A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Store Bought Waxes Part II (No Zaino Posts)
1222325272877
  • mrdetailermrdetailer Member Posts: 1,118
    It would have to be a RED. My Mazda had a similar problem.
    You won't be able to get a good job yourself without a random orbital buffer. Trying this by hand will not produce satisfactory results.
    Bretfraz gave good advice, but I took a slightly less intrusive approach. I used Meguiar's chemical scrub then then a swirl remover. The scrub wil not work on any surface with cracks. That will take off the paint. I felt that this approach would take off less of the clear coat.
    I really like his idea of using a professional to remove the initial oxydation if you can.
    The main thing that I wanted to add was that at this point you have a delicate clear coat surface. Once the initial surface is restored use less abrasive cleaners. On my formerly damaged surface I never use a cleaner wax. It brought up pigment with every wax job.
    I don't use anything stronger than glaze. I use that twice a year. 3M's Perfect-IT Glaze for Dark cars is a bit more expensive, but it's the best for reds. 3M Imperial Hand Glaze and Meguiar's #7 Show Car Glaze are also very good. I also don't apply a glaze on this car without using a clay bar first. This removes the pollutants that can scratch the surface more. Some color will always come up when you glaze.
    That's why regular applications of wax become crucial. Use a pure waxing product. Meguiar's #26 Hard Yellow Wax with Carnauba is very good. I apply a liquid coat, then wait a couple of weeks for it to cure then put on a paste coat. This combination on 2 of my cars has lasted over 6 months in the summer.
    But on my damaged surface I have found 3M Perfect-It Show Car Wax not only provides the great looks, but seems to keep oxidation out better. I just started using it on this car so I'll know for sure next spring. It advertizes 6 months durability. The way dirt and water fly off, I believe it. I just put on my second coat, and the depth of the shine is as good as anything you'll see at a car show. If ordered directly from 3M it is a little bit softer and easier to apply by machine. Even with the machine, I just do a section, like the side, the hood, roof or trunk. If this stuff sets for a long time it is real work to rub off, otherwise it is easy for a paste.
    I also understand that collonite #426 is very durable as well.
    And NEVER use anything other than 100% cotton, or the new Microfiber cloths designed to remove waxes or glazes from car finishes. If it's like mine the clear coat is more sensitive.
  • urchin34urchin34 Member Posts: 70
    1) Yes, it had to be red!!! When you mention a "pro" are you referring to specialized detail shops, or just the local car wash? Last time an orbital buffer touched my car (local car wash) it took me days to undo the damage. Since then I have been afraid of anything but my own two hands. And that was just plain old white.
    2) Is there a difference between glazes and polishes?
    Yes, a "pro" is someone who details cars for a living and has the talent and expertise to do the job right. Ask around for a referral to a good detail shop or mobile detailer. A real detailer will charge $75 or so to do an exterior detail.
    A glaze is a fine polish that remove or fills in spider webbing and buffing marks. Most glazes include emollient oils to feed the paint and bring out the gloss. A glaze is the last step before applying wax. Glazes have no protective qualities and they can wear off within days or hours if not covered by wax.
    So glaze is a subset of "polishes". Polishes run the entire gamut of products from mild to wild.
    A body shop professional who uses an orbital buffer, rather than the random one that I only dare use, will be able to get the finish better.
    Polishes? Modern marketing has confused it almost completely. That's why I look for glazes.
  • protege_fanprotege_fan Member Posts: 2,405
    Is there any wax that is best (most durable, etc.) for harsh winters with lots of road salt? Are there certain types of "waxes" that should be stayed away from because they aren't able to expand/contract in the winter well? Thanks in advance.
    Protege_fan
  • adc100adc100 Member Posts: 1,521
    Im going to purchase the Collinite 845 for use on the Sentra. That's the wax developed for high voltage insulators. It is a liquid though. I have seen in other posts that indicated it is very durable. Perhaps someone can shed light on this. Wish I could buy it local (Harrisburg, Pa)http://stores.yahoo.com/autofanatics1/collinite845.html
    Yeah, I've never seen Collinite in any stores here in Calgary, Canada. Is it mail order/internet order only?
