jukeboxcarl2: Thanks for the input. The only thing that I could get out of the dealership was to use premium grade fuel, contrary to the owners manual.
I haven't had any issue in two Fords... 90 ranger 2.3L 4-banger and 00 explorer 5 L v8. I have noticed the cars I hate to follow because of sulfur stink are mostly imports. I have also heard some of the local auto mavens say this is due to rich operation because of a bad oxygen sensor in the exhaust. some sensors are iffy from day one, others get that way... when the sensor in my 4-banger got "lazy" I could start the ranger, but about the time it started to warm up, it went rich and stalled. no fun at 18 below at 2 am to be explaining things in a very loud voice to an engine. anyway, try checking the o2 sensor.
I took my 1998 Sentra to the dealer in my area Akron,Ohio. I thought maybe the catalitic converter was bad. I only have 2000 miles to go before the warrenty on it expires. They were of no help, said all Nissans do this and there is no cure. Then they pulled out a paper for me to read. It said gasoline is being produced with too much sulpher in it. There is some truth to this. Using BP or Amoco = Worst smell for me. It try to find gas thats not oxygenated. Any help out there?
like, duh, Nissan, if all the gas is sulphurated, design for it. or have your car known as a stinker by everybody in the market. I have run Citgo, Amoco, Holiday, SuperAmerica = Ashland midwest, Mobil, Cenex, and several brand-X and no-brand fuels in two Fords and a 1975 Buick with no stink. A little "rich" dusty smell on cold start is as bad as it gets. I know there have been 6 different refineries producing that product, and who knows how many down the Williams pipeline, over the years.
it's some of the car makers, not the gas producers, who haven't got their act together on H2S.
Well, it is almost a year since I purchased my Infiniti G20 and the sulfur smell is still existant on a daily basis. I give up!
I discussed it with Nissan's Corporate office for a while and they refused assistance. They said that I must have bought gas at some point with a really high sulfur content and now I have to wait for it to burn off. They could give no estimate of time for when this might happen. They passed along the same pamplet to me that they give everyone that 'defines sulfur' and explains 'rotten egg odor', etc.
This is 99% a Nissan problem and if you ever smell this at a stoplight, look around and I guarantee there will be a Nissan or Infiniti in sight.
There are no more suggestions worth trying. I tried everything and nothing helped! I will NEVER buy a Nissan automobile again and neither will anyone I know.
it has been suggested that flashing the engine computer will help on other brands. that sorta depends in most instances on newer control code being availiable from the manufacturer, I suspect... my experience in flashing things like half-million dollar data switches in production, all the way down to my homebrew FrankenClone computers in my bedroom, is that real-time processors can confuse their flash code on occasion and thus need a refresh for the jolly Hell of it, but load-at-boot-once machines don't usually have issues. engine computers are a real-time processing application.
if the module dies in the flash, it was probably really No Freaking Good to begin with... but it is a nasty way to spend 600 or more dollars for a minute's worth of work.
in polite society, especially in the warranty period, a dealer uses a laptop computer to re-program the flash EEPROM memory in the main engine computer... that's "flashing" it. power shops also get into it, but that voids warranty and carries no EPA warranty protection against pollution, engine damage, etc. a really screwed up engine computer can blow the engine up, but usually a hosed box will just be a no-run situation.
the stink from H2S gas in the exhaust is caused by dumping of excess fuel into the cylinders... it is carried out as unburned hydrocarbons, along with the additives and problems, and those react rather violently with oxygen (mostly) in the catalytic converter. sulfur from gasoline is a problem in this regard, and it catalyzes with hydrogen to make hydrogen sulfide gas. this is a pollutant, in water it's called sulfurous acid H2SO3, and emission is limited by federal law. the tailpipe sniffer should also be seeing excess unburned hydrocarbons, low CO2, and probably higher CO than permitted. eventually this excess hydrocarbon in the engine exhaust will burn up the catalytic converter... the way they make 'em nowadays, the cat "sponge" of ceramic will probably shatter from the excess heat and block the exhaust.
none of this is good. it is incumbent on franchised dealers to honor their warranties and the 60 or 80 thousand mile EPA warranty and correct these problems. dealers will piss and moan about and try to blame things on sulfur in gasoline... and dangit, that's nonsense, it's been worse in the past, and the system is designed to deal with it, or the car would not be certified for sale in the US.
if they can't get that together, and frankly all they need to know came in the factory base tuneup training if they bothered to send anybody to it, you may need the state pollution board and/or your lawyer to get involved. they need to sniff the tailpipe, put the car on the box, and check the flash revision on the car, and see if there are updates from the automaker's national service webserver. if so, flash it in.
if the engine computer is sick, flashing it could kill it. so then they replace a computer under warranty, ain't nothing evil about that, either.
this is assuming that everything works as the computer tells it to do, which puts the onus for the problem on the computer telling it wrong. any way you put raw gas into the exhaust stream... stuck injector, bad plug, wire, coil, or output transistor from the computer preventing cylinders from firing... also can cause the same result. so that's why you need to wire the car up all the way, run it per the EPA long test, compare the results to the handy-dandy tree of findings in the service manual, and thus determine all the likely faults and fix 'em in order until the problem is gone.
what has been happening is... it runs, they got things to do, they didn't look at your problem as the factory service books said to, and you are driving an illegal car. they need to deal with it according to the books. maybe they need to finally sit down and read those books, but if you can't get their attention, get an advocate (aka lawyer or pollution bureaucrat) to remind them they are supposed to do more than count the money at the end of the day over there.
if I seem a little torqued, well, I don't like sitting behind those stinkers, illegally firing up my asthma. I want them all fixed or replaced, now. barring that, I want the guys who DON'T fix them in the can, and the Federal pollution laws allow for that.
Thanks a bunch. There seem to be a stinking problem with new (2003) Toyota Corolla and other ULEV Toyotas.
My Cololla stinks only occasionally (heavy accleration) so I am not sure how aggresively to pursue this. The Toyota officially denies the problem and steers people to low sulfur gas (some premiums).
the flint hills (fka koch) refinery in newport, MN and chevron across california have retooled early to meet the EPA 2005 no-sulfur requirements. you can get clean gas in all formulations in those areas if you know how.
in the twin cities metro area, it's "blue planet" gas at holiday stationstores from flint hills.
my understanding is the chevron blends in most of california are sulfur-free across all grades, but see a dealer to be sure or check their website.
there will be other regional refineries make big local noise when they get their tool-ups completed, so watch a newspaper near you...
meanwhile, it might be worth dropping an email to NHTSA. yes, put in a complaint on your stinker. they get enough, they'll put a little pressure on friends carmaker that you and I and our lawyers can't www.nhtsa.gov
How can it help with stinky smell?
Who can do it?
