the Outback rides smoother and is quieter than SUVs. They exxagerated a little for effect.
-juice
-mike
-mike
Looks at how many truck commercials show mud slinging and basically tearing up whatever trail they're using. I think it's a clever counter punch.
Kind of like the CR-V commercial that shows extreme sports guys wiping out, hinting that they are XTerra owners.
XTerra is not the only truck SUV, it's just that most trucky SUVs are failing miseraby in the market - Vitara, Tracker, Sportage, etc.
-juice
-mike
-mike
They are basically saying, look, you're not going rock hopping, so why not get a comfy ride that can still get you where you need to go, quietly and comfortably?
-juice
-mike
Actually, this isn't a hot issue because the rise of All-Terrain Vehicles has attracted almost all those guys who genuinely enjoy bombing around off roads, throwing mud. Now it is the ATVs that are doing most of the damage and attracting the most controversy.
Steve (in MN)
-juice
Steve
I can't speak for MN, but in NC, VA, UT, CO, NY, NJ, PA, etc it's highly illegal and un-called for to be off the trails. If offroaders see you pulling stunts like that they generally will call you out on it.
-mike
-mike
Around here, there's nothing left that isn't paved or developed. Old motocross sites in College Park have become Home Depots. The beach is about the only place left.
-juice
Bob
-Pining for the fjords in Florida!-
Steve
-mike
Steve
http://www.adport.com/backroads/
-Colin
Steve
-juice