    Are there any opinions on Nu-finish? Is it suitable for winter use?
    Pro_fan
  • armtdmarmtdm Member Posts: 2,057
    I used it for several years, very durable, polymer. Shine not great but durable
    Now use the product that cannot be mentioned on this board plus # 26 and Collintie for side panels. Nu Finish is fine if you want durability only !
    Yeah, for this winter I don't really care about shine. I just want my paint protected against the harsh conditions up here!
  • dhanleydhanley Member Posts: 1,531
    I'm a bit leery of nu-finish.
    I use nu-finish on part of my car that is NOT clear coated ( inside the engine bay ) , and a substantial amount of color was on my rag after i was done.
    I also did part of a friend's car that was HEAVILY oxidized and had no clearcoat(left?) the nu-finish made it look really amazing--glassy and smooth--but again, a lot of paint came up on the cloth. Aside from that, it was like the amazing TV ad. Wax alone didn't come close. If i had done his whole car, it would have superficially looked new.
    I am leery to use it on my new(ish) car with clearcoat though, i worry about it eating away the clearcoat over multiple treatments.
    If i had an old car, heavily oxidized, not shiny at all, i'd try it though, to restore the paint.
    dave
    Besides the price, what is the difference between the Meguiars 3 step "Deep Crystal" system and the more expensive "Professional Mirror Glaze"(that is the 7, 26, etc.)? The Deep Crystal wax claims to be the most durable on the market, but the #26 makes no such claim.
    Also, if I can't use the #26 on plastic parts, what do I use on the plastic bumper painted the same color as the car?
    It's prolly best to ask Meguiar's directly as they know best. But in general, Meguiar's products in the burgundy-colored bottles are their "consumer" line. They are widely distributed and are aimed at casual consumers who shop price as well as quality.
    The "Mirror Glaze" line is targeted towards professional detailers and serious enthusiasts. The products are more specialized and results-specific. Mirror Glaze users are more concerned with effectiveness and results than price. Distribution is limited and focused on the trade. The best places to find a wide selection of Mirror Glaze products are at body shop supply stores.
    Finally, you can wax "plastic" but use good judgement. For example, if your car has bumper covers painted jsut like the body (same color, same gloss, looks just like the body but made of plastic) I see no reason they can't be waxed. It is plastic parts that have no gloss and have a texture that you can see and feel that cannot be waxed. Stuff like body cladding on a SUV cannot be waxed. Best thing to do is use tire dressing on cladding.
    I have used both. The #7 may be the deciding factor though. Perhaps the #7 and Step 3 Carnuba would yield the same results-but since the #26 works well why bother. You could experiment a little to find out if you are so inclined and don't want to waste the 3rd step carnuba. I use the remainder of mine on wheels and bumpers..
    bretfraz/mrdetailer: I did finally buy some Perfect-It instead of the Collinite (the insulator stuff-= 485, I believe) because it was available locally. I'm planning to use it on my red Toyota as mrdetailer suggested for red. I'm anxious to comare durability compared to the #26.
    Really should have used a swirl remover before the #7 though. But hey-its only a truck!!
    First, I have to say that it is truly amazing what today's products will do.
    We started with the dawn/clay/dawn routine. Next came Meguiars clear coat body scrub, which actually was quite amazing. Next, we applied Meguiars step 2 polish with a combination of very careful hand polishing and a random orbital buffer. Next came the step 3 carnuba wax. This was all with the cheap "consumer oriented" stuff from Checker. Finally, last night we decided to put on another wax layer, using the Meguiars #26. It was a great final step. I swear it looks new.
    Two of the guys in neighborhood were so impressed with the change they were seeing in this '91 "clunker" that they offered to clean windows and detail the interior. Then they took the two "chicks" working on it to check out new hubcaps. Who knew that waxing a car had such wonderful side benefits? Next week we tackle one of the guy's '96 oxidized silver job. The new neighborhood entertainment!
    I know you could see the difference. Its a great product.
