Oil change miseries
jjr21jjr21 Member Posts: 3
edited November 2024 in Mercury
Last mechanic to change the oil must have used an impact wrench to tighten the drain plug. Can't budge it even with a 28" break bar.
Trying to siphon the oil out with a Harbor Freight hand siphon pump, but the dipstick hose meets an obstruction about 3/4 the length of the dipstick, doesn't reach the crankcase--maybe a guide for the dipstick?
Any ideas, clues, or suggestions about how to proceed?
  • thecardoc3thecardoc3 Member Posts: 5,862
    Which direction were you trying to turn the drain plug?
  • kyfdxkyfdx Moderator Posts: 271,243
    Lefty loosey, righty tighty? :#
    It's easy to get turned around especially if someone is lying on their back and reaching overhead to accidently go the wrong direction. A ratchet could help make sure that didn't happen but with a breaker bar.....
