You beat me to it. I was THINKING of saying that, but was afraid of starting a war here. That's who I heard it from too. I never had that problem anyway because I learned years ago never to use wax/polish on textured trim.
This car really has a very deep and rich shine. I can see why it is called show car wax. Here's what I didn'
1. Washed with Dawn, tropical scent since we didn't have standard blue.
2. Used Strip Kleen Surface Prep to remove all old wax. I got this from an automotive paint supply store. Great for removing globbed on road tar too. It came off in about a minute. It took off tree sap quickly as well (thin coat).
3. Used Erazer Clay Bar and Meguiar's Quick Detailer as a lubricant. Much quicker than my first time was a year ago. Like all car detailing, it becomes easier with regular care.
4. The hood had a scuff, so I used Meguiar's #9 Scratch Remover and Surface Prep on it alone. Great job, removed the scuff, reduced some prior swirl marks, and left the surfact ready for wax.
5. I then used 3M's Hand Glaze everywhere else. It was slightly more abrasive that Meguiar's #7, and actually buffed down the scratches. Great for cars that have some surface scuffing. I applied it with a random buffer.
6. I then used 3M's Perfect-It show car wax. I used the can that I purchased directly from 3M. It had a wonderful coconut smell. This was good because on examination the paste wax was embedded with small particles that resembled short coconut pieces. There is no way these particles could have been suspended in a liquid.
The technical advisor said to use it by hand, but when I stirred it it was fairly soft. so I got out a new bonnet and applied it by machine. Don't put too much on the pad, or it will scatter little chunks all over. When applied thinly it went on quickly. It really doesn't have any abrasives. My Red car would have left something on the terry bonnet if it had.
When dried it was more clear than a carnauba wax. It wasn't as easy to remove as a liquid, but I would expect that. It was about the same as Meguiar's #26 Hard Yellow Wax.
It was beautiful when I got done. The shine is deep and rich. It looks the best it ever has. But the last time I gave it a similar treatment was just when I was starting to extensively detail, and I didn't have that much experience. I also had a lot of oxidation to remove. The blaze red finish positively glows. All for about $15.00 bucks.
If I'd used different products you might say I've been Zainoed. My argument here is that an excellent surface prep really adds depth and clarity to the shine regardless of the product.
Initial Evaluation -- Impressive.
The shine is supposed to last over 6 months. I'll let you know. That's why I bought it for this vehicle.
I had excellent results with the above on my garaged Club Sport. I used the 3M Hand Glaze as prep followed by the wax. No clay, no Dawn. The entire process was quick and easy-@2 hours. Result: the paintwork is smooth as glass, with a very deep shine.
Britton2. I just let it sit for about 15 minutes. However the can says that it can be shorter than that. You are just supposed to use a section at a time. I did the sides, then the roof, hood and trunk in separate stages by machine.
Div 2: The Dawn was just a wash as a prep and took no time. Clay bars depend on use. My cars are outside and need a yearly job. My Dad's in a garage, and doesn't appear to need a clay bar after a year. But to me, a clay bar seems to add some extra clarity and depth.
I have no doubt that your Liquid Perfect-It wax produced excellent results. I can't wait to try mine next summer. I used the Paste because it has ingredients that are more durable. 6 months instead of the liquid's 3 according to 3M tech support. This is of course an average. Your liquid should last longer if it is away from the elements. I wax my cars every 3 mos on the average. For my Dad's garaged one, every 6.
I was just reading thru a co-worker's "Final Coat" paint protection warranty documents (she's got a P5). I told her that I thought it was a waste of money, but the dealer gave her a "discount" on it.
Anywho, the "helpful hints" section says this: "If you have purchased FINAL COAT Paint Sealant for your vehicle, then it is not necessary to wax your car. Wax will not harm your Paint Sealant, however, the wax itself tends to yellow and dull your paint finish."
Then it goes on to say: "If you get the urge to wax, we recommend that you use #FC 218 FINAL COAT Co-Polymer Car Polish as per instructions. It is specially formulated to Fortify, Restore and work in conjunction with your FINAL COAT Paint Sealant to provide maximum protection against the elements."