    Did you use the paste? You'll find that as you use the #26 you learn to let it dry just the right amount of time before wiping it off. Under most conditions its under 5 minutes. If you let it on even a couple of minutes too long you tripple your work.
  • rayfbairdrayfbaird Member Posts: 183
    Be careful, or soon you'll have a shelf of different products like I do.
    Meguiar's is the only car care line where I have a fair degree of experience not only with the consumer line, but the Gold Class, and the Professional line. Here is my opinion based on my 5 years of experience.
    1. The clear coat body scrub is excellent for neglected surfaces. I used it twice, then use the glazes and waxes after that.
    2. The consumer Deep Crystal produces a nice shine, but to me puts on thiner coats than the other lines.
    3. I like the gloss on Gold Class, but not the durability.
    4. I now only use the professional line, not for looks, but because of durability. My car that was waxed 5 months ago with #26 is still beading well. If I used Deep Crystal they lasted about 3 months before loosing beading.
    Rewaxing in about 2 weeks with #26 after allowing the recent finish to cure and fully harden greatly increased durability.
    Yes, I have been bit, but bad. Today I did the SUV, and as I was sitting between two little two seater sports cars at the vacuum, I wondered why I ever bought this thing. So of course, I had to figure the quickest way to do this job. I ended up with the Meguiars #6 cleaner/wax. It was fairly easy, but can't say that I care for the results - it seems oily. Can I also go ahead and put the #26 over this a couple weeks down the line?
    Sure. It's compatible. I like to do one coat with #26 liquid by machine. It gets into the scratches better, and helps smooth the surface. 2 weeks later I follow it up with a hand application of #26 paste. This is the combination that increases durability the most in spite of what others say. And it uses very little of the paste. I've used mine for over 15 coats and may still get another 2 out of it before the can runs out.
    If you've been bit bad like me you have to watch the car care budget.
    Used the Perfect-it, just to try something different. I thought it left a nice shine. (Used it on top of the the #7). Although it was easy to remove, it seemed that it never totally dried and left a very, very light oily film. Thought maybe I didn't let it dry long enough so today I let it dry about 1/2 hour (temp- 55 degrees F). Still somewhat of a film left. The reason I can tell is that when you go over it with a rag, you can see changes if the sun is reflecting. Just curious.
    urchin34: I used the #26 over the Meguiar's cleaner/wax (not the #6 but the Walmart level stuff) it worked fine and gave a deeper shine.
    At this time of year if you do small sections it's Ok to do in the sun. It worked well at about 65% on my Dad's car yesterday. It must be powdery.
    This is pretty common. Try spraying a little water on your car and wiping it off with a clean towel.
    So are all random orbital buffers essentially safe? Any favorites out there that are fairly light and not too awkward to handle?
    I posted some detailed info on buffers in here previously. You may want to search back for those posts.
    Orbital buffers are safe to use as long as common sense is applied.
    I read your post this morning and called 3M technical support. They said that 2 things could have caused this: too thick of a coat, or not drying enough before being wiped off. They also recommended terry towels to wipe it off.
    I'm sure that temparature, and humidity would affect it too. With our 25% humidity (no significant rain for 6 months) it dries pretty quickly. My biggest problem was getting it off after it dried hard. It took a lot of elbow grease.
    I did a second coat on my Dad's dark green Taurus this weekend. The car looked really good before, but great afterward. And there are absolutely no swirl marks.
    I have tried 3-4 different types over the years and I found the following. Any buffer that runs off of the car battery is junk. It takes too long with a 4 inch pad. 9 inch pads make the work go very quickly. If a lot of stuff comes up on the pad, change the terry cloth quite often. (I haven't tried the new soft foam ones yet, but I'll be the terry cloth are easier to clean.) Work quickly. Even on bad spots don't try to linger. You'll get swirl marks if you do. I just go forwards and back twice on each area. Do a quick coat and then go over it again a second time.
    Hand coats can be nice, but for real beauty nothing beats a good buffer. It also applied very quickly.
    I use the mid grade Sears that I got on sale for about $70.00.
    Thanks. I probably just did not let it dry enough. In fact after talking to Meguiars, they told me that I probably am not letting the #26 on long enough. To impatient-thanks again.
