It seems that Honda hasn't figured out a way to fix the problem yet. It's very annoying not knowing how much gas you have.
Honda Corp. wrote me a letter stating that they are working on a solution. They still haven't figured out s remedy yet.
Also had to have a strut replaced and the recall. My family owns 3 Hondas right now, But I can say the Civic '01 is real a piece of junk and I wouldn't recommend it.
Any ideas?
Could something be loose? Anyone else have this problem?
I am taking the car in on Friday for the gas tank recall - having this checked out as well. Also, any fix yet on the bouncy-ness of the rear end of the car? My car had no CD player or fuel gauge issues, but now the recall and transmission are bugging me. Hope I made a good choice....
I have a 2000 Honda Civic LX. Each time I brake from low speed ( 5 to 10 mph) there's a noise similar to a metal-to-metal contact. The noise is either close to the left front tire or is somewhere in the back. I went to the dealer and he told me this phenomenon is well known by Honda and is called "Applied Brakes Click". The way, he described, is that there's is a latch close to the brake pad. And each time the car drives for the first time in one direction (either forward or backward) the latch will clip and that's the origin of the noise. My case is, however, slightly different. The noise is persistent even when I keep on driving in the same direction. I will listen the little "clack" noise at any stop sign or when I stop at any traffic light. The noise was noticed for the first time after the 15,000 miles service. Has anyone ever experienced a similar problem? Pease let me know how you proceed. I will be going to the dealer for the 22,500 miles service very soon. What should I do if they cannot perform a good diagnostic?
Teles
My 92 Civic lx wont start. I had a similar problem before with the main relay. No fuel or ignition, just starter rotation. The main relay checks good. The fuel pump does not operate during start, but does work when jumpered. I have a constant sheck engine light when test connector is jumpered. Manual says electrical portion of fueling system, or
ECM !
The car has 198k, and had a distributor replaced before I bought it.
I tried following trouble shooting tree in repair manual, but don't feel gung ho about everything. The engine light never did extinguish through any of the disconnect/ reconnect steps. I get the idea an ecm is pricy since I cant find anyone who sells them besides dealership and Junkyard. If ecm is bad, should I buy new or take chance on used one from the boneyard? I have heard Honda has problems w/ ecm's in these cars.
At a loss for a troubleshooting step to go for next. I probably missed something obvious. (All fuses were good)
The car is not selling well.
Cars that don't sell well new do not sell well when they are used. The Protege is a good example of this.
Not bad cars but nowhere near the resale of others.
For people that can get past the Honda hype, the Protege is a real contender to the Civic, resale value included. I've seen some Honda incentives such as cheap financing and doubling B2B warranties. Guess they aren't selling well either. And there has been some persistent problems (read "recalls") with the new Civic. How's that compare with the Pro?
I hope the Protege5 doesn't sell well. I used to have a Civic wagon and the new Protege5 is everything I wanted it to be. If they do 0% on it at the end of the year I'm selling my beater Civic and getting one. Then, I hate to say it, I'll have no more Hondas.
Is this normal or did I get a bad half shaft? Should I cancel the appointment to put it in and get a new one?
I know this isn't a civic, but they are cousins. ;^)
Personally, I think that they are a great value used. They are very good cars and they can be picked up for a lot less than a used Civic or Corolla.
My post wasn't intended to slam Proteges. ONECE AGAIN...I think they are great cars.
Just pointing out the fact that for whatever reason the market for Proteges has never been a strong one.
Every dollar spent goes toward the car and not to the bank. Actually a new Pro is probably a better value than a used on right now when the interest costs are figured in.
Too bad. The new Civics are a great car and a great value. Recalls and updates happen to all makes and models and usually don't really amount to a hill of beans.
Pick a car...any car and there will be reports of gloom and doom. No car is perfect.
I’d appreciate if anyone could shed some light on this - if I have to live with it or there’s something to be fixed or anything I may be doing wrong.
Honda doesn't use a hood insulator on the inside of the hood like other cars in its class. You can buy an aftermarket insulator for the inside of your hood which should quiet down the engine somewhat. There are other sound deadening materials you can purchase that quiet the car down but add weight to the vehicle.
Some people swear that undercoating the car will make it more quiet. Otherwise, the sounds you are hearing are typical.
(also i was thinking about the protege, but i could get the corolla at a lower price, everything else about it i loved)
hope this helped
the Passenger Space
DudleyR
I can't believe potential Honda buyers are scared of some of these problems...go check out Fords message boards if you want to see problems and scare yourself.
I own a 2001 Honda Civic EX coupe...big deal about the hose clamp recall....BOO HOO.
I have had no problems yet with my Civic. I have over 10,000 miles which is nothing, yes, I know, but I have always owned a Honda and I have been satisfied. Look at consumer reports and compare those red circles to other autos with loads of black circles. Honda come out tops.
My point is, don't let some complaints by Honda owners scare you. It is very normal for cars to have some sort of bug now and then.....hey, at least the bugs in a car are far and few then a PC...could you imagine if cars were like PC's? Yikes!!
sorry, needed to vent... just my opinion on Honda.
I have a feeling that the Elantra GT is going to start being pretty popular. The only economy car with a little style and still has a good price. The Protege 5 is cool - but underpowered and pricey compared the Elantra GT.
Our Neon (AT, 4 W disc brakes/ ABS, traction control) has 7K on it no single ding, ping or problem, runs like Swiss clock and paid $11.5K. Can you get a comparible Civic for that price?
Well, I know you will start with resale value. But you are forgetting that you pay $1.5K-$5K extra up front. Depreciation rate difference less than 10%.
You rate protege under powered, what about 115hp Civics?
I can't remember.
I'm glad that you've had good service out of your Neon. Our family has just had bad luck with many Chrysler products (Minivans and Jeep Grand Cherokees). We just don't buy their products anymore. The 4 speed transmissions in the Chrysler minivans are notorious for not lasting long. We had problems with three of the four vans that we owned over the past ten years. I can think of several other people that have had similar problems with the transmissions, even in the Jeeps.
I haven't had any problems out of my 2001 Civic EX 2 Door, and I'm about to roll 5,000 miles. I'm hoping to get many years of trouble-free service out of it. Hondas are usually known for that.
I got a whole new distributor. The only thing I had to change over was the rotor and shroud. I am guessing that the ignitor and coil are part of the distributor assembly. Anyway, I went ahead and got a new rotor,cap, and plugs. The guy at the parts counter said to bring in the Ignition control module and have that tested. The new stuff didnt work, but was needed soon anyway. Another friend said that the circuit for the plugs route through the Injector wiring for ground. I believe that the ecm controls the injectors and fuel pump through the main relay. The main relay did check good, but I guess I could check it again.(I popped a fuse or 2 while troubleshooting--jumped out to test pump)
thanks for the input, I am getting tired of dead ends. My wife needs the car soon and I am close to sending it to Honda. I don't have much time to work on it. I really want to find the fix myself. There isn't much satisfaction when somebody else does the work. I'm rambling, Thanks for the help.
I am not saying the Civic is the best econo car either. I am finding that out as the days go on. Things that I don't like about the Civic are the ride comfort and the interior. To get my seat back far enough (5'11 here) I have to reach too far to use the radio. I have rented two new Neons. Both were fine, but the interiors did not seem as well assembled.
I really think that if the new Elantra did not have the Hyundai name, that the Civic, Neon, Focus, Sentra etc would be pointless. Just my opinion.
