But, still a couple of things left unanswered. I couldn't find anything about a blow-off valve. That's not the same as a wastegate, is it? Can changing the blow-off valve increase performance, and, if so, how?
1. Bleed (flush) the brakes and replace the Fluid with ATE Super Blue
2. Replace the dual stage booster with the single stage, rebleed brakes, of course.
3. Possibly go with stainless brakelines.
I've already got EBC Greenstuff Pads on the front of my car (with 70k miles) so I'm not 'exactly" stock.
Report to follow.
Ryan
-still waiting for my WRX Wagon.
Yes, I'm refering to the "STi Shifter". I read somewhere on i-club that the two shifters are from the same source. I think even Larry Ganz confirmed that.
Check out Cobb Tuning's page at: http://www.cobbtuning.com/forester/drivetrain-shift.html
They're exactly the same. The Cobb site has some info on the bushings too.
Ken
Cash is at a premium nowadays, but I still have the itch to tinker with the car a bit. A set of 16" rims would be a potentially worthy investment in the $300-$400 range, but then going to 215/65/15 still gives me slightly better profile (stock is 205/70/15) with a VASTLY better tire selection. 215/60/15 would fit, but with a difference in aspect that begins to get a bit slapdash on the speedo.
Then there's exhaust. boy, am I itching to try that. But there I am looking at $450-$600 for a stainless steel set up with mandrel bends etc., the kind that won't fall off the car in 3 years .
Longing for the day when quickening and Quicken finally get along.......
Ryan: I bet you're going to end up with some pretty sweet boat anchors! They do say it's the dual stage booster that causes the mushy pedal feel.
Definitely tires first, Loosh. Those impact everything - acceleration, braking, and cornering.
-juice
Other than terrible tire selection (but there is some) then why not 225/60-15?
-Colin
Yeah, I find the stock shifter height to be a bit too tall for my tastes. I guess it would be a good height with the arm rest.
Do you know the Forester uses the same stock shift lever as the Impreza?
Ken
Ken: yes, the lever itself is the same.
However, we at least think the rest of the shift linkage differs some. I crawled under there with Jim Moran, who had done his brother Mike's Kartboy, and not only did the SPT linkage look like it would not fit, but also he felt it looked different than he remembered on his brother's car.
Perhaps the Forester's is slightly longer, due to the stretched wheelbase. I'm not sure.
-juice
got my WRX (wagon) on Friday. The brakes feel much stronger than on my RS. The suspension is also a good deal softer (on the WRX). Time to evaluate the STi strut option I guess.
The RS brakes got their fluid replaced thursday night(valvoline syn) and still feel soft. The brakes on my WReX don't feel that much softer than the 4-pots on our 2000MY GT Turbo.
The Sedona Red Sportwagon is a sleeper though. I drove it around all weekend with hardly a second look. Parked at the Dairy Queen in front of about 25 people, nuthin. Can't say the same for my RS.
Ryan
What kind of suspension are you running on your RS? Version 5 struts and springs, right? (Imprezer's old set?)
-Colin
-juice
I have a two day divisional autocross coming up this weekend, let you know how that goes.
-Colin
-mike
Don't worry, at some point this season I will autocross on my street tires in a regional event and see what they can do after running my good v700s.
I posted it before but it's worthy of repeating-- two passengers at the autocross couldn't believe I had stock brakes down to the OE pads.
-Colin
-juice
anyways keep me posted on the differences. I know the r compounds would be better. How much and is it worth it for an occasional autoXer...that would be my question.
Ateixeira - The WRX is far superior to the old RS, it feels so much more solid, and doesn't push and roll over on itself nearly as much as the old stock RS seemed to do. I was most impressed by the new 2002 2.5RS. The benefits of the new chassis really improved it upn the old model.
Ryan
It is ... what 100lb? heavier than the previous RS but I think it's a good value.
-Colin
Just a word to the wise.
-mike
-Colin
Ross
-mike
Dennis
And the Forester also has that beam from B-pillar to B-pillar. Maybe the new one is different?
I also had an ASC moonroof on my old Sprint, and friends had them on a Raider and Spectrum. None ever leaked or had any problem whatsoever.
-juice
It seems criminal to me to consider installing an aftermarket sunroof in a car specifically engineered to have an extremely rigid chassis like the new Impreza.
-Colin
-mike
-wdb
-mike
The WReX has enough power that I can use the A/C and still have fun driving it. I hate driving my RS with the A/C on. I feel the drag immediately, same with having a passenger. It's (the A/C) coming out this summer.
I still think the old Impreza is pretty solid goods overall though. Going from my WReX to my RS, the RS still is plenty of fun.
RP
Seriously, I don't think fun driving and a moonroof are incompatible. If it needed to be designed-in from the get-go, then it should have been, plain and simple. This is a fun car that appeals to the type of people that want an opening above their heads.
OK, Subaru, make a drop-top WRX and nobody will care. I'd even buy one.
-juice
Dealer problem #2 I had bought a spoiler with the origional intention of putting it on my self, however when I got it out of the box the installations were not very explicit to say the least, so I made an appointment for the dealer to install it, after half an hour the advisor comes and says we cannot install this spoiler sir it is not a subaru part, the spoiler is in a subaru of canada box and it was bought at the dealer where I bought the car, so the advisor suggests I take it to the bodyshop as they are more experienced in installing spoilers, well they looked at and said no way this is a hack job to install this spoiler it is not subaru it is not even the right part #well just to prove them wrong I went into the parts guy and asked for the part # of a rear spoiler low and behold the part # on my box was the same #.I left before I completely lost it and punched somebody out, so I stewed all last night and this morning I took an insane pill and attacked the top of my tailgate with a drill after removing all the trim panels around the inside of the tailgate it was obvious how the spoiler was intended to be installed, two of the mounting bolts came through access holes that are already in the tailgate, one hole on each side has to be drilled through the double skins and a reinforcing, the worst part was drilling the first hole (after that it was home James and don,t spare the horses).
