Honda Accord problems
1) I know you've posted this multiple times, but you emphatically believe in using Honda parts only, correct? I would assume this includes oil filters, but not necessarily fluids (oil, anti-freeze). Again, apologies if you've answered this before.
2) Have you heard of any transmission issues with the Acura TLs, which are V6s?
3) Since the cars are fairly interchangeable, any issue with Honda mechanics working on TLs?
Meanwhile, I'll tell you that I bought a 99 TL a year ago. Since that time I've followed ALL of the TL topics in Town Hall. I have not seen any problems whatsoever reported with the TL transmission.
What say you, auburn?
Pat
#25 of 418: Hello richrf....... (tomhan) Wed 26 Jan '00 (11:32 AM)
Glad to see your here.
As you can see, there are even more quality issues
that hadn't shown up on the other forum. I hope
the perfect car owners on that site read my message
and don't come over here to bash us every time we
mention a problem.
For referance again, here are some of my quality
issues. I'm hoping that someone out here will keep
us informed if they are finding resolution to any
of these.
Transmission problems - I had the reverse clunk
problem and as had been verified Honda's first
response was... "what problem" . They did however
admit to the problem soon after and didn't waste
any time in getting a replacement. Problem is that
I now have a brand new trans that whines at low
speed and doesn't shift as smoothly as the first
one did. It appears that this level of mechanical
work is beyond my dealerships capability.
Fuel boil-over - I too have this one and it is a
major concern for me do to a health issue. I must
have a dependable car. No solution to date although
you (richf) have indicated that it is at least
being looked at.
Wind/road/engine noise - The noise level is
outrageous on this car. For referance, the noise
masks my heater fan on full speed at roughly 40 mph
on a smooth raod in calm wind. This is excessive.
The dealer made a very slight improvement by
adjusting the rear passenger side door but the
overall noise is bad news. The engine sounds quite
loud also from within the cabin.
Fortunately, I have a 97 camry to compare to and
the camry is a sure hands down winner.
Cruise Control - Although not a major issue for me
I noticed this weekend that any time I excellerate
with the cruise accel switch the car speeds up at
full throttle. I don't know if this is normal for
the accord but my camry accelerates at a gradule
controlled rate that is based upon the grade. The
control also over-shoots a bit. If I speed up to
50mph mph for example and let go of the accel
switch the car continues to advance to around 53
mph. The camry locks on as soon as you let go.
Overall cheapness - I'm can objectively state that
honda's quality level has decreased from the last
model I owned (88 LXI). A number of my body panels
aren't even close to being lined up. Honda used to
be famous for their build quality. I don't have the
scrath problems that Richf talks about but the
paint job just has a cheap "Earl Shieb" appearance
to it.
Body rattles - I have a lot of rattles already at
1100 miles. My camry is three years old and not one
rattle yet.
Sound System - I probably don't view my radio has
poorly as Richf but it is sure nothing to write
home about. I sounds to me like Richf has a
defective unit while I view mine as cheap. It
definately needs to be upgraded and I agree with
Richf that it is not up to even the minimum
standards for a car in this price range. My
97'camry sound is far superior. Funny thing is that
I read on another site that the 97'camry sound
sucks compared to the 93'camry sound. Oh well....
I am very interested in hearing the results of
unhappyv6owner's lemon law pursuit. Please keep us
posted. I will make one more attempt at my
transmission and will then follow the same coarse.
I've already sent a letter to Honda as a sort of
"shot across the bow" pre-warning.
Didn't you find any posts about a resolution to this problem? I thought there had been at least one or two. I also thought the problem had to do with just certain areas of the country?
Oh well, auburn63 will show up and clarify, I'm sure. :-)
Pat
Ever since I first saw people complaining about the boil over thing I have been looking for a buletin and have not gotten one yet.I have even searched for it on the Honda net we have. The only thing I found was possibly something close. I found a service news on hard starts and they say the fix for this is a new TW sensor and computer. They say at certain temps that the TW(temp/water)sensor mis-reads the value and the computer makes the mixture to rich causing the car to flood.I have seen this way back in the 88/89 era but have yet to see it at our dealer for the newer cars.I will however keep looking, but in the mean time if your car will not start try holding the throttle wide open and cranking for as long as it takes( up to like 1 min of solid cranking)if still has not started give it a min for the starter to cool down and then retry.
