if he's done lateral links before it shouldn't be a problem.
~c
Guess my sway bar and strut tower brace were under warranty from 1998 to 1999 after all! LOL
-juice
That's very interesting and, if true, a step in the right direction for SoA.
Ed
Also gave me a complete installed price for the STi swaybar when I asked.
-mike
...oops, I see Mike beat me to the punch on that one. :-)
Ed
Too bad you didn't have your FXT out in Santa Cruz. The local dealer there does in fact install STi parts as well as other aftermarket parts, even Kartboy.
Have you considered an independent mechanic to do the job? Around here, there are severeal independent shops that specialize in Subaru that would do such work. There's got to be a few in your area.
Ken
-juice
The dealer said it would cost about 300 usd to install without including labour. that to me is overpriced. My question is am I better off having it installed @ circuit city/local car audio store or having it done @ a dealer? I not very good putting stuff together so the diy kit is not an option.
Thanx for any comments
-mike
~c
Keyless entry alone was inv $114/msrp $175.
The dealer had to install the keyless entry on mine as they didn't have a Legacy with it pre-installed.
Jim
-mike
I have used Viper, Alpine and Code-Alarm. Based on that personal experience instead of secondhand hearsay, I believe that Viper is the best for both entry-level features and higher end stuff with many options with one tiny caveat... Alpine's dual-zone radar cannot be beat for open-top vehicles. It can be used in a standard car for a 'promixity' warn-away or full alarm, but that's annoying (illegal in NY I think!) and ineffective. it does work great for someone reaching into a Miata or Wrangler when you have it parked with the top down.
~Colin
The car is currently under the knife, and I'm having an SPT short throw shifter (for the Forester) and an STi tranny mount installed at the same time. :-)
volkov - Are you getting a USDM or JDM STi up-pipe? Or do you choose to remain silent? ;-)
-Dennis
Likely a new USDM. Not the cheapest at $275, but not ridiculous and fitment/stealth properties are the best.
I've been talking about it and Cobb Accesport for a while, but want to let her break in first, and make sure there are no underlying problems before I actually fiddle with her. Still hasn't seen her first oil change. Only hiccup so far is that it's sticky to take her out of 1st when she's cold. Please note I said coming out of 1st. If I give a tiny throttle blip after hitting the clutch, it goes smoothly. I have no idea why. Goes away after 3-4 shifts - which is half-way to work for me, LOL. Obviously a warm-up issue, but I wonder what it will be like at -30.
Nicholas
They fixing it under warranty?
-juice
~c
We all know pros will get them, however we've recovered at lease 3 FIRST HAND EXPERIENCE HERE where the viper alarm was defeated easily by the theives via the valet and via replacing the brain of the viper alarm with another one...
So I was simply commenting that I'm not convinced of the viper's quality in protecting ones car. Sorry to have offended you SIR!
-mike
Uh, yeah Colin would be correct. They found it not to be customer abuse. :-) They showed me some nasty pics from SoA of some non-warrantable issues.
Meanwhile, I'd love to swap some stuff from this loaner F-X I'm driving. Fully manual climate control with no annoying HAL, Single CD changer w/extra storage space. Ah, the simple things.
-Dennis
Subyimprza got the 2 aft links in today before he had to leave, so functionally the car is back to 100%. I'll give the forward links a go when I am recovered.
I'm also watching you and those control arms...;-)
Ed
Compare the number of wheel bearings and gaskets, those showed clear patterns.
-juice
Yeah, I was a little surprised at this mis-hap since I've been driving manual Subes for seven years. The tech said it's "possible" that the gear could've been slightly out of spec. I think the long throw shifter is out of spec. :-)
Ed, I have a very close eye on my suspension. I think I check it once a week.
juice - Ed is very familiar with the wheel bearing issues.
-Dennis
-mike
Good to know. we'll have an opportunity to discuss firsthand on the 11th.
You bet. No wheel bearing issues = no intro to Patti = no confidence in SoA ability to stand behind product. All those happened and my confidence level in SoA is fairly high.
That said, I am also very familiar with the head gasket issues. Lest this turn into a complete lovefest, I have to admit that the head gasket issues were a factor (albeit a minor one) in my decision to trade the '00 with <70K miles on the odo. Granted the coolant conditioner remedy looks to be the fix, the need to add that with every coolant flush just didn't give me a warm fuzzy. Here's hoping the new 2.5T block is less weepy.
Ed
now we'll see how long those endlinks last. ;-)
-Dennis
-Dave
-Dennis
Ken
-mike
Sorry the WIDE picture put your camber bolt sentance off-screen.
-mike
welp, that ain't gonna to break.
~c
It's a little stiffer, but the throws are wonderful! Feels a little closer to the Rex's shifts instead of those looooong Forester shifts. More of a snick-snick feeling. I'll probably get the Kartboy bushings too.
Oh yeah, the new 1st and 4th gears and synchros aren't bad either. :-) I didn't even complain about first gear. Thought is was just me causing the grind downshifting to first, but they duplicated it and found that synchro/gear worn as well.
-Dennis
Bob <dreaming again...>
At least it is an option now, unlike 17" wheels. :-(
~Colin
-D.
The stock shift lever has a rubber insulating layer that the STi shifter doesn't.
-juice
~c
I've had both, the STi shift vibrates more, something people in that price class may not find acceptable.
This topic is oft debated, some like short throws, others argue longer throws give you more leverage so they're actually easier to shift.
An extreme example - the S2000. That shifter is *stiff* and if you're off by 1mm you'll miss the shift.
Maybe you don't want to churn butter but a $30k near-luxury shopper doesn't necessarily want to stir a box full of thumb tacks with a skewer, either. :P
-juice