    I'll bet a quick spray and wipe with Final Finish, or Quick Detailer will clean up any excess.
    Worked lots better. Any direct comparison between #7 and Imperial Hand Glaze? The #7 does a nice job, but it doesn't remove fly dirt and has a tendency to get blotchy if you work it too hard. I'm thinking I finally need to use a buffer. I'll go back and read previous posts on these.
    http://www.carwash.com/article.asp?IndexID=6631154
    This was mentioned in post #826 by Bret.
  • bluong1bluong1 Member Posts: 1,927
    Hi all,
    I'm new on this board. I had a problem and a friend suggested me to submit it to this knowledgeable discussion board.
    Last Friday I took my 3 month old yellow Mazda Protege5 for a 140 miles trip to Lufkin, a town located in the North side of Houston, TX. At one point I followed a small truck, and I notice something hitting the windshield, probably falling from the truck, but nothing was broken and everything seems to perform normal. I did my 102 miles camping/biking trip Friday and the whole Saturday in Lufkin area and get back to Houston late that night. Sunday I took my car for a wash, and then I noticed there is black paint spray all over the hood and and the right back door of the yellow Protege5! One have to get close enough to see them, but still I'm really mad! I tried to remove few large spots with my finger nails with care, and they seems to come out. The yellow paint is very fragile (I got 2 scratches on the hood from small flying stones), and there is a rumor that Mazda had problems to make the yellow paint sticking strong enough to the body, and hence the yellow Mazda cars are only available in limited quantity. So my question: is there any way to remove the black paint spots while minimizing the dammage to the original paint? Thank you very much for your help.
    Bruno
  • joe166joe166 Member Posts: 401
    can be removed lots of different ways. You should always try the least obtrusive way. First try some very mild solvent like alcohol. If your yellow paint is at all acceptable it won't come off with any mild thing like alcohol, but try it in an inconspicuous place first. If it starts to come off with an alcohol rag, run, don't walk to your dealer and demand they do something about it. It shouldn't come off with that. If that removes the paint, fine. Then renew your protectant package (wax or polymer or whatever you use) since alcohol removes most protectants. The next mildest (to my limited experience) is claying the car. They sell clay in any auto parts store or larger auto departments (Pep Boys, Discount Auto Parts, Autozone, Target, etc). This is a fairly simple procedure. If that doesn't remove it, you need to try a mild abrasive, there are many and I am sure you will find lots of brand names in the prior posts. Just remember to be careful as you are removing the good with the bad and if you aren't careful you might take all of your clear coat or top layer of paint off. I have never had to go beyond the clay. Read the instructions and go for it. I have not used an abrasive on my new car and in fact haven't used one on any car I have actually owned in years. I did use a polishing compound on a rental car that someone redecorated for me in a large parking lot. I didn't want to pay for the repairs and especially for the loss of revenue while it was in the shop and I was able to remove some foreign paint applied by another bumper fairly easily with little effort. I would hesitate to do this to a large area of the car as I really don't trust myself with a buffer and I sure wouldn't want to do the neccesary labor to do it by hand. Try the alcohol and the clay, otherwise take it to a detailler. If they rub through the high point of your paint they will fix it. If YOU do it you pay for it.
    Thank you Jose for your detailed and excellent reply. I'll try to fix the problem step by step just like you suggested, starting with the alcohol. I'll let you know the outcome.
    Cheers,
    Bruno
    This is a clay bar issue. Despite my best efforts, when I repainted my windshield wipers there was some overspray that I hadn't noticed for 2 weeks. The clay bar took it all off. See my later posting in more detail.
    I thought I would like to share my last few years of experience with clay bars and quick detailers. They are related since the quick detailers are used as a lubricating agent for the clay bars.
    Clay bars can actually be purchased in different grades from auto paint supply stores. The type I am speaking of here is the mildest one -- the overspray remover. These were originally designed to remove the paint airbrush slopover when a car was repainted. However detailers have used them for years to create a mirror surface before a car show. It has been found to be the only efficient way to remove pollutants from a paint finish such as sap, bird droppings, rail dust, sand and salt that have embedded into the paint finish. They have only recently become popular for consumers.