Old Volve Dude
Yes I always say to use OEM parts but any good tech can install them.This includes everything except for like oil and maybe brake fluid. However trans fluid,power steering and coolant I would use the Honda/Acura stuff.
That I know of there has been no trans problems but I do not work on them we have a Acura dealer down the road from us so I dont see many.
As far as a tech working on it. Sure they are all basicly the same so a Honda tech would do just fine. There are a few that I have been working on due to some of the customers not liking the other dealer.Hope I have answered evry ones questions.......
Pat hello once again, I am still going to keep an eye out for that Boil over thing but I think it may be the same as the temp sensor thing.Time will tell......... nice hearing your comments once again...see ya
My dealer just informed me the necessary
replacement parts to fix the boilover problem have
been sent directly from Honda. The fuel pressure
regulator and computer are being replaced. I just
hope they know what they're doing. They said they
have to keep the car a whole day. Service manager
also said this is the first repair of this type he
has had done. Also mentioned there would likely be
a national recall of V6's to fix this widespread
problem.
Pat: You bought an Acura TL? Nice car. Had someone in another forum stating that they had leased a 97 for three years and was not happy with it at all (hard shifting trans, gas hog, many other small problems). Then they went out and bought a 2000 Chevy Impala. Just in love with it and tried to convince me that it was better than any Honda product. Go figure.
Prior to this car, I owned a 5 speed '89 Accord LXi - ten trouble-free, dependable years!
I personally have tremendous faith in Honda/Acura products based on my own experience and the other Hondas that my family and friends have owned.
As has been earlier noted, this is a place where people come to find help with problems - if 95% of the Honda/Acura cars on the road are problem-free, how many of those owners would think to stop by here and report that?
Pat
This type of information is very valuable for those of us trying to buy a dependable car. Why would anyone purchase a car with a "fuel boilover" problem that keeps the car from starting....especially when the factory still hasn't published a repair for it yet?
Isn't that important information for a consumer to know before shelling out $20K? For people to speak in general terms about quality and dependability and try very hard to influence other people to buy a car just because they did is not very useful to most shoppers.
tl565 why don't you find some other car to rag on and get on with it? They aint perfect, none of them.
If you feel comfortable spending $20,000+ for a brand new 2000 model car that does not start during the winter, and if you know that Honda has not published a repair fix for it then great. I'm sorry that pointing this out is somehow considered 'ragging'.
Folks...The problem only affected a few V-6 cars. It has been long resolved...O.K.? the affected cars have been/will be fixed under warranty!
Fuel Boilover? What's that? Why have I never heard of this except in these forums? Even the Honda Tech is puzzled!
For crying out loud...If you are scared, don't buy a Honda! What then, will you buy?
Is there such a thing as a perfect car that will never have a problem?
Well, I would like to point out in dollars and cents, what made me buy another Honda:
My wife's 97 Accord LX has been with us for 3.5 years and over 59,000 miles. My total outlay for maintenance has been $185. This includes oil changes every 3,750 miles and 1 valve adjustment all done by my local Honda dealer (the dealer gave me a $ off coupon book to be used toward the cost of oil changes, so that helped). I changed the air filter, spark plugs and rotated the tires myself.
By my calculation that figures to under $55 per year total maintenance cost. I know that I have tires to buy soon, and the 60,000 mile service, but all cars have to have tires and service occasionally. I will do it all the service work myself except for the valve adjustment.
In 3.5 years this car has NEVER been to the shop for repairs, only for service. How could I not buy another Honda???
I will give my 2000 Coupe more than 3 months to prove itself. If it proves to be virtually maintenance free I will continue to buy Honda. If not, I will then consider other brands.
I just hate to see someone come into this forum and trash the Accord without first having owned one.
BTW, I just passed the 7500 mi. mark on my 2000 Accord SE, bought 12/99. No problems to report.
tl565, you're right, my apology.
miles on it now I found a major tranny leak my car was made 5/00 so the problem is not solved who wants a rebuilt tranny in a 22k car my days with honda are over. I went to the nissan dealer on 5/17 and traded for a maxima lost 2k but worth not having a lemon for a car beware honda owners they dont build them like they once did. By the way my max now has 100 miles on it and is perfect.
