2024 Ford Mustang Mach-E Lease Deals, Incentives, Rebates, and Prices
189111314
  • mcbagpipe89mcbagpipe89 Member Posts: 9
    thank you, i'll do that. would you also be able to provide the same info for a 36/15 lease in 98580 for the 2024 mach-e premium (extended battery, awd)
  • kyfdxkyfdx Moderator Posts: 271,926
    Subtract 3% from residual when going from 10K to 15K/yr
    perfect, thanks
  • AtomicX28AtomicX28 Member Posts: 6
    edited February 2
    Does anyone have the MF and RV for the following:
    2024 Mustang Mach-e, GT, 10,000 miles
    36 or 39 month lease
    Zip code 33458
    Zip code 33458
    0.05% APR
    52% or 51% residual
    $8000 lease cash
  • torifile_edmundstorifile_edmunds Member Posts: 16
    edited February 2
    Can I get numbers for premium 24/15 AWD with extended battery in 27707?
    0.05% APR
    58% residual
    $8000 lease cash
  • R1redbaronR1redbaron Member Posts: 10
    Will you please provide the numbers for premium 24/12 AWD with extended battery in 34786?
    0.05% APR
    60% residual
    $8000 lease cash
  • beercules87beercules87 Member Posts: 1
    Can someone please provide the RV, MF, and incentives for the Mustang Mach-E GT for either 36 or 39 months/10k miles in 33183?
    0.05% APR
    $8000 lease cash
    52%/51% residual for 36/39 mo
  • lcwallacelcwallace Member Posts: 2
    Can someone please provide the RV, MF, and incentives for the Mustang Mach-E GT for either 36/39 months/15k miles in 37027? Same for a Premium AWD with extended battery
    0.05% APR
    $8000 lease cash
    GT
    49%/48% residual for 36/39 mo
    Prem
    50%/49% residual
  • RoiiiRoiii Member Posts: 5
    Could you please provide the numbers for premium AWD with extended battery for 24/36 in 94402?
    15K/yr
    0.05% APR
    58%/50% residual
    $8000 lease cash
    15K/yr
    0.05% APR
    58%/50% residual
    $8000 lease cash
    Hi Could you check the numbers for $0 down for 24/36 and 10k/year
    Roiii said:
    15K/yr
    0.05% APR
    58%/50% residual
    $8000 lease cash
    +3% on the residual for 10.5K/yr
  • ronbest3638ronbest3638 Member Posts: 2
    Can someone please provide the RV, MF, and incentives for the Mustang Mach-E Premium RWD for either 36 or 39 months/10k miles in 85004? Also $0 down
    Standard or Extended range?
  • newcarshopper2019newcarshopper2019 Member Posts: 3
    Can someone please provide the RV, MF, and incentives for the Premium AWD and RWD with extended battery for either 36/39 months/15k miles in 37763?
    0.05% APR
    $8000 lease cash
    AWD: 50%/49% residual for 36/39 mo
    RWD: 49%/48% residual
    Standard
    Standard
    0.05% APR
    $8000 lease cash
  • ESticklandEStickland Member Posts: 4
    Can someone please provide the RV, MF, and incentives for the Mustang Mach-E GT for 36/39 months/12k miles in 02176?
    0.05% APR
    $8000 lease cash
    51%/50% residual for 36/39 mo
  • glegaspiglegaspi Member Posts: 2
    Hello, may i please have the money factor, residual, and incentives for a 24/36 month, 10/12k miles lease mach-e premium RWD extended in 94545?
    0.05% APR
    $8000 lease cash
    59%/51% residual for 24/36 mo, 12K/yr
  • EljaycrownEljaycrown Member Posts: 2
    edited February 11
    Can someone please provide the RV, MF, and incentives for the Mustang Mach-E Premium Extended Range for 24/36 months/10k miles and $0 down in 92101?
    RWD or AWD?
    RWD or AWD?
    RWD
    RWD or AWD?
    RWD
    0.05% APR
    $8000 lease cash
    60%/52% residual
  • 1BadTrainDriver1BadTrainDriver Member Posts: 9
    Could I please have RV, MF, and incentives for a 2024 Mustang Mach E GT, 24 or 36 months, 43065 zip code? TIA!!
  • Hi there can I get the RV, MF and any incentives on the 2024 Mach e RWD select/premium standard range. 36 months 10K miles for 29680
    Annual mileage allowance?
    0.05% APR
    51% residual
    Prem: $8000 lease cash
    Select: $7750 lease cash
  • LeftBlankAgainLeftBlankAgain Member Posts: 4
    Can you please share the MF, RV, incentives for a premium rwd extended battery. 12k/39mo 95632
  • Itbrodee60Itbrodee60 Member Posts: 9
    can i get the RV and MF for 2024 ford mach E select 36/15 92545 zipcode
    0.05% APR
    50% residual
    $8000 lease cash
    RWD or AWD?
  • leaveoverbuyleaveoverbuy Member Posts: 37
    Hi there, can I please get the MF, RV, incentives in 85225 on a 24/12 for the Select RWD/AWD and Premium RWD/AWD? Thanks!
    Could i get both? Looks like the 39 month is the sweet spot for the Mach E so could you send that as well for 12k/year.
    RWD or AWD?
    RWD standard
    39/12
    0.05% APR
    Select
    RWD: 49% residual. $7750 lease cash
    AWD STD: 50% residual. $8250
    AWD EXT: 51% residual. $8250
    Premium
    $8000 lease cash
    RWD STD: 49% residual
    RWD EXT: 50% residual
    Add 9% to residual for 24/12
    RWD or AWD?
    RWD standard
    0.05% APR
    48% residual
    $7750 lease cash
    39/12
    0.05% APR
    Select
    Premium
    $8000 lease cash
    Thank you for you help and info! I am signing on a Premium AWD tomorrow:) Initial quote with $0 down was $685, signing price is $414. Knowledge is power!
    39/12
    0.05% APR
    Select
    Premium
    $8000 lease cash
    Congrats! Thanks for the report
  • CarbrowserCarbrowser Member Posts: 1
    edited February 20
    Can someone please provide the RV, MF, and incentives for the 2024 Premium AWD with extended battery for 24 months/12k miles in 73160?
    0.05% APR
    59% residual
    $8000 lease cash
    Can you please share the MF, RV, incentives for a premium AWD extended battery. 12k/39mo 95632