So wax makes your finish yellow, but they still provide a recommendation for THEIR brand?!??! Just thought you guys might find this as humorous as I did.
Sorry, but I don't see the conflict that you two seem to in what the company is quoted as saying about wax and then recommending a polymer. You seem to be making waxing and applying a polymer the same thing; they are not. Yes, they are both protectants applied to a vehicle's exterior, but that is about as close as you can get to using the same words to describe both. Waxes, most of which are carnauba, adhere to the paint surface and can be fairly easily removed; polymers chemically bind to the paint and, when cured, are much harder to remove. In discouraging the use of wax and recommending applying a polymer, they are being consistent, though self-serving in citing their product. Perhaps their mistake is in using the words, " ... urge to wax ... " being met by applying their product, when they probably mean something like, 'we don't recommend waxing, but if you feel you have to do something rather than accept that the product can be left alone, do this ... ' and what they recommend is not waxing. What a co-polymer is, I don't know either, perhaps it is a combination of a wax and a polymer that provides the long-term protection of a polymer with the short-term shine of wax.
Most so-called carnauba waxes contain polymers as well. Yes, there are differences between products but to make such a dichotomy out of it is marketing (on both sides) IMHO.
As far as the term "waxing" goes--that is just the term people use for putting some kind of protectant on their vehicle....to make a big deal out of the semantics smacks of marketing, also.
the other day. After looking at the ingredients I concluded there were abrasives there. That's probably OK but I would prefer to work a little harder and not use them. I instead bought another bottle of then #7 glaze. I am doing a '92 Corsica that was repainted a couple of years back with a quality paint job. I just did the hood this morning with the #7 and 2 coats of #26. Looks like a mirror. I really feel pity for those that go to Kmart for their Turtle Wax, etc. (That would have been me for about 40 years of car polishing)
I had always believed that Imperial Hand Glaze contained very mild abrasives--until last year when I saw a post on another board where some guy e-mailed the head of the car care division for 3M and the person e-mailed back that there were "no minerals in Imperial Hand Glaze", i.e. it was not abrasive.
However the 3M Canada site has MSDS for 3M products--here is the MSDS for Imperial Hand Glaze:
But thanks for getting back. I looked on the bottle of the 3M and drew the same conclusions. So as I said went with what has worked for me. There's always the urge to try something different even if it works for 'ya. (probably why there are a lot of divorces). I was looking at trying the One Grand or Collinite 476(or other Collinite) next. Your thoughts??? Thanks
This is hard to believe, but the peanut butter worked so well restoring the black color to my sons rubber/plastic door handles on a Cavalier, I took the plunge: The black plastic cover that hides/protects the wiper mechanisms in front of the windshield of my '92 Corsica looked so ugly with wax residue, fading, etc. I decided to use Crisco Cooking oil on it. Its unbelievable-it looks like new. Its really too good to be true-I think I am dreaming. Its hard to believe no one has mentioned this (that I have seen). I suppose I should have pattened it!!!
Good job with the cars. I have a question - did the PB and the Crisco actually remove the wax and residue? If you washed off the parts will they be totally clean of wax?
It actually removed wax and also the paper towel got a lot of black on it. So it evidently removed oxidized plastic/rubber. I am going to go over it with Vinylex as a protector. I'll keep you posted. Nothing I haver used has come close.
Yeah it did the same to me--"forbidden"--apparently you can't link directly to it...here is another page that links to it though, if you are still interested
I have used One Grand products--Blitz Wax and Omega Glaze and they are very good. Blitz Wax is a "carnauba wax" and lasts longer than most such products and looks great--a very popular product. Omega Glaze is very similar to 3M IHG in my opinion.
Collinite:
Have never used any of their products, which is a little weird since they are located rather close to me in Upstate NY (Collinite is made in Utica, I believe). The body shop supply stores around here sell the Insulator Wax, which is essentially a polymer sealant, a good product and very long lasting, from what I understand. They also make a carnauba-type "wipe-on, wipe-off" wax which I have heard people speak highly of--can't remember what it is called... "Concours something-or-other" I think .
has anybody used a product called race glaze. this past summer here in louisville we had the street rod nationals. i seen alot of the street rodders and custom cars using this product on there cars with very nice results. there were alot of very expensive paint jobs and many swore that this is the product they use and trust. i have purchased a bottle of this stuff and plan on using it in the near future. has anybody else used this race glaze?
