Visitor Agreement.
Greetings from sunny Miami.
When I park my car outside overnight in cool humid conditions, I start it the next morning, the drive belts squeal for the first 2 minutes or so. When I start my car in the afternoon (after sitting in the parking lot at work all day) the drive belts are silent..
These are the original belts, EXCEPT for the A/C belt which was installed last year. I did check the belts' tension and they are correct.
Is this situation (cool, clamy mornings/dry afternoons)causing the belts to contract when cold therefore squealing a bit when cold, and expanding when warm-squeal stops!
I would appreciate Auburn63s' help on this one or anybody else who is knowledgeable.
Thank you, Rich.
I'd like to offer my Honda Civic 1996-2000 service manual (Honda Motor Co is the publisher, no USBN number unfortunately) for sale. I bought it, but didn't use it. So it's in "like new" condition. If interested, please e-mail me at vasvik@netzero.net
So I had to drop by another dealer.. I bought Honda becuase I've heard that honda is worry-free.. But I could not say that I have been happy about this Honda.. Pretty much frustrated experience from both mechanic and dealer at Honda.
Have you ever heard like "What did you expect after buying Honda Civic".. Could say that it was the humuliated experience.. I don't know whether I will go with Honda next time.. Probably I will go with another Japanese car maker.
My car milege is under 20,000.. But I think that I've visited at the dealer about 15 times for this on-going noise problem..
Greetings from sunny miami.
Squeeky noise when driving over bumps
Driver side front window rattling at speeds of 35+ (continually cranking down window and rolling it back up to create better seal...never worked)
Slow crank down in hot weather and rain with windows.
Radiator busting after 2 months of owning new car
Seatbelts breaking 4 times 1st month, 3rd, 4 and 6th month of owning car...
Air conditioning going out 5 times (3 times componets had to be replaced)
AC never really getting cold...even after 30 min of being on
Clutch going out after 2 yrs (car was never raced and clutch was gently handled when driving)
Idle and engine problems at 2 1/2 years. Thank goodness for warranties!
Oh and then the crowd favorite...honda service techs forgetting to put the new oil in the car after an oil change. Never ever go to Rock Honda, Spreen Honda or another honda dealer in Ontario...bad service ppl.
I own a 1998 civic hx. The first three years were great but the last year it has developed a few problems and the dealership can't seem to fix them.
1. strange rattle in the back, they said maybe it was a rock.
2. The tranny-a cvt-doesn't come down fast enough when I hit the brakes. It trys to take off if I don't hold it my foot on the break. The dealer said Honda is aware of the problems but have no solution. The warranty is over but Honda gave me goodwill and tried to flush the tranny. I was told to come back in 6 mos. maybe there would be a solution.
3. It has only been four mos and it still jerks sometimes so hard it shuts itself off. Also now the brakes are slow to respond and the car accelerates to 70 mph with little pressure while other times it sticks. This time when I called for an appointment I was not greeted warmly. I am afraid to start spending lots of money on a car that has many years to go. btw it only has 28,000 miles.
Help can I get rid of this car? It is paid off in 4mos.
She mentioned yesterday it took much longer to start (a few times of 10 second cranking) and when it did, the 'check engine' light was on. Other than telling her to keep at least a 1/4 tank of gas at all times, any idea would could be causing the problem? Thanks!
Usually starts it cold, on a slight incline towards the front of the car...
-B
-B
Someone has activated the child lock on that door.
Easy, huh?
We don't have any problem with our CD Player. My daughter has been playing CD-R from office depot and it played all the song.
bjk
I don't think Civic gas tank could hold extra 4 gals of gas.
I took my 2001 Civic to get an oil change yesterday to the same service center that has done every oil change on the car. They tried to check the air filter and came back and said they could not. One of the embedded nuts in the lower air box had busted loose when they tried to loosen it and they can not remove the lid without further breaking the lower box.
They told me that Honda specs say to tighten the bolts to 16 lbs of torque, and that the heat and vibrations of the engine can cause the bolts to seize further. The part is $42 to replace and an hours labour. So if I want them to change the air filter next time it will cost me and extra $107. They told me that this was a common problem.
When I got home I checked the rest of the bolts myself. 3 of the 7 bolts were broken loose. There is no reason to tighten these bolts to 16 lbs. They are only holding on a light plastic top. But they said they had to because it was Honda spec.
Has anyone else experienced this problem?
Besides this, I have had no problems with my Civic. I really like it and am thinking of upgrading to get a better interest rate.
Was it 16 in-lbs or 16 ft-lbs torque? I didn't see the spec but just by guessing it, it should be torque to 16 in-lbs which isn't very high. If 16 ft-lbs that's way high for screws like that.
To me Air filter is wear and tear part, but screws and nuts to hold the air filter box together are not wear and tear parts. It should cover under the 3 years 36k miles warranty.
bjk
Procedure is in the owner's manual:
1. Turn off the engine
2. Press and hold the select/reset button on the instrument panal, then turn the ignition switch on (II).
3. Hold the button until the indicator resets (approximately ten seconds).
bjk
Quick update about my "quirky" radio that would switch stations on its own:
Honda replaced the entire stereo headunit. Apparently there was a malfunction within the unit. Replaced free of charge of course
I'm relieved it was not an electrical problem- that would have worried me greatly of problems to follow!
Carrie ~Owner of a 2002 Honda Civic EX Sedan with Automatic in Eternal Blue Pearl.
I have not reviewed the spec. That is just what the mechanics told me. I know they are torqueing it down to 16 ft pounds, because I had to use more than that to remove the ones that would come out. I will ask the mechanics to review the spec to see if maybe they missed it.
Thanks for the advice.
Typical brake job if just replace the front pads at dealer should be less than $100 bucks. Charge $40 bucks for inspect front brake is a ripped off. Lots of places will perform free brake inspection. Front brake wears out at 30,000 is normal.
bjk
