There's a decent bit of intake noise when you really go after it... but otherwise I'm happy. It was on the car when I bought it and I've cleaned & re-oiled once.
I think they're worth it to avoid buying paper filters. I do think AMSOil or other foam air filters trap more funk than K&N filters do though.
-c
Do they make AVS-i tires in that size, Loosh? Maybe Tire Rack has some left over.
-juice
Cheers Pat.
Cheers Pat.
I get there and walk into the garage, what do I see? Oh the whole front of my car MISSING. He actually disassembled my whole front end to put it in. While he is at it he's cleaning my yellowed headlights, and removing the airbox silencer. I only wish I had the $ for the HID conversions since it's so nicely apart we could easily do that. The car is totally non-aerodynamic w/o the front end on!
-mike
15" alloys from Jim's Legacy Turbo
Donut swapped for true Full size spare on steel rim
ASC 750 one-touch programmable power moonroof, 17"x30"
Take-off 6CD changer plus cassette from a WRX
Rubber cargo liner
Leather shift knob
Cargo net
I think that's it. We might tint the windows next. That is one BIG green house, I think it needs it.
She's basically lookin' like a 2003 L/SE model. Had I known I might have waited, but maybe not. I'd have gotten a single CD instead of a 6CD, and vanity mirrors on both sides, but not much else. Oh, and the rims would have been 16s.
But I've invested $19k, and a 2003 L/SE with a 6CD would run at least $20k.
-juice
Cheers!
Paul
-juice
Cheers Pat.
John
John: interesting idea. Maybe I'll do that if we decide to do something temporary. I'd prefer a full tint, we'll see.
-juice
It is great when things work out even better than you expected them to.
Cheers Pat.
ATF Cooler
Cleaned Headlights
Painted rear wiper arm that had the paint off it
Replaced wipers
Reconnected the stock horn in parrallel to the air horns
HID conversion on the low beam Projectors.
Still waiting for the ATF Filter kit to come in, then I may need to upgrade the stereo to a single din so that in the 2nd Din we can put in guages.
-mike
You did HIDs? Did you get before/after pics? What did those cost, $500 or so?
-juice
Thanks for the offer on the single DIN cassette. I may take you up on it. I'd like to find a single DIN Cassette/CD but not sure they exist.
-mike
When they put CDs in the head units, they dropped the cassettes.
Aftermarket?
-juice
Sanyo EXCD-1000
Sanyo FXCD-1100
Pyle PLCDCS-90
-mike
-juice
-mike
Many players without such jacks still have equalizer or pre-amp input jacks on the back which you could attach to, but in many cases (like on my Sony) those inputs bypass the player's built-in volume, bass and treble controls so you would have to use the volume control on your DVD player.
The other way to get external signals into a stereo is to use an FM modulator so you actually pick up the signal on a radio channel. The quality usually isn't great and they require batteries or yet another power cable. They are good for people who are stuck with their OEM CD player, but if you are buying a new stereo anyway then just get one with an input jack.
-mike
I've got some small nicks in my tint in the cargo area from some snowboard edges. Usually, a little grease pencil will touch it up to the point where it's not super-noticeable.
Ken
Ken: it almost looks like the windex & razor blade treatment might be sufficient to persuade the tint off the glass. (note to self: careful on the back window with the defrost wires!)
Cheers!
Paul
http://www.tintdude.com/remove.html
bit
I went to the dealer recently and sat in an Outback. To my amazment, there was slightly less room for the driver than my 1990 Legacy Wagon. I have done a number of camparisons on legroom to other makes and models, and have found that that the measurements say the Outback has more legroom than the Volvo XC, Audi Allroad, Ford Explorer, the list goes on for about 20 vehicles. I found that with the seat all the way back and down, I felt a little cramped to the poing I would not drive this vehicle.
My question is are there any aftermarket modifications that can be made to the seat rails to permit more legroom and possibly more headroom?
There must be many 6'2" drivers out there who want a vehicle with the brawn of a small SUV but the "parkability" of a car...
I would be greatful to hear of your findings.
Ciao.
-juice
somehow Loosh comes to mind.
-Dave
FWIW, the track on our Legacy looks pretty straight forward. On the Forester, the front of it slants down, but the Legacy's looks straight and more basic.
-juice
Eric
OK, Eric, power seats only. Got it.
-juice
Ken
Maybe it's an anomaly, let the dealer check it out. Let us know if the dealer resists, we'll put you in touch with SoA service.
-juice
http://www.imagestation.com/album/?id=4292183933
It is much more rare than 96-99 DOHC engines though.
-Colin
http://forums.i-club.com/forums/showthread.php?s=&threadid=262179
Stephen
I still prefer DOHC.
I could have told you the Forester had the same center console, no wonder it fits.
-juice
Ed
The engine ran and made plenty of power to move the vehicle. I'm sure it would've overheated enough to cook the block & heads if not dealt with immediately though.
-Colin
In your case, Colin, did you have the heads off to do your mods? Did you use new gaskets? Just curious.
-juice
yes I did have the heads off to install the cams. the cam cover has six Torx Plus 45 bolts and on my 24k mile engine, the rear-most ones were frozen in place due to heat from the headers and the liquid gasket used to seal the cover.
once three bolts partially stripped, I made the decision to pull the heads to get better access. one of them was destroyed getting it out, I used a chisel at a 45 degree angle to the bolt head to get it rotating.
I figured while I had the heads off, might as well do some light porting. ;-)
-Colin
I wonder then if bad gas detonation is the cause for gasket failures in both the Phase I and IIs.
Did you tear down the engine before or after you took your RS in to the dealer?
Ken
Did you use new gaskets? You dodged the question so I'm thinking you didn't. ;-)
-juice
of course I used new head gaskets when I had the heads off! new intake manifold gaskets too, even though it's not the same with a floating manifold like the EJ series uses it was still a good idea IMO. I did reuse the exhaust manifold gaskets though... they seemed like new.
ken: before and after, actually. I tore it down at 24k miles to install the cobb street cams and ported the heads.
then around 37k miles, it was overheating a bit and I suspected water pump, head gasket or something along those lines but the dealer didn't find much of anything interesting. they topped off the coolant and installed a new crankshaft front oil seal. (had a slow oil leak for a while.)
39k, massive coolant leak from the blown head gasket. I decided to not risk paying full dealer rates in the event this wasn't a warranty-covered repair and did the head gasket again by myself.
42k, overheating again and purging into the coolant overflow tank until it was full. I start looking for a different car, and ditch the Impreza for $11,000 at the BMW dealer. with 42k miles, scratched up interior from 2 terriers riding along, and stonechips galore I thought I did alright...
wish I hadn't ported the heads. if I hadn't I would've made the dealer fix the overheating problem and I'd still be driving a Subaru. I also wouldn't have a car payment, which would be nice.
-Colin
I should stop fiddling, too. The snorkectomy was fun but you do end up with more intake noise. Fine with me, but I wonder if the next owner will mind.
I dunno, I just feel like I have to customize whatever I own to my liking. But I probably ought to leave the engines alone - not enough experience to fix whatever I screw up.
-juice
