Best Regards,
Shipo
Best Regards,
Shipo
From what I have read it would be normal to see low pressure only at higher temps, when oil is less viscous and thus leaks out faster. But, to clarify I think the pressure on this car is lower than it is supposed to be all the time, when the oil is hot. However, it is only infrequently going to 0.
I'm not sure about pressure releif valve. The diagram we have shows one, but then it says "not applicable from 8/95". :confuse:
Perhps a good sign is that the fitting at the temporary guage on the windshield started leaking a bit and the back of the mirror is now pretty well lubricated.
Best Regards,
Shipo
So now the plan is to have some probably 20W-50 put in there, since the pint of glop helped as much as it did, I am hopeful that the 50 weight oil might be enough to keep the light and alarm off for the summer. I hope the 20W is not going too far, too soon, since we still have lows in the 20s and occassionally even lower in April...I just looked it up and all time record low is 7 F for April here, record high is 91 F, though.
More information: after changing the oil, I checked and re-checked the oil level. While doing that, I cracked and broke a part of the dipstick tube, which is plastic. We got that replaced the next day at the VW dealership. While at VW dealership, we also asked them to check on why "check engine" light was always lit. They did check on that and fixed it so it was no longer on all the time.
Then, next day after leaving, engine became very sluggish all at once. Because of this sudden onset, I'm thinking it wasn't just a coincidence of long-time neglect.
Your thoughts?
I emphasize that engine was very sluggish, but not knocking.
Spun bearing? In any case, it's at the garage and will have a diagnosis soon.
He-he, playing Devil's Advocate here; every BMW sold in the States for at least the last ten years has taken seven or more quarts of oil, including their 2.5 liter models.
That said, 4.5 quarts sounds about right for the Toyota engine.
Best Regards,
Shipo
My wife's VW takes 6 quarts in a 2.5 (5 cyl) and that is 5W-40. Used to have a Sentra that took only 3.5 or 3.75, IIRC...but that was only a 1.6L.
Changed out the first run of Redline on a Saturday morning with a cold motor. Got one-half quart more dirty oil out.
No delay in oil pressure time on start up. Was the quiet start up due to Redline on the metal. Two posts two vehicles.
He eventually came to the conclusion that the problem was probably actually the oil pump and he decided to attempt to replace this himself. He was successful in doing this and it seems that now the pressure is well above spec, with conventional 10W-40 oil in there. He is happy as he seems to have solved the problem for about $100 and 7-8 hours of his time (which is not worth much, as he earns less than $7 per hour and I think he'd rather be under his car than working over a fast food grill
Best Regards,
Shipo
Second guess is that the filter is being "double-gasketed", that is, there's an old gasket stuck to the motor that's hard to spot.
