Honda Accord problems
No info on 6 cylynders doing it as of yet. If you guys have 6's and they do it bring them in and show them and then let me know...good luck
I noticed that the brake fluid color in the master cylinder is much darker than new fluid. Guess it's about time to change the fluid. Remembering the old days, this was a two person job. One person in the car pumping the brake pedal while the other bled the caliper. Can you recommend a easier way, or the correct way to change the fluid in the brake system?
I appreciate your time and knowledge helping Honda owners like myself.
than the store brand ATF Dexron III? Honda owner's
manual recommends using Honda ATF, but says you
can use store brand ATF Dexdron III temporilly and
to drain out the system and refill it with Honda
ATF when you get home. I find this stupid and
conflicting. Why would it be OK to use it
temporilly if it is not compatible to begin with.
Is Honda try to make more money from a 2000 Honda
Accord V6 owner @ $5 a quart?
We have been told that any top grade oil of the correct viscosity will work.But as far as the filter, the only proven one to hold presure and have available oil on restart is the Honda one. Also it is important to note that you must replace the crush washer, that is under the oil drain plug, at every oil change. If not then you risk damaging the pan threads.
Dont know if they have their own fluid factories or not, my thoughts are ,no. But they have additives that they have tested and designed for their stuff and they have the makers install them in the fluids.
I did not specifically question the lubrication engineers on power-steering fluid, but there seems to be agreement that only the Honda-brand power-steering fluid should be used in these cars.
Motor oil is a different story; many brands are acceptable.
Honda also specifies the use of only the Honda-brand anti-freeze. Perhaps this is necessary but I, for one, need to see more information to be convinced of this need.
The Accord has extremeley large rearview mirrors that aren't exactly aerodynamic...you can see for yourself, it is really flat (perpendicular to direction of travel) and has a large surface area, these are symptoms of air resistance which also causes noises.
But how many other cars offer you such visibility as the Accord? And the reason why we hear the wind noise so much is because the engine/suspension noise is barely audible, and because I like to blast my Salsa music.
I would also suggest changing your Honda ATF at no greater than 30K intervals. Got a check engine light at 70K with a 97 accord-was a check tranny code-changed the ATF-it was dark and a with a bit of a burnt smell, cleared the code and after another 30K-no problems. I drive all highway and assumed changing the ATF at 90K per the owners manual was ok. It is easier to change the ATF in a new honda than the oil-just drive it enough to get the ATF hot and be careful when removing the drain plug-ATF can get to over 300F.
Are you contributing the wind noise to the large mirrors but say its ok because of your music level?
Your friends modified Accord has what sort of mirrors? any pics? did he lose power? I would sacrifice power mirrors if the noise was cut in half and the mirrors did not look like a Kit car.
I think that the wind noise is substantial. Honda should have been more sensitive to this during the design.
Anyone else solve this problem?
Norton
I hear wind noise coming from the drivers side window, I don't think it's related to the mirror though. It seems to only be coming from my side.
Does anyone else have "acid rain" spots on their cars?? The "acid rain" is eating into my clearcoat and causing water spots and litte holes in the clearcoat. Honda says this is normal. My car is only 3 months old and has been taken VERY good care of. Do any of you notice this problem? Or is it just me?
- Anthony
The acid rain wouldn't happen on your door, only on the top of the car where the water can sit. I think Honda is throwing me a load of crap, but that's a different story. What color is your car?
sanandton:
What color car do you have?
- Anthony
Have you noticed that before? My rear 1/4 panel underneath the clear coat has smear (like finger print) and dust. Hardly noticed that under bright sunlight, but when the light is not so bright, especially when I am waxing the car... After some hassle with the dealer, they agreed (america honda has to see what'd happened in the factory) that it's damaged in the factory and repainted it (suppose to pick up the car today). Not sure whether you are in this case.
- Anthony
The engine will shudder and then it acts like it is starved for gas, then it smooths out and may not do it again for a couple of days.
- Anthony
Find a GOOD tire shop that will tighten the lug nuts with a hand torque wrench to proper specs, even if it means putting off that rotation / balance till you can find someone to do it properly. It will pay off in the long run IMHO.
That's my plan for my 2000 SE.
Honda Accord Problems – Part 2
Thanks. Your host, Bruce