    I have used these clay bars.
    Meguiars Body Shop Professional Overspray Clay. This is a white natural clay. It stretches fairly easily once warmed in the hands, shows the accumulated dirt well, and is easy to fold in and expose a clean surface.
    Meguiars Clay Bar with a Quick Detailer Kit (Autozone $9.99) Frankly it looked and performed similar to the professional overspray clay. There was no appreciable price difference. The only real disadvantage was that it was impossible to see if used on a white car. This is the least expensive all-in one deal.
    I purchased Mothers California Gold Paint Saving System ($19.95). It had not only the clay, but Mother's Showtime Instant Detailer, and a small bottle of Mother's Cleaner Wax. Luckly it was a bright yellow color. This is clearly an artificial clay. It has a definite plastic texture. This is harder to warm up. Sometimes it will strink after stretching, so make it a little larger than you want and you'll be happy. It is not quite as easy to fold into a clean surface as the natural clay.
    Erazer Surface Cleaning Material. This had a good cost advantage. From www.autofanatics.com for 17.95 you can purchase a kit that has 2 bars instead of the 1 bar Mother's came with, along with 16 oz of the Lubricating Agent and Gloss Enhancement Spray and 4 ounces of Acrylic Paint Protector. Its look and performance were identical to the Mother's Clay. The kit form makes it very economical.
    In order for the clay to work correctly it has to have a lubricating agent. Some use Soap and water, but I use Quick Detailers for consistency and ease of use. Here are the ones I used when claying.
    Meguiar's Quick Detailer, and Meguiar's #40 Final Inspection. The Quick detailer has a wide spray on the bottle. This was the best for applying before rubbing the surface with clay. Quick Detailer does contain a little carnauba wax, Final Finish does not. These two are characterized by their "high lubricity" to use Meguiar's words. They appear to be more slippery and consume less product. However, they are also a little bit harder to get a dry surface when wiping. Both have a nice, clean smell. Shine is excellent. Meguiars does not use silicone.
    Mother's Showtime Instant Detailer. This had a standard spray bottle, and was not as slippery as Meguiars. This honestly was not a problem until running into trouble areas. Then it consumed a lot of liquid to get the surface clean. Mother's wouldn't disclose whether they used silicone or not. Application of waxes after using it has not been a problem.
    Turtle Wax Bug and Tar Remover, and Emerald Series Permium Detailer. The first product removed bug stuff pretty well, Tar, not so good. both work fine as a lubricating agent.
    Erazer Lubricating Agent and Gloss Enhancer spray. This is the one that stands out of the crowd for me. On a dirty surface this cleans very quickly, dries easily and leaves and excellent shine. Slightly better than the others. The lubricating agent contains more alcohol so it dries quicker. Just work a smaller area at a time. This is very easy to dry the surface with this agent after using the clay.
    Bottom line. Generally all of these products worked well. Rough surfaces, sometimes after years of neglect, would again become showroom slick and mirror smooth. The differences between the products is not significant enough to worry about, it's rather a matter of preference and cost.
  • bigcompactbigcompact Member Posts: 33
    Well, since I live in an apartment, washing will have to be done at a coin-op a couple miles down the street. Then since the car is both black and new, I have two reasons to not use a glaze/polish before I wax if I don't NEED to. And since I live in MA, we are running out of weekends warm enough to do this kind of detailing.
    So far I have purchased Meguiar's #26 liquid, cotton terrycloth pads (applicators) and 100% cotton terrycloth towels for buffing/removing wax.
    Washing the car thoroughly at the coin-op (which i have been doing every week anyway, so it's pretty clean already), drive it home, dry off whatever is left, and then hit it with the liquid #26.
    Thoughts on this?
    BTW, if anyone has ideas on additional steps, keep in mind that the selection of QUALITY waxes/polishes/glazes at the local Autozone is limited to mostly Meguiar's stuff.
    Oh, and protection is definitely more important than shine.
