Alternator mounting brackets breaking
I have had 3 alternator mounting brackets (orig., a new one, and then the new one after being welded after we were told it would be 4 to 6 weeks to get a new becaue "they NEVER break") break on my 2002 Odyssey in the last 7 months. Anyone else had this problem or know of any tech papers issued by Honda about this?
When they go, it is without warning, lots of belt whining, followed by the belt breaking, and then all the associated $$$ of replacing them all.
Signed,
Had enough in FL
Signed,
Had enough in FL
More $$ and more $$.
Then this morning the belt slipped off and I opened the hood and noticed that alternator was a bit off alignment and the belt was shredded. Cause? You guessed it, broken bracket. I'm beside myself and don't know what to do.
Any one else have this problem and did you find a long term solution?
Merry Christmas.
I can be reached at fabrimount@hotmail.com.
Jim
I logged in to the forum to find replacement part cost, but now that I see it is a regular problem, I may Superglue the old one and take it to a machine shop and have a new one made of heavy angle-iron steel. Actually, with just a little more equipment - a good hacksaw or power metal saw, a piece of 1/4 inch x 1 inch x 2 inches long regular angle iron, an electric drill with the right size bits and a tap for each hole, I could make one that I do not believe would break — ever!! I would attach an additional nut on the back side of the two alternator side holes. Superglue should work fine for that. Just be sure to only get the glue on the part of the nut that needs to be attached. Your friendly hardware store should be able to match the bolts you removed with the right size drills and taps.
One nice thing about this is that if your homemade part ever did break, you could fix it with your own tools and leftover angle iron from before in less than an hour.
I know -- I am rather careful with my shadetree mechanic ability, but I cross threaded this lower bolt during an alternator replacement. The heavy alternator and the full weight on this lower bolt makes it difficult to start by hand. I know now to support the alternator with one hand, while threading this bolt with my other fingers. Had to end up installing a Helicoil to properly repair -- because of very limited access -- not the easiest repair.
Saw comments by Jim on the form about making stronger replacement brackets but email gets rejected. Recently bought a 2002 Odessy with lower miles. But couple months after, have broken two alternator brackets. Anyone else have source to make solid replacement bracket, and did that resolve the issue? If so, let me know the cost and how fast I can get a replacement part.
Steve