Is this stuff really thick? Does it have some cleaner or mild abrasive in it that removes oxidation and dead paint? If so, I've used it. On race cars of all things.
Does the product have a mfr name or website on the label?
3M hand glaze definitely has some abrasives. Glaze's purpose is to clean and polish. Imaging trying to clean off backed on crud on a pan without using some type of abrasive. I'll take a scrubber everytime over a disrag on that situation. Glaze is the same the very slight abrasives remove pollution and dirt.
If they were the same why would Perfect-It Show Car Wax instructions advise glazing first and then waxing? It is actually the mild abrasives that give it the deep wet look finish.
Imperial hand glaze does contain silica particles, but they are very small. Nothing like a swirl remover or rubbing compound. Meguiar's #7 Show Car Glaze is milder. It uses clay as the abrasive. This breaks down with use.
I found 3M glaze to be a little stronger than Meguiar's, but this only helped buff down scratches and swirl marks on an older car. This is a highly recommended glaze, probably the one must often used by professionals.
For waxes after you have glazed, use 3M Perfect-It Show Car Wax, Meguiar's #26 hard Yellow, or Collinite 476. Of these Collinite 476 claims to last the longest (1 year), then 3M (6 months). Meguiar's doesn't put a time on their products because they say conditions vary widely (true).
I really like 3M for winter use, and Meguiar's #26 for summer.
Also, if the surface is glazed, it uses much less wax. I have a can of Meguiar's #26 paste that has been used over 25 times. Dosn't have much in the can, but I can still get another 2 or three uses before it's gone.
I have and use Marque d'elgance carnuba wax from Collinite. A paste, easy to put on and get off great shine. Seems to last about as long as any carnuba product but I still use it for doors and sides of vehicles but I have switched to a polymer for the hood, roof and trunks and this combo works great. Actually, not sure if I will purchase a carnuba in the future as the polymer is really incredible but I have a supply of Collinite, and # 26 to use as well.
as is 3M Perfect-It Show Car Wax Paste. That's how they get their durability. In the shine department 3M Paste is every bit as good as Meguiar's. I'm still testing durability.
The #915 Marque D' Elegance is a high Carnauba.
My guess is those who want a good shine and durability should use the Collinite 476.
I use Meuiar's products but find I get finger prints on the car finish too easily. A day after I cleaned the car (waxed about three days earlier) I opened my trunk and when I closed it I could see a mess of prints. After a wax job would using the final finish detail spray have stopped this?
I have been using Mothers cleaner/wax for years and it works well for me. My question is can I add another layer on top of the cleaner/wax, like this 3M Show car wax or the #26. I am looking for a great shine on a red car. I am not concerned about durability becasue the car is always garaged.
Switch to Meguiar's #26 Hard Yellow Wax with Carnauba. I notice finger prints only when I'm buffing and have residue on my fingers already. It's hard and no finger prints are left when fully hard by the nexst morning.
Any cleaner wax is too soft and not durable in my experience.
Naah? do the job the right way and it will last even longer.
I did a cleaner wax then put on Meguiar's Hard Yellow #26 for years. Lasted about 3 months. My cars are outside.
This year I abandoned the cleaner/wax and used a glaze then the Wax. It's lasted 6 months and still looking really good. The Meguiar's #26 still beads like new on 2 of my cars.
If you want to put a wax on top of a cleaner Wax use Meguiar's only. 3M contains polymers and needs to bond directly to the paint surface. They recommend using a glaze first. I did Imperial Hand Glaze. Then I put on the 3M. It looks like it will be very durable. My Dark Red Mazda has the deepest shine it has ever had.
