Corolla 2007, the engine cut off when I shift from P to R or D or 2 or L. Can you help me please
MeleCarCare11MeleCarCare11 Member Posts: 1
edited January 2024 in Toyota
Corolla 2007 cuts off the engine when the shift lever is selected on R or D . I cleand all solenoida and changed the ATF but no change al all.
Answers
  • oldfarmer50oldfarmer50 Member Posts: 24,521
    I had a similar problem with a 2004 Chevy. It would start and shift into reverse only to stall when put into drive. The problem was a sensor on the transmission that told the TCM which gear the transmission was in. According to the shop, if these sensors get dirty communication is lost and the TCM can’t select a gear. Cheap fix of about $100.
    I assume a 2007 Toyota has an electronic controlled transmission.
  • thecardoc3thecardoc3 Member Posts: 5,858
    Does the engine stalling just kind of die like the engine isn't idling fast enough, or does it slam and stall like you slipped your foot off of the clutch in a manual transmission?
