Visitor Agreement.
The temp gage doesn't go up as high as i think it should.It barely rises off the cold mark.
Can you give me a hint what is involved here.
Thanks for your help.
The temp gauge may not be working right, but most likely you have either a stuck open thermostat or don't have one at all. Honda engines are not very hot engines to begin with> None of the Honda's I had ever had the temp gauge climb over the quater way up from bottom, even in the 100°F with A/C on, climbing a steep hill. Honda engines have alluminum block and head, and have a very efficient cooling system.
I have a '95 Civic EX (1.6L VTEC) and last night while reaching some 'extra-legal' speeds, I noticed my car topped out at 95 mph. I have aftermarket low profile tires with 17 inch wheels--and I'm aware that going in excess of +3" can really affect the performance of a vehicle--but is this the result of a speed-limiter or the cosmetic enhancements that I have made?
95 mph is pretty ridiculous in my opinion, and I am genuinely concerned. Any input that you guys can give is greatly appreciated.
THX
sdiori
I do think however, that is deliberately difficult to get it into first or reverse. This is to keep you from going into 1st when downshift to 3rd.
The other thing is that the wheel well is a bit close to the clutch and may occaisionally keep you from pressing the clutch down all the way unless you leg is moved inward a bit.
Enjoy the car!!!!!!
-Marc
I happen to know you don't live in Montana, so you probably don't know that changed 5 years ago.
http://www.mdt.state.mt.us/speed_limit/
And I belive there was always a "safe speed" law that allowed officials to determine what the maximum safe speed was, based on weather and road conditions.
I recently took my 2001 Civic coupe to the local Honda dealership for a free 40 point inspection...
My Civic has roughly 46,000 miles on it and I was told my the Honda repairman that my struts are leaking and need to be replaced... Total esitmated repair bill is to be around $750.00 !!! Yikes !!!
Does anyone else have similar experiences with this type of problem? Any suggestions and/or comments are welcomed ! Sam
I feel that there is a lot of tire noise, and Civic does not have the best or quietest ride among the compact cars.
Please advise. Thanks.
They stated they would warranty their labor and aftermarket part for the typical 1 yr/12,000 mile Honda warranty on repairs. The car had 120k on it when this repair occured. The old OEM raditator did not fail but was not flowing well according to them, the temp guage would stay at 7/8 at speeds at or over 75 mph in summer. I did change fluid at required intervals also with even OEM Honda stuff (dealer installed) and it failed.
Anyway the car has 210k on it now and no problems no engine failures, no premium and no additives. Just oil changes every 4k miles and regular maintenace intially by dealer till 120k and now an independent. The car runs decently, not like new obviously, I plan on purchasing a new car likely Honda/Acura within the year. 10 years and over 200k miles is enough.
Replacing a radiator on a Honda is not simple but doable for average DIY. On most Honda's you do have to remove the front cross member.
This was approx 4 yrs ago. I cannot vouch how they service vehicles currently as all I have used them for every year is a state inspection that is free on my birthday an oil change.
Of course, it's desirable to use OEM parts. I think here, we had a dealer offer the customer an option on a very high mileage car of little value.
They could spend 600.00 (or whatever)on a factory OEM radiator or maybe save a few hundred on a aftermarket one that would do the job too.
I know we recently had a single mom with limited funds bring her 1988 Civic in because it was making a terrible noise. The CV joints were shot.
The Civic had over 200,000 miles on it and she was broke.
To help the poor lady, we installed a set of remanufactured half shafts instead of the much more expensive OEM joints.
Something wrong with that?
No, Honda dealers should stock and install OEM parts. I for one am convinced they fit and work better than aftermarket parts. I doubt if any Honda dealer STOCKS parts other than Honda OEM.
There are times, however, when exceptions should be made. Just common sense.
Of course, the customer needs to be made aware of their choices and it must be explained to that customer that the aftermarket radiator probably won't fit quite as well and last as long as a OEM radiator.
If you had a 15 year old Accord with 225,000 miles on it and you were struggling to make ends meet, what would YOU install given the choice?
Not everyone can afford to replace their cars after a few years like you do!
I just bought a new Civic LX and happy to join the 'club'. I have some questions on my new car. When you check the gas and brake pads area inside the car, do you see there is a piece of hand size, round shape cloth using staple on that area? Do you know why use staple to build a car? Also, do you find the car a little noise during idle (start, but not move)? Thanks for your input and comments.