    Thanks in advance for the advice.
    Problably in MA there will be a season where it's too cold to wash properly. To get Max protection, after a week or 2, put on a coat of #26 PASTE over your liquid coat. If you apply the paste by hand that can will last a long time.
    I have car where I did this treatment almost 7 months ago. It rained hard yesterday. It still beads as well as the car waxed just 2 weeks ago. If I just did the liquid it generally lasted about 3 months.
    From what I've read, you and that Bret guy seem to really know your [non-permissible content removed]. So, just for the sake of satisfying my own curiosity, why is it recommended that you wait 2 weeks or so for the recoat? Why not just do the two coats in the same day?
    Again, i believe you, i'm just the curious type.
    I hear ya, been there, done that. Still do it. Black cars, white cars, dark green cars.
    Here's what I do:
    1. Wash car with normal soap, mitt and bucket at the local DIY coin-op spray joint. Just like I'd do in my driveway if I had one.
    2. Dry there. Only prob I have with driving and drying is that you pick up any loose crud on the road before you get home. Instead buy one of those Calif Water Blades and/or an Absorber. Bring some cotton terry towels with you. Then dry as normal. The blade lets you squeegee off water and the Absorber.....absorbs. Finish drying door jambs, around trunk and hood, and the wheels with the cotton towels.
    3. Go home and wax there. #26 is good stuff but it doesn't have any polish in it. If you don't wanna do the "two step" then I suggest Meguiars Medallion. Prolly the most durable product they make. Has a light chemical cleaner in it. A great "one step" product. Remember to wax your car in the shade with the paint cool.
    Final comment - A glaze on a black car is the best way to bring out the gloss. No other color responds to glaze like black. I've owned several black cars and they've always looked their best when I've done the glaze/wax combo.
    What steps are good and which are bad/useless? I normally use the High pressure soap, followed by the foaming brush, finishing with the high pressure rinse. If i have extra time left on the clock, i'll sometimes use the teflon/wax spray. Before you say anything, i know that the spray wax step lasts a week at the very most. But i figure, if it doesn't HURT the finish, then why not?
    Anyway, are there any steps I am missing, or ones I should discontinue?
    Should I really glaze/polish a brand new car? Are (mild) abrasives a good idea at this point?
    Since 1993, 90% of my car washes have been done at the coin-op's. I've been living in apts or condos that don't offer car washing stalls. My current apt does but our county is on water restriction so the stalls are shut off. Ticks me off because one main reason I took this particular unit was its proximity to the washing stall. It's been shut off for over a year.
    Anyway, my technique at the coin-op is the same as my driveway. I bring a bunch of quarters and keep feeding them in. But I use car wash soap and a couple mitts and wheel cleaner& brushes. I never ever use their spray wax or that foaming brush. Nasty things, those. The goal is to gently wash the car. Just use the rinse mode.
    The high pressure is nice to blast the wheels clean and rinse of the engine. But I keep the wand 18" or so away from the paint. High pressure can easily damage your paint so go easy.
    The only allowance I make when bucket washing is I go to the coin-op when it's not too busy. I hate rushing thru my wash.
    On glaze, your car is definitely ready for it. It may look good now but glaze will make it pop. Glaze is a very fine polish that includes emollient oils to feed the paint and light fillers to hide swirl marks. Follow it up with a coat of #26 and you'll be amazed. I'm sure Auto Zone has Meguiar's #7 Show Car Glaze. That's good stuff. 3M's Imperial Hand Glaze is also a winner.
    You want the wax to cure and completely harden. Then it will put 2 separate layers on, and not mix. Just like floor wax. 2 separate thin coats are better than one. I've done both and found that waiting makes it much more durable. Especially if you can get it out in the sun to really harden.
    Bret is completely right. It's worth the effort.
    On your new car #5, #7 Showcar Glaze would be best for the first year or two.
    Well, looks like I'm heading back to Autozone. I actually debated buying the #7, but changed my mind. And if i'm really motivated, i may get the #26 paste to do a second layer.
    Thanks again.