So to Recap so far I have swapped out the stereo and speakers, had an alarm with auto start installed,installed a hood deflector,spoiler,cleaned and painted the calipers,had the rotors cross drilled and plated, put on 16x7 primax model 684 rims with goodyear RSA 205x55x16 tires, rear mudflapsfor legacy, front mudflaps from outback modified to suit GT, subaru do not offer fronts for the GT because of the body kit on the rockers, all mudflaps I primed with flex primer and painted body colour.Oh and also installed the tweeters and subwoofer
Thats not a bad list for 4 weeks of ownership, this was a long post sorry about that.
Cheers Pat.
Ross
-Brian
So Legacy's (L, I presume?) rear mudflaps don't interfere with the GT aero ground effects?
How much material did you remove from the Outback front mudflaps?
What is flex primer?
Painting the mudflaps to match the body is a nice touch. If you get a camera, please mail the photos to me or juice or put them up on PhotoPoint.
..Mike
..Mike
looks like camera will have to wait I have spent all my spare cash on the mistress but there is an outfit here who will process regular 35 film and upload it to the net so I will try that.
Cheers Pat.
I have fitted a few spoilers, this is not my first, though it is a first on a car that cost me so much to buy, the hangup was the intructions were pitiful they did not for intance mention that you had to remove all the inside trim pieces from around the tailgate I had to figure that out for myself, I had thought on first look that I would have to drill all six holes through double skins but it turned out that was not the case, anyway the first hole is always the worst, once you drill one there is no going back.
Ross, yes I guess I will have to get off my [non-permissible content removed] and make a statement with this machine,Ha! Ha! this is a recurring theme with me, right from my very first car I had make it mine and different from all the others of the same make and vintage, my poor wife has put up with a lot over the years even though she is not as interested as I in things mechanical and she will usually be very understanding when I screw up which is wont to happen from time to time like one instance I had hankered after a set of BBS Rims for months when I finally got them they did absolutely nothing for the car I owned then I ended selling them at quite a loss, she gave me no grief and there have been other instances over the years, well thats enough of memory lane for now.
Cheers Pat.
-Colin
..Mike
..Mike
For all others who like myself bemoan the lack of an ignition key light i am trying to figure out a way of rigging one up. I got minature bulb and socket from the ashtray of an old honda I took the collar off that goes around the ignition switch in the subaru, I drilled a hole at an angle into the collar and epoxied the socket into it, now I am trying to get a friend in electronics to build me a little time delay relay which I will wire through the pin switch on the door which operates the dome light, when I get it up and running I will post the results here.
Cheers Pat.
Sounds like quite a list. How do the brake discs look now?
-juice
I'm mulling over putting 17" wheels on my GT sedan; did you consider 17's, and if so why did you decide not to use them? Tirerack (www.tirerack.com) lists 17" wheels from 6.5" through 7.5" in width that supposedly fit the Legacy. I most like the look of one of the 7.5" wide models but I'm hesitant to put a wheel on my car that is a full inch wider than stock.
Also, Tirerack recommends 205-50/17 tires, and yet the NZ Legacy RSK has 215-45/17 tires. The overall diameter of the 215's is closer to the stock 205-55/16" tire, but, geez, a 45-series tire looks like a rubber band wrapped around the rim - not much protection for the wheel. If I do it I will probably go with 205-50's and put up with a slight error in the speedo.
Cheers,
-wdb
Great write up. How do the new brakes perform?
I can relate to the oil plug experience. Some moron mechanic way over tightened the plug on mine and it took several minutues of intense swearing to break it loose.
Ken
#7 is a silver WRX wagon somebody has already stolen the WRX badges from it,#8 side view shows the spoiler. #12 is the JVC xc770 cassette and CD combo.#16 hood deflector.#17 and18 shows how I teed off an adapter in order to have the idiot oil light as well as the gauge. you can also see I had the alternator belt guard chromed first step in dressing up the engine.
#19 is a close up of the front mudflap for the benifit of Mike Smith. The rest of the photos mostly show the brakes.
To access the photos go to WWW.futureshop.ca/photo the album ID.514549 and the password is 3822.
Cheers Pat.
IMO you will never come close to the limits of the tires and rims on the car now the lower profile you go the more you degrade the ride 17 and 18 inch rims are more about looks than function, I got 16x7 with a 40mm offset and that is the widest you could go without the risk of rubbing and if you did go to seven and a half you may find you have to roll the rear fender lip Colin care to comment?
The 45 series tire is the proper size with a 17 inch rim but with a sidewall that low you may as well be on solid tires I had 50 series tires on my 89 Accord and there was a lot of difference in the ride quality.
Another drawback to the 17 inch is of course cost you are getting into speciality tire and rim sizes with a corresponding jump in cost.
Ken you only notice a lot of difference in braking if you on the brakes a lot like in the mountains other than that it is unabashedly an appearance thing.
Juice they look fabulous.
Cheers Pat.
I see that you don't have the compass/auto-dim mirror. Next upgrade?
Besides the price, how are the Eagles? Our OB is the first car I've owned that has something other than Goodyears on it. (I'll probably switch to Michelins when the Wilderness' wear out)
-Brian
I zoomed the photos and noticed a pinstripe and the letters "GT". Is that your handiwork too?
..Mike
..Mike
