Visitor Agreement.
Correction Camry "does" have side impact beams. Sorry for the error.
Finally brought the car in for the SRS light.
Dealer gave me a Toyota Corolla as a loaner.
A loose wire caused the SRS light problem.
One comment on the Corolla. I had previously test driven this car and while not up to the Camry and Accord it was decent enough. Well I had to drive about 40 miles that day on backcountry roads and was stunned by how poorly the car performed and how poor the suspension was. The transmission was slipping. The Car had a little over 7,000 miles on it. The car was completely different from the one I test drove only a few months earlier.
At any rate I finally got around to turning the radio on and was greeted by blaring rap music playing at the highest volume level. I nearly jumped out of my skin.
I got the radio under control and the CD out of the CD player and put on a little more sedate music to find that the speakers in the front were shot and had low buzzing noises coming out of them.
I would guess the car has a difficult 7,000 miles.
At any rate if any one drove this particular car they would not buy a Corolla which would be a shame because this car was not even close to fairly representing a Corolla.
Lastly, I love the handling of the Accord and have averaged 27 miles per gallon in mixed driving.
Replaced camber kits, turned out squeeky because of neoprene bushings vs old rubber ones.
Anyone have any experience.
egr valve problem, causing a vacuum type leak.
Like sanandton said those are great years, I have a 92 and the only problem I ever had was the distributor. I am also a cert. Honda tech and have seen many of them not many problems at all.
Hondaman18,
At our shop in New Jersey we get like 21.95 for an oil change and that is with the factory parts. So how can you go wrong? If you still want to go to an outside shop then make sure to bring with you crush washers for the oil pan as they will not have any of them and if you reuse them it will cause premature oil pan thread wear. As far as the fill for the transmission it is on the top of the trans on a v6. It will be a 17mm nut right on the top.
Bolderbob9,
If I was you I would go to another dealer as they are all not the same. Sounds as if they could have caused a problem when they did the update. They may have even told you a lie about the check engine light and the cause to cover up something they did. It is hard to say but sounds as if you need a fresh opinion..Good luck
I'm sure it has to do with glass and surrounding rubber channel/gasketing. Anyone know of a lubricant that can be used without causing damage to rubber?
Thanks in advance,
2000 Honda EX-VL Sedan
I still have some questions for you knowledgeable folks out there.
First, after the tranny replacement, my key got stuck and I was unable to remove it a few times. I had to restart the engine and shift gear and wait a bit to remove the key. It's happening once in a while. Any thought? Maybe a loose connection?
Second, it's not related to tranny replacement. The engine developed a mild tapping sound after 3000 miles. I was to busy dealing with the tranny and I didn't bring this up to the dealership yet. It doesn't seem to affect engine performance. So I'm not too worried. This tapping sound is especially noticeable going up a hill with, say, 2000 RPM (when there's more pressure on the engine, I guess). One day, I opened the hood, and asked a friend of mine to give a little gas. There was a very noticeable tapping noise (high pitch). He suggested that it might be the exhaust pipe moving slightly. Some people said it's the piston and valve tapping sound. None of them however is a mechanic. None of cars I owned before had noise like this. Then again, it's my first Honda.
It's just annoyance. I'll mention this at next oil change. I hope it's not a sign of a more serious problem. Any thoughts about this? I'd appreciate any info.
--terminalis
I have been advised that the Oil Drain Plug does have to be watched and should be replaced frequently to avoid leaks. I always thought or I should say really never was concerned about the oil drail plug in a car (You just screwed the son-of-gun in pretty tight and your oil was locked in the crankcase until the next oil change). Now I have visions of the drain plug falling out or leaking on an extended drive and causing destruction to my brand new engine. To me this is a very strange thing to worry about on a new car. Otherwise I have nothing but praise for my accord. Can anyone give me any support, confirmation or similiar experience. Thanks so much.
Honda checked it out for me all I needed was a new tire and rim and alignment. Got it back this evening car still like new. Not a single rattle. By this point with my 5 previous fords and 3 GM's I had sooo many rattles that I had given up trying to get them located and fixed. I suspected they were one of those extra factory installed options that mislead me into the purchase in the first place. All I can say about the Honda so far is "Man, what a well built car"!
Believe me, you don't want to strip out the threads on the oil pan. I did it on a motorcycle and it cost mucho bucks to replace the pan. I did not know to replace the crush washer back then.
- Anthony
If I keep driving without getting anything adjusted in the engine, will it cause any damage?
Could I simply ignore this problem?
Thanks for your input.
Snowman: I am still having that little stumble too. I am just going to ignore it until my car is ready for its first service.
But if it is important then I will do it 22.5K service.
Keep in touch for this issue
Regards
Regards
1. Should I be able to feel the AC compressor cycle on and off at interstate speeds, and hear the freon circulate thru the system? ( a slight hissing sound when compressor kicks in which slowly disappears as compressor runs thru THAT cycle)((same thing on all cycles)).