- Anthony
When I bought my '89 Accord, they told me to do essentially that and I always did with that car and have continued the practice with my TL just out of habit.
Is that why I don't know what this vapor lock condition is? :-)
Pat
- Anthony
- Anthony
ODI ID: 721653
Make: HONDA
Model: ACCORD
Year: 2000
Date of Failure: Friday, December 10, 1999
Incident: No
Fire: No
Number of Injuries: 0
Component: FUEL:FUEL LINES FITTINGS AND PUMP
Summary: ON THREE SEPARATE OCCASSIONS MY CAR WOULD NOT START. I HAD TO MAKE SEVERAL ATTEMPTS AND EVENTUALLY IT WOULD START BUT WOULD NOT STAY RUNNING UNLESS I KEPT GIVI
ODI ID: 719977
Make: HONDA
Model: ACCORD
Year: 2000
Date of Failure: Saturday, December 04, 1999
Incident: No
Fire: No
Component: FUEL:FUEL SYSTEMS
Summary: HONDA ADMITS A PROBLEM WITH THE 2000 REDESIGN OF THEIR V6 ENGINES. THIS CAUSES A VAPOR LOCK TYPE PROBLEM, WHICH HAS CAUSED MY CAR TO BE DIFFICULT TO START ON 7
ODI ID: 718015
Make: HONDA
Model: ACCORD
Year: 2000
Date of Failure: Wednesday, December 01, 1999
Incident: No
Fire: No
Number of Injuries:
Component: ENGINE COOLING SYSTEM
Summary: IF TEMPERATURE WARMS UP DURING WINTER, FUEL WILL BOIL OVER AND FLOOD THE ENGINE PREVENTING THE ENGINE FROM STARTING UP.*AK
Have you tried talking to a detail shop about your problem? It would seem to me that even if you spent a couple of hundred out of your own pocket it would be better than the grief you are now suffering. Good luck.
Again no guarantees on the typing, old hands, old eyes, bad memory!!!!!!
diagnosed with transaxle failure by the local
honda dealer. My extended warranty will cover and
honda has agreed to cover the deductible, $250, if
i can provide the crucial 30K transmission service
paperwork. I don't have my owner's manual handy,
but i can't recall a 30K service on the tranny
being required for normal conditions. Can anyone
help with the actual interpretation of the
maintenance schedule? Does the 30K normal service
schedule require this? Why is a honda with 46K of
highway miles having transmission failure? So much
for reliability and Honda being one and the same.
Will probably look at nissan or toyota next time.
Any thoughts out there.
I also have my doubts. First of all, a transmission leak normally does not require the replacement of the transmission.
And, running to another brand isn't a smart solution either. Maximas, like hondas are great cars. They are also far from perfect. What will he/she do if the Maxima's transmission develops a leak? Run to yet another make looking for utopia?
So, what raised your suspecions?
isell - I'm not speaking for jin_satx, but for one thing check the date of justme6's post and the dates of purchase to which he refers - could have been just a mistake, but still....
Pat
ODI ID: 720976
Make: HONDA
Model: ACCORD
Year: 2000
Date of Failure: Friday, October 15, 1999
Incident: No
Fire: No
Component: Summary: 3 TRANSMISSION LEAKS AS OF 04/04/2000: AT THIRD LEAK - REPLACING TRANSMISSION...OIL LEAK: ENGINE REPLACED DUE TO INDENTATION B/W VALVE COVER & BLOCK. RECEIVED
tl565, exactly how many problems will deter you from buying an Accord and when will you move on?
Bolderbob,
They are probably trying to say that at 30k you should have changed your trans fluid and if you can show proof of that then that is all they need.
Pat,
I still have not seen any Honda in the 16/17 whatever years I have been with Honda. So what you are doing is a good practice if for no other reason than it is allowing the fuel system to presurize fully before starting up.I am still trying to get info on how a fuel injected car boils over or vapor locks. I have seen many for various reasons flood cold/semi warm but they are due to a miss read of temp. So I will keep you in touch......
