I don't use this stuff too much anymore. I'm afraid of it being compatible with picky fuel injectors (although I believe they claim it's a detergent) as well as possible adverse effects on sensors and/or emissions equipment but I used to use it in my 1986 Escort GT and found that the car's engine sounded smoother (a slight, totally subjective improvement) and oil consumption, never a major issue while I owned this car, dropped to ZERO. Fuel economy also seemed to improve ... maybe as much as 3-5% (from 28-29 mpg to 31).
As for high-speed driving, high RPMs really break down oil so you can add this to the long list of "severe" service conditions. This necssitates you using a better (synthetic) oil and/or changing the oil more frequently.
My current Civic has 112,000 miles on it and runs excellent. I didn't buy a Honda so I could get away with abusing it, I bought it so I drive it hard, take really good care of it and have it last a long time and maintian its value.
I probably take my car (a '95 Coupe DX) to 5,000 rpms at least once or twice each day. I've also gone on long, high-speed trips with the car. Early in September I drove to Thousand Islands and back in one dya ... 450 miles, most of that being 80mph highway cruising.
--- Bror Jace
Just enjoy your Civic. You'll really like it in the 4,000 - 6,000 RPM range!
might use a quart between changes.
i would only get zapped in the winter in my civic, so the dry air and the choice of clothing makes a big difference.
See post #998
--- Bror Jace
I am having a problem with the passenger side lock. In cold temperatures the door will not unlock using the power locks. Once the car warms up a bit it works. The driver side lock does not have this problem.
Any solutions? Or should I take it to a dealer?
Thanks...Greg
I may be wrong, but isn't the '02 Civics come with Dunlop tires these days? I was at the Honda showroom waiting for the engine oil service on the Civic and I saw this show car LX - nice with chromy inside door handles, similar body paint on the outside door handles, and DUNLOP tires ! Geez, Honda really tweaked a lot on the '02.
My 99 Z-71 4wd also has the same brand. They were not recalled on Chevys.No problem here either.
Frankly, I am not worried about it. I do kind of listen for any funny sounds coming out from under the vehicle such as thumps etc.
Nathan
There's a noise, somewhere under the engine on my 01 Honda Civic LX, when I drove on a bump or a dip. Is there anyone having this kind of noise?? Should I take it to a dealer for check up? or that's an acceptable noise???
That same Civic squeaked and rattled since new ... but only in the severe cold (below freezing).
--- Bror Jace
Sometimes on a mildly cold day, when I turn
the ignition the car won't start on the first
try, but does eventually. No big deal.
Then one day I was sitting in the car with the
radio on and the car was off and suddenly the
battery died and I had to jump it. I thought that
was strange for a relatively new car with low mileage.
A friend said the battery contacts might be a little
dry and I should spray grease on them (didn't try).
And still to this day I intermittently have problems
turning the key and getting the engine to start.
Are these situations related in some way? Might it be
a bad spark plug or is it the battery and its contacts?
The idling problem you are experincing is one that can be attributed to the Idle Air Control Valve, the fuel pump recall they did, or the torque converter, the ECM.
This new model Honda has introduced into the consumer's world has too many bugs.
My car use to die on me when I would step on the brakes. The idle would drop so low that the car would stall.
Took it back to the dealer so many time for the same problem and finally got frustrated and traded the car in.
If you are experiencing this stalling problem, get the dealer to check it out. Insist that they look at the problem.
One time my car stalled out on me, while I was in the middle of traffic at a stop light. Luckily there was no one behind me or I would of been rear-ended.
Stalling problem is no joke. New vehicles are not suppose to do this. Honda has made a serious design flaw with their ULEV car.
Food for thought.
i would like to thank the theives for not damaging my locks or breaking windows.
i hope someone has info on this mystery and info on how we, civic owners, can protect ourselves from break-ins and theft. i'm sure some of you guys have large investments to protect, especially when your civic is modified.
Somebody please provide advice about synthetic oil. Worth it? No value? Your experience? Thanks.
I've owned my Civic for over a year and have put over 15K miles on it, both in very hot weather and very cold weather. (I live in Wisconsin.) It's never stalled on me (though it does idle very low). And even today, when it was about 10* when I went outside to start my car, it started on the first crank.
I think the seat rocking issue _IS_ a design flaw. My seat rocked as well - I took it in, the dealer found a TSB on the item, and ordred replacement bushings provided by Honda.
You also commented that the seat rocking issue is a design flaw. Well I have known people who own the new 2k1 civic and have not experienced this seat rocking problem.
From what you wrote in the above post is it still a design flaw, or are you contradicting yourself?
The words design flaw, though vauge, describes that Honda should of thought a little more about their product rather than pushing it out into the open market where a number consumers are unhappy.
Sure there will be some bugs for the new generation Civic, and sure there will be a lot of unhappy customers, "You can't please everyone".
But when you see the number of complaints of unhappy customers you start to wonder what is going on. To view this go to www.nhtsa.dot.gov.
Also, when you look at the recalls that were called by the factory you also should be skeptical about the reliability of the car.
From my experience as an engineer, I can honestly say that Honda made a boo-boo.
Great body style shell, but does not have the guts to be reliable.
Recently, our '97 Civic LX's SRS indicator light came on and stayed on ... the manual said have it checked out ... the dealership said the entire air bag system had gone out and must be replaced -- to the tune of $361 + $98 labor.
Is this a problem others have had? It seems odd that it would just quit working after only 79,000 miles of virtually maintenance-free driving.
This particular service manager said there was no manufacturer's warranty to cover it, but I really can't afford that kind of hickey to my pocketbook.
Any advice on whom I could contact for help?
(I noticed a similar problem in post #182, but can't get in contact with the guy.)
What oil do you all recommend?
Mudd
