Visitor Agreement.
"A 5-speed manual transmission is standard, with a new Direct Control 4-speed electronic automatic available as an option. Models equipped with the 5-speed manual use the Subaru Hill Holder hydraulic clutch to help make starting off on an incline easier and safer. A 4-channel, 4-sensor anti-lock brake system (ABS) is standard on all Subaru models. Forester 2.5 XS and 2.5 XT models are also equipped with an Electronic Brake-force Distribution system (EBD), which enhances braking performance and stability through optimized braking force between the front and rear wheels."
-Brian
Bob
http://forums.nasioc.com/forums/showthread.php?threadid=321331
Ken
-juice
Cheers Pat.
-Brian
http://mccr.madcars.org/rwdturbo/Images/WRX%20Club%20-%202003%20M- odel%20Release/imagepages/image1.html
Bob
And, like the UK, the Aussies get semi-auto a/c on the standard WRX. I've always hated the manual recirc. lever on my Imprezas in comparison to the electronic buttons on Legacy's and overseas WRX's.
-Dennis
I know it's been brought up before on here, but I'm thinking that we need rear fogs in N. America. It seems that at least once a week you hear about bad accidents in fog.
Last weekend, the entire NJ Turnpike was closed due to an accident in the fog.
The only problem would be that it would have to be automatic. I saw a pic in the newspaper about the Turnpike that day. I believe 1 out of 5 or 6 cars even had any lights on.
-Dennis
-Dave
-mike
-Brian
Bob
hypov: care to elaborate on how you heard that?
I bet Bob's wrong. We'll probably get some rebadged GM, if only to earn some CAFE credits. A Subaru hybrid would by a tiny niche within a tiny (1.1% market share) niche, i.e. not worth developing a whole new powertrain for.
-juice
Bob
I think it was the Chevy Aveo that was being made in Korea at the former Daewoo factory. They'll probably engineer that for Chevy, and then give Subaru a re-badged model.
Keep in mind hybrid sales are tiny. The Insight sold in its first year about what the Baja sells per month.
-juice
Bob
Would y'all be able to provide a little more detail(s) about the new 'Direct Control' shift on the upcoming 4EAT? How different it is from the gated shift 4EAT?
A:
New for the 2003 Legacy GT models is a 4-speed electronic transmission with sportshift. With Subaru, we generally offer a new feature in one model and then expand it through our model lines if warranted. I cannot state that this sportshift feature will make it to other models, but I also cannot state that it will not. Only time will tell.
Similar to transmission features found on more expensive European vehicles, sportshift gives the driver added driving excitement by enabling the driver to choose when to manually upshift or downshift through the gears. The driver can also leave sportshift in the fully automatic drive position thus letting the transmission shift on its own. Depending on driving style and driving conditions, an economy or sport mode of shift program will be operational.
Whether the vehicle is at a standstill or is moving, the sportshift operation can be engaged only when the shift lever selector is in the Drive position. Push the lever to the right. The transmission display in the instrument cluster will show the current selected gear. Aside of the instrument cluster shift position indicator are arrow-shaped lights that will illuminate to signal the driver whether an upshift or a downshift is possible. To upshift, the shift lever is pushed forward to the plus position. To downshift, the shift lever is pulled rearward to the minus position.
When shifted to a higher gear too early, the transmission will not upshift until a predetermined engine rpm has been reached. When shifted to the next lower gear, the transmission will downshift only when there is no possibility of over-revving the engine. If engine rpm are too high for the downshift to safely occur, as series of audible beeps will sound to warn the driver that the downshift cannot be made until engine rpm reach the acceptable range of the selected gear.
Sounds like "Direct Control" shift to me.
I said hint, cause it appears to be a standard answer to a question that a YES NO answer could not be revealed.
-Dave
They could then justify a hybrid powertrain for that.
-juice
-juice
-Dave
You ask about A and they tell you all about B.
-mike
So maybe there will be a few tweaks to the '04 Baja Sport, like offering more monochromatic colors, perhaps?
Bob
-juice
If Sportshift=Direct Control, then it begs the question, why a different name? Perhaps Direct Control has some improvements over the current Sportshift?
Ken
Aren't they red? I've seen red rear fogs on an LR Disco and they were about as bright as a brake light. That's the same way a guy in Poland described his on nasioc. That doesn't seem too bright.
It would need to have a "fog sensor" so people wouldn't always drive with them on. :-)
-Dennis
Not necessarily describing "direct control".
-Dennis
Ed
If the Direct Control Shift is indeed different, SoA's response would have been, circa, "We do not have details at this time... la ti da ti da..."
Why a different name? I don't have an intelligent answer, but I'm guessing they do not wish to mate the word "sport" with the 2.5l turbo that will be in the Forester XT. "Control" sound more stabilizing, and "direct" enforces it, being that the Forester is a mini-ute. The perception that the Forester XT being sporty (as in a racer) might deter certain market segment perhaps?
-Dave
-Frank P.
i too wondered about that statement, as i don´t see nearly as many Impreza Outbacks as i do Foresters and Legacy Outbacks around Northern New Mexico. Then again, we eat more tortillas at home than bread...so in our case his analogy works. :=) seriously though, shouldn´t Legacy be on the pic?
Actually, the big Outback should be on that pic. It's been their best seller for more than half a decade. Although so far this year the Forester is ahead for January. The OBS might be 4th or so, hardly bread and butter.
2005 is the magical year when the 7 passenger big SUW arrives. We know no details, except that it will NOT share a GM platform as originally planned. I expect an Outback Plus, with a 3rd row, taller stance, longer wheelbase, and a 240hp H6 standard. It might be my next car.
-juice
Horrible to drive behind for a few hrs. I am very glad that people here generally don't have the option to have them cause they'd have them on all the time, just like their forward fog lights.
-mike
Even the Subaru showcase the Speedvision used to show had a mistake. They called the VDC a VCD. :-)
Unless they run it by the Edmunds Subaru Crew, the information could be incorrect. ;-)
-Dennis
-juice
Ken
More pictures in a little while.
-Brian
-Brian
-juice
Bob
What I don't want to see is seating like the GX470 - basically bolted right on the floor, with zero room for your legs. You end up with your knees in your chest.
-juice
-mike
