Visitor Agreement.
I agree that a warm engine does provide better performance, however I don't need all that extra "performance of the engine" right out of the driveway when I'll be traveling at about 30 mph for a couple of miles before I get out of the residential area.
I think today engineers are more concerned with the life of the vehicle beyond the warranty. If they made a car to last 36,000 miles, the company would be out of business. I do believe the big three attempted something like that several years back, and they lost a lot of market to the foreign companies (Honda, Nissan etc.)
I bought the new OEM air filter from my local Honda dealership. My question is, should the air filter be oily? You can touch the paper fins (not sure what that part is really called) and they are moist with an oily substance.
My old air filter is also oily, so I guess they're supposed to be like that, but does the oil improve the performance of the filter? Maybe trap more contaminants?
Just out of curiosity, what kind of climate do you drive in? I'm surprised an air filter was already that dirty on you. Anyhow hope this helps and I recommend buying a K&N filter next time around.
I had the same experience with my earlier Honda. What experience do you cite your responses from? I know other owners of what you must consider "high" mileage Honda's which I consider normal and they have had similar experiences.
By the way, the climate in the Northern CA bay area isn't extreme. As cold as we get is 40's and in summer maybe up to 105. The only reason why I change my air filter so often is that I drive in dusty areas. There are tons of diesel trucks hauling dirt and gravel on the freeways that I drive on every day. Not to mention all the diesel fumes and soot from the big rigs themselves, and pollen from the trees and grassy hills near the freeway. Anyone who drives the 24/680 freeways from the Caldecott tunnel through Concord knows what I'm talking about. The freeways are always congested with traffic and you will always pass at least 10 if not more diesel trucks hauling dirt.
PS: If you're really looking for a little extra boost I highly recommend the AEM V2 intake which I currently have in my 03 EX coupe. It is a direct fit and not a universal part
I would ask for an estimate for repair from an independant, I think you will cut your price significantly. It could be noisy valves that need adjustment or work. I would not throw in the towel with the first shops diagnosis.
You have no basis for the longevity of your methods except hearsy and some information mostly based on advertising and extrapolation of read material. You have never kept a Honda vehicle as you mention past 100k miles. Many people who write to this board have experince with 150k+ and personally I have into the 200's. The first problem with your advice to others is implying an non-needed cost is required to operate the vehicle. They last fine without the extra's as I have and many have found.
anyone please help.....thanks
I have a 2004 Honda Civic Coupe EX with manual trans. I just purchased a set of those Xenon lightbulbs, both low and high beam. Yesterday, I popped open the hood and I having some difficulty replacing the front head light bulbs. Can anyone help? Do I have to remove the headlight assembly?
I had a similar noise as you describe on a Camry.... had the timing belt replaced.... noise went away & car ran like new.
I would do that first... since you know you're going to have to do it anyway.
We tested a bunch of Civics, and they all had the gurgling. All but a used 2002 and the hybrid had the "jet engine" sound, but this sound was less noticeable on the automatic transmission cars. The service technician thought the sound might be because of what he called "break-in" fluids. Apparently, new cars have special fluids called break-in fluids that get changed out with regular fluids at the first oil change. Because they're different, the engine can make noises with them that it won't make after they get changed out.
We've been on the lookout for any 2004's out there that have had their first oil change, but we can't find any. If anybody out there has one, we'd be very interested to know if you've noticed a change in the noises your car makes since that first oil change.
1. What is the proper way of breaking it in? I understand there are differing opinions on this topic.
2. What kind of oil should be used, and when should the first oil change take place?
My 1992 Civic EX (183k) has recently developed problems with the blower. It still works more or less on the lowest setting, but anything above that and it will make a very loud, unpleasant, constant noise. Also, even if it's on "1" and I drive over the slightest bump or pothole, it will start making the noise too (until I turn it off and back on). What do you think it is and how expensive would it be to fix?
The other noise I'm getting is when I start from a complete standstill. As I begin to move slowly, I hear a sort of whining noise that seems to be coming from the front, right side (wheel?). This only happens at very low speeds (less than 3-4 mph) - as soon as I begin to move a little faster, the noise ceases. Any ideas?