    The 1-800 Meguiar guy indicated you could do back to back #26, But common sense says wait a couple of days between. I sort of compromise and go over it twice with about an hour in between. It takes so little time to do after its clean its not a big deal.
  • pjyoungpjyoung Member Posts: 885
    I mentioned in another thread that I had a product that beaded water after 6 months and was informed:
    ...all they were offering were their opinions and no one ever supported any of their claims with facts. All they do is throw opinion after opinion, and when they're pressed for proof, you get name-calling and more opinion.
    None of them have attempted any emperical testing
    I'm curious if you could post your methodology. Have a great day!
    Yeah, biased observation. I accept no less than top quality shine for my vehicles. I remember the other thread. Ridiculous standards. The fact that you had something last 6 months is completely believable.
    Some clearly follow an I have facts, you have opinions philosophy.
    Beading is something that I watch very closely. Any significant reduction and I rewax. In my view it's fairly obvious. Look at the car finish after a rain like I did yesterday. If I need a rewaxing that there is a visible difference in drop size. Ironically poorly waxed cars have smaller drops, and dry quicker.
    Do I put a uniform drop on each car weekly and measure the height and width of each drop to the utmost micrometer? Of course not. But my cars are outside in all weather so I watch it closely.
    I also notice the same phenomenon when I wash the car and then drive it. At about 55 MPH if the water beads, groups together and then flies off it's a good finish. If it drips off in sheets I rewax. I also rely on touch, shine and whether I need to get it ready for the long cold winter.
    I do try to wash weekly, by hand when possible, dust when needed, use a detailer to catch bird droppings, and water spots in between, and park in the shade whenever possible. The car that has held up so long is white.
    I do know that in prior years when I used a cleaner wax instead of a glaze then wax that this prime quality only lasted about three months. I've been a little frustrated with the longer time, but the wife likes it better. More time for the Honey do list.
    I hear ya Mr. Detailer. The one unexpected result of a longer durability is a longer Honey-do list. I suppose that's a common thing though...;>)
    I was thinking about trying out klasse at some time. What are the opinions of this? I like what they claim about it, but we all know how advertising claims can be.
    dave
  • protegextwoprotegextwo Member Posts: 1,265
    I tried Klasse for the 1st time, in early August. So far, I love this stuff. The first time I tried Klasse, I just applied the All-in-One and the Sealant to my spouses Protege, knocked the job out in less than 2 1/2 hours. My wifes 2000 PRO-ES looked sharp when I finished. The Klasse has held very nicely at the 3 month mark!
    I tried Klasse for the 2nd time last week. I was preparing "MY" 2000 Mazda Protege ES, for our 2nd Annual Edmunds Mazda Mid-Atlantic Protege Picnic. I really wanted my Protege to pop, so I went for my own version of a 4 step concour "Wet Look Shine", lol! The whole deal took me about 7 hours. However, this included a hand wash in my driveway, an interior detail (just a quick touch up) and a couple of breaks for lunch & dinner.
    Step 1-
    I glazed my dark Emerald Mica PRO-ES, with a hand application of 3m Imperial Hand Glaze.
    Step 2-
    A hand application of Klasse All-in-One. Very very easy. Apply a nickel size dab of All-in-One to a folded micro fiber towel dampened with a quick detailer. Wipe right off, no drying needed.
    Step 3-
    A hand application of Klasse High Gloss Sealant. Klasse is acrylic that bonds to the paint. Very, very easy to apply. Apply a nickel size dap of Klasse Sealant to a folded micro fiber towel dampened with a quick detailer. You need to let the sealant dry before removing. I let it dry before dinner and a hour, 45 min. later it was plenty dry. Wipe off with dry cloth, no heavy buffing needed.
    Step 4-
    My final concour move! A coat of Blitz One Grand Wax. This aplication of Blitz was for added depth and wet shine. Blitz One Grand is a tad easer to apply than Meguiar's Hi-Tech #26 Yellow Wax. Nonetheless, it seems that most hi-end carnauba paste waxes can be, somewhat of a pain in the butt to remove, hehe!
    Results:
    Awesome, well worth the effort.
    Respectfully,
    Larry