I have just bought my first new vehical (2001 Dodge Grand Caravan Sport, Silver). Since I have never owned anything new, I wanted to know what is the best Wax/polish or process for my new van. Also what is the best tire dressing. After reading a few posts I have seen 3M and Meguires, or Zymol as the best- I have used Meg Cleaner/Wax for many years and have been moderately happy, but after reading I now know there is better, What is everybody's suggestions. (Of course there is always the Z and I am still considering that). I am looking for the most durable and best shine.
about nine months ago with my new vehicle. I immediately polished it with a K-Mart cleaner/wax. (real bad idea). However after reading these posts I applied the Meguiar #26 Yellow (Didn't use a glaze-bad Idea) But I guess the K-Mart stuff did enough cleaning that the #26 looks great. I keep giving it another shot about once a month (overkill). You'll never get the absolute best product recommendation here. The fun is to try something and getting the experience. Good glaze and a good wax-you can't go wrong (IMHO).
I went horse riding in Bryce Canyon last Saturday. Had to relieve some tension. The Peekaboo trail is an incredible ride.
Anyway, back on subject. I drove the car with 3M Perfect-It Show Car Paste, and it got caught in a rainstorm. Now desert rains are really dirty. They usually leave a white residue on any surface. But this time the drops just flew off of the car. When I got up the next morning, expecting to have to do a Quick Detail, all I had to do was run the California Duster over the surface.
PS. I've washed it three times in the carwash and it still acts new. This finish appears to be both beautiful and sturdy.
Quite often they are contrary principals. Armour All makes a very durable wax according to Consumer Reports, but the shine is poor.
Since it's new, the first thing I would do is use a clay bar. Even shipping here from the factory puts pollutants on the paint surface. One of the most common is small iron particles from train rails. If they are not removed they will surely damage the finish. I have used Mother's, Erazer and Meguiar's. Quite frankly they are all good. I use a number of quick detailer type products as a lubricant.
If you want durability avoid a cleaner/wax.
I have experience with Meguiars and 3M product lines. Both are generally very good. Meguiar's uses more natural carnauba. I would recommend using #7 show car glaze then #26 hard yellow, both liquid and paste. Use a buffer (Meguiar's soft foam recommended over the stock applicator pad with terry cloth) to apply the liquid, then put a coat of the paste over the tailgate, roof and hood. In late fall I always add another layer a week or 2 later of the paste. This works well with an occassional automatic car wash. But I can wash on warm days here even in January of February.
I do the same with the 3M Imperial Hand Glaze, and Perfect-It Show Car Paste. The liquid doesn't have the ASE additives that make it durable. This one seems better if you waste your money and use automatic car washes more often. (Cringe).
Neither one of these lines will cause streaking, clouding, or require a long time to dry.
Using a Garage in any climate is much more protective of any car finish than being outside.
I just purchased my first one. It rained the other night. I really liked the fact that many of the rain stains and dust came off when I dusted it after the car was dry. I looks pretty good without washing.
I know understand what they mean by OCD (Obligatory California Duster)
I used to use Nu Finish simply because it is cheap and highly rated for protection and being long lasting. However I decided I wanted a little better looking finish. I found at a gooid price (16 bucks for 2 bottles) Zymol Cleaner Wax at Costco and have used it on 2 trucks. A 97 Dakota in Brillant Blue and an 01 Dakota in Flame Red. The Zymol did a good job and I am happy with it. One of my requirements is a single step producty as I am not going to spend all day waxing a truck. The Zymol works well. It may not last as long as the Nu Finish but the shine is visably better.
you would be surprised how little time it takes to put on a coat of wax after you apply the glaze. I can go to the carwash, spend a little time getting the flydirt and stains off (half hour) and then wax in about an hour. Plus this job is (IMHO) a lot better looking than the one step product. I guess it all depends on what you are looking for in the final product.
Let's say i just want to keep the car looking pretty good most of the time, but my main concern is having the paint look great for a long time. I'd like the car to look for for 10 more years, say.
Here's my current system :
* hand wash every weekend unless the car looks particularly good, or particularly awful. * wax with the cheap zymol cleaner wax every month * dawn wash, glaze, wax, every 4-6 months * clay the car once a year, previous to glazing.
