Factory oil filters vs. After Market oil filters
I am debating if I should use factory oil filter
or after market. I had no problems using
aftermarket in my old used car but I just bought a
new car.
Does the factory oil filter provide better
filtration than aftermarket?
new car.
When an oil filter is brand new it filters the poorest. Strange, not really the filter is designed to remove certain size particles, as the particles fill up the openings in the filter they plug up the opening. Some openings are not completely plugged so these openings will filter finer particles. As a filter is used more and more openings are filled up until the filter will not allow adequate oil through to lubricate the engine. As the oil is backed up the pressure can go up and in a worst case scenario either the filter breaks and allows its junk back into the engine or the oil stops flowing. In either case thats why you need to change filters.
occasion has terrible valve noise at startup after
sitting overnight. All the valves click/clash very
loudly for at least 5 seconds then suddenly stop.
It has only happened once and is not a single
valve
click, or a rod knock noise. A friend with an
Infiniti G20 had the same. My guess is Nissan is
having a quality problem with the anti-drainback
valves in the oil filters, so I took off the
factory filter and changed to a premium
aftermarket
brand. The dealer service manager said "yes they
do that sometime and said the factory was aware,
but did not say what he thought the cause or cure
was. Anyone else had this problem??
By the way, I have the 1999 I30 with 5200 miles.
I would suggest a Mobil or Purolator Pure one filter ( Pure one has a silicon, not nitrile rubber) antidrainback valve). Try one of those and see. I have an I30 also. maxima engine
One hypothesis is that if the car is left for a period of time, oil drains from the galleries in the head, and the noise of the hydraulic lifters before they receive oil for a few seconds creates the racket.
If you're concerned, or want to read more, look at the SE-R Mailing List Archives here:
http://www.se-r-list.org/archives/
the search engine for the archives is very powerful, search for "start-up clatter" and other similar phrases.
As well, check out:
http://www.se-r.net for more general info about the cars. This is THE best site for the car on the net.
I don't have the problem on my NX2000.
Infiniti was good about trying to solve the problem on the '96, but to no avail. They changed the timing chain, plus a host of other things. Never fixed it.
You did hit the nail on the head, however, with the anti-drainback issue, IMHO. I, too, changed to a Purolater Pure-One filter on the '99, and the problem has not occured since. I tried this as the Pure-One claims to have a superior anti-drainback valve...and so far, I believe it.
each. Are they that much different? Can a person
go longer between filter changes when using a synthetic oils?
I am thinking of using synthetic oil in my truck.
Just use the search button on the left side of your screen and search for OIL. You will discover oil and become a rich oil tycoon...{%^D
Your host, Bruce
http://minimopar.simplenet.com/oilfilterstudy.html
-Chris
Someone out there knows- who
I really appreciate the website you posted. Thanks!!
Jim
Another stupid question: where is the oil filter located? It's crowded under the hood and I see one cylinder on the front side of the engine block. Is that it?
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Thanks for the info on Pure-One edwardh1.
http://www.pureoil.com/catalog/catalog.asp
I do not sell them
The infiniti engine in the I 30 is a 3.0 liter. Filter is horizontal (neither up or down). I had trouble with valve clatter at start up with Nissan filters and switched to Pure Pure One. No more clatter. Maybe my dealer bought up a lot of Nissan filters and set them in a 105 degree warehouse and the anti drain back valves quit?? Whatever Or may be a Nissan design defect??
I think the G20 engine is same as Sentra
Vern
I truely feel that buying expensive oil filters and synthetic oil is just increasing your operating costs. UNLESS your car manufacturer calls for synthetic oil, Just change your oil/oil filter every 3000 miles or 3 months, and let your engine warm up before driving off. I sold my high mile cars becauseI got tired of them, and not because they ever gave me any troubles.
Much less hassle with synthetics, especially with 5 cars
A GREAT way to increase life of an engine is probably the simplest and cheapest thing you can imagine!
Okay, go to your fridge. Grab one of those magnets that's flexible and is magnetic over the entire back, and go stick it on your oil filter!!! Put some tape on it to make sure it stays there, and VOILA! Most of the particles that collect in these things are metal from your engine, so having a magnet somewhere in there will suck em to the side! try it!
Will using mobile one and mobile one filters at the first oil change and every 5k there after in city driving work? Is that the best bet to make sure that the little Honda VTEC has a long life? I tend to rev it a lot...you have to get anywhere with only 1.7 liters...
Will Mobil One and Mobil ONE filters work in the Civic, and will the warranty be valid, does anyone know?