With your other noise I'm not exactly sure what you mean by a whining sound, but I would take a look at the condition of your brake pads. It may be your wear indicators hitting the rotors which means time for a new set of brake pads! Sometimes the wear indicators won't make any noise while driving at higher speeds and won't go off at all while braking. At least thats my past experience...Anyhow good luck.
2) Honda uses special break in oil. Go the full interval ie 5000 miles. People will tell you about shavings but these don't really exists (old timers tale). If you are uncomfortable with long interval do at least 3000 miles with special break in oil. As far as oil use 5W-20 as prescribed by owners manual. Lastly google "Bob is the oil Guy".
My 2001 Civic coup ex has 40K miles.
The car was fine in the am on my 30 mile ride to the office.
When I came out of the office the transmission would not engage although I was able to shift to the different gears, but there was no response from the car. The engine would rev. It was as if the transmission was not getting the signal to go into gear.
I was towed to the dealer. The car sat overnight. In the am the service manager wrote up the work order and confirmed what I had told him. The could would not engage.
Later in the day they called me to say that the mechanic started the car up, shifted gears and engaged them normally, drove 15 minutes and was unable to find the problem. They said they did all the necessary "tests".
Any ideas what could cause this to occur, then "magically" return to normal.?
Dennis
I wouldn't describe the noise my Civic makes as like a 'jet engine' but more like a high pitched whine. Also the gurgling noise that you described, I would describe that other noise as some sort of 'trickling' noise that liquids make when they travel through pipes or metal surfaces. Then there's the low-pitched buzz...I'm basically repeating myself again of what I've said a few pages ago.
Nick
I can be driving down the road, doesn't matter what gear, RPM, or Speed; With my foot on the accelerator, it's like the gas is completely cut off. I can be going say 70, the car will "jerk", then starts slowing down like it isn't getting any gas. All of a sudden (maybe 2-3 seconds), it's like the gas is cut back on and it resumes previous accelleration. It's so bad at times, I have actually caught 3rd gear on the freeway. It's actually pretty dangerous, almost got slammed by an SUV on the freeway last night because of the stalling.
The bizzaro thing is that it's an intermittant problem that has been occurring for the past 5yrs or so and no mechanic (dealership & private) has been able to duplicate the problem. It will go about 6mnths running fine, then for about a week or two it will intermittantly start doing it again. Then it will stop for another few months.
This is the only problem I have ever had with this car and I really can't afford to get rid of it. I think all these men think I'm just imaining it
3 weeks ago my wife and I purchased a Honda Civic 2004 EX. We made our purchased based upon price and Honda’s history of producing reliable cars.
We are very happy with the car.
Anyway, the other day I notice a very slight “ tinny metallic, vibrating sound” coming from the engine area when accelerating to about 1900-2100 rpm.
Above that, the noise disappears. Also, the noise isn't there when it is idling.
Up until this point there had been no sound and the engine has been nice and smooth even when between 1900 - 2100 rpm.
The car currently has about 400 hwy miles on it. It runs fine and accelerates fine, but I am now concerned about the noise.
Of course, maybe I am being a little paranoid, new car and all. And I am sure that my first scratch and/or dent will be a traumatic experience for me.
However, now my "warm and fuzzy" feeling is fading.
I have an appointment to have it looked at in the next few days.
But, in the meantime could anyone make any suggestions as to what might be causing this noise ?
D. P.
Seems to only make the noise when the driver side window is down. And when I press on the door paneling near the lock tab or on the glass, the rattle stops. Could it be the glass in the passenger side door?
Anyone have any ideas as to what is causing this?
A question for you and to pass onto mechanic, does the tach drop to zero when this happens or is the engine running? If it drops to zero its likely the power to computer has been cut. I had a similar deal but the wire a ground was obvious and sticking up off the engine on old VW Jetta.
My 2003 Civic LX (manual transmission) had the same "very slight tinny metallic, vibrating sound" coming from the engine area. But only mine occurred at about 3000 RPM. The noise came from a slightly loose exhaust manifold and the dealer took care of it on my first oil change under warranty.
Don't worry too much, if you take good care of your Civic with regular preventive maintenance, it should last a long time. My previous car was a 1989 Civic Si hatchback which had 252,000 miles and I only sold it because the original distributor finally broke.
Hope this helps,
Derek