2. I too am a bit disappointed with the amount of wind noise at interstate speeds. Not so much windshield on mine as drivers door. (haven't had opportunity to check passenger side yet). IYO could this be caused by the air flow between the window and the outside mirrors? If not, what would you suggest? BTW I can live with it if necessary, kinda hate to, but don't want to turn a small thing into a bigger one replacing this and that etc.
Thanking you in advance.
PS: I'm so glad my buddy Al Gore invented this internet, where I can ask a Honda tech questions from the comfort of my living room.
Also, after some heavy driving and with the A/C on and then turning off the car in my garage, the car makes a bunch of noises, like moving liquids (coolant) and it will stop. When the car is outside I never notice it. And just today, it was really humid and I heard a periodic humming sound coming from the car (or was it the garage door opener?) but I just couldn't pinpoint it. It was like a someone humming "wang" like a bumblee wing.
Anyhow, these things don't bug me at all. I have a friend with a 95 Maxima that makes crackling noises from all over the car like crazy....now that's annoying.
Also, I think I'm gonna have to live with the eggy smell from the exhaust...but it only happens sometimes. The fuel mixture up here is kinda rich...the bikes constantly spew flames from their tailpipes in Toronto....or is it a problem?
BTW do they still use freon? I thought that was banned, at least in Canada.
Dont know if it is an issue yet, I am going to check for info on it on tuesday.Other than that I would suggest having them set the idle using the PGMFI checker.But I will try and see on tuesday if there is any other info available.
Fritz1224,
No real opinion here, preludes have used the twin cam design for a while in some of their cars.They seem to be reliable but as for how much better they are would probably be based on opinions. I think they are a bit better for high performance cars but not sure how necesary for street cars.
BJKlinton,
Thanks, As far as the compressor kicking in, I would say that it would be normal to feel it due to the fact that it is an extra load.Should not be a bad drag or feeling but a little is ok.The hissing noise, I have heard on occasion in my own Honda and have never paid much attention to it.I have not read anything on it saying that it is bad.If you want to be sure just have you dealer do a performance check on the AC to be sure.As for the wind noise yeah there is some noise created by the mirror to see if that is where most of your noise is coming from just fold it in and see if the noise changes.Hondas due have some wind noises from the door seal area that is normal. If there is a abnormal wind noise then there will most likely be a water leak to go with it.
Titopuente,
sounds as if most of your noises are normal and that humming noise may be your cooling fan. It can come on up to 15 minutes after shut down and stay on until underhood temp cools down.The rotten egg smell is usally a fuel related thing so possibly try another brand and or octane and see if it gets better. If not try your dealer to see if there is anything that can be done in your area with it.
Pat
Thanks always for your help. As you suggested, the service guys at my dealership adjusted the shift cable. Now, the key getting stuck is not happening anymore. Thanks!!!! Also, I had the manager take a look at that tapping noise. He said that it's the fuel injector making that noise, and all hondas have this mild tickling noise. He said that people think it's the valve, but it's not. It's normal. He seemed sincere, and I'm pretty convinced that he's right. Anyway, it's pretty mild unless I'm going up a hill with a lot of people in the car.
Some more questions about the famous VTEC for auburn and other enthusiasts! Now that my accord is running fine, I want to have some fun driving aggressively. I'm pretty sure this VTEC stuffs have been already discussed somewhere, but I'd appreciate any info. I tried to sense the famous VTEC kick in, but I'm not sure when I hit the VTEC zone. I noticed that around 4500-5000 RPM, the engine sound changes from smooth to harsh one. Is this the VTEC kick in? I didn't notice any sudden change in accerelation that accompanies the harsh change in engine sound. I didn't feel any sudden power increase even though the RPM reached up to about 6000RPM. How do you guys use the VTEC?
--terminalis
As always your are welcome for any help, glad to be of help when I can. Now since I gave a general explanation of a VTEC in another thread and got spanked on technicalities, so I will refer you to this web page http://www.fortunecity.com/silverstone/lancia/58/technical_school/engine/vvt_2.htm
it is also a bit in general but you will get the point. If after reading and going out and trying to keep the rpms up you still dont notice I will try and give you more info.Glad most of your problems are going away...
Any insights are appreciated.
Prodigy,
Thanks, glad it helped you. I need to check specs but I think Adg45 is close with the 3500 rpm..
- Anthony
Thanks for your reply about the ABS light on my 94 Accord EX. As you suggested, I did find the fluid below the minimum line on the modulator assy. Additionally, I also found some moisture areas (not really wet) areas on and around the assy as well.
Now for the maintenance. Would you guide me through the proper steps for bleeding he system? I did notice what appears to be a bleeder valve on top. Also, How do you add fluid to the pump assy?
Again, thank you for your time and expertise...