I know i could do much more work and improve how the car looks, but i have limited time to devote to keeping the car looking good. Ten better looking is not worth double the time to me, nor several times the money.
I tried the forbidden stuff, and i was unimpressed.
I am wary of nu-finish because on non clearcoated areas it seemed to remove considerable paint.
I avoid glazing too much because it is a mild abrasive, and i worry about the clearcoat getting worn down over the years.
Sounds fine, you do put quite a bit of time into it though. As for the forbidden fruit,.well, one thing it has over all the products you mention is durability. Hands down. I use it on all roofs, hoods and trunks with #26 or Collinite on the doors and side panels. Shine similar but Carnubas have no durability!
It has to be a balancing act. Waxing once a month seems overkill. You have a good wax, and it should last at least 3 months. Zymol is a good product, and it should last that long unless you put it in a carwash every week. Maybe use a spray quick wax between to save time.
I totally agree about glazing only 2 times a year to preserver the finish.
I'm sure some of this is answered in here someplace, but can't read anymore.
1) What about automatic car washes in between waxing? Do you do just the car wash or let them put on the extra clear coat protection and waxes? Since I cannot hand wash in my neighborhood are automatic car washes better or worse than the local bay and power wand?
2) A friend has acquired a fairly oxidized maroon car. Which is considered best in this situation, clay or a liquid cleaner, such as the meguiers?
1. Stay away from automatic car washes if at all possible. They'll only damage your paint. And the crud they spray on it is a waste of money. What's wrong with the coin-op joints? I've been using them for years. Still do as my area is on water restriction and I cannot wash my car at home. I use all the same tools and stuff and bucket wash as normal. Just be careful with the high pressure hose.
2. Oxidation will take some work. If you're doing this by hand then start with clay and go to a fine cleaner like Meguiars Fine Cut #2. The car may need two applications to cut thru the oxidation. Follow up with a swirl mark remover or glase, then wax. I'm thinking 3-5 steps minimum. But the best method is high speed polishing by a pro. The heat from the buffer works wonders with old paint. But leave the polishing to a pro. Your arm will thank you.
Collinite makes a sealant that is designed for automatic car washes. I haven't tried it so I don't know how it works, but if it's like other Collinite products it will be good quality.
Car wash preference for me and reasons are:
1. Hand wash. This is be far the least expensive option and will get the best results. For 5-7 bucks I can buy a years worth of Auto soap. The water use is minimal if you use a nozzle that can be shutoff when using it. With experience, it takes about the same amount of time. I use this method 90% of the time.
2. Do it yourself car wash. This method allows for good control to clean what's needed. If the car is extremely dirty, preferred. I also use this when temperatures are a bit colder. I prefer the ones that have a hand brush. I can get this done for about $3.00 if I hurry.
3. Automatic Car wash. Often use recycled water. Fine in summer, but salts may not be filtered out in the winter. When it is sub-freezing this one has to be used be cause it can be washed, machine dried, then hand dried before being sent outside. Undercarriage washes also help remove corrosive salts. But this can be very expensive.
Wax on any automatic is no substitute for a good machine or hand applied one. It may help a little between applications
fastdriver
Protege_fan
Anyway about the 3m STUFF???
http://multimedia.mmm.com/mws/mediawebserver.dyn?oooooo3oKupVjt3oMdppJVJq1&C_hUw5xtpokva--
The MSDS states that Imperial Hand Glaze contains 1% to 5% "ceramic materials and wares" which I would take to be abrasive--then again I'm not sure.
http://products.mmm.com/ca/en/MSDS/searchResults.jhtml
Hopefully that will work or try:
http://products.mmm.com/ca/en/MSDS/msdsSearch.jhtml
and just type in "Imperial Hand Glaze"
Collinite:
http://www.bmwz3.net/seriousz3/astro.html
PS, the Z3 mentioned here is a BMW car model, not the verbotten product.
However they didn't check out the professional lines of products like 3M Perfect-It Show Car Wax, and Meguiar's #26 Hard Yellow Wax with Carnauba.
I'm with ADC100. Much more durable if you use a glaze and then a wax separately.
Does this seem reasonable to the pros?
dave
