Visitor Agreement.
BTW #26 Paste is on sale at Pep Boys... What a deal!! Even if you just use it on your shower.
Seriously, I'm very impressed. You've come a long way and it sounds like you're doing a great job with the Protege's.
Sounds like the folks on the Autopia boards have been offering you some great advice (as usual). Kepp up the great work.
- - Bret - -
-Larry
I like the fact that it is easy to apply, gives a good shine and is long lasting. One thing that I've noticed is that the car seems to stay cleaner - with wax you seem to get a static charge that makes dust stick to the finish.
I was impressed enough with Klasse to reorder when I finished my first bottle and I also decided to go ahead and try some of the highgloss sealant. I don't know that it's necessary as the all-in-one does pretty well, but we'll see.
I ordered by searching the net for the best price..
http://store.yahoo.com/klasseproductsdirect/klasalacpola.html
This is the best I've found, but I'd appreciate it if anybody knows of a place with a better price.
Only kidding about the shower. :-}
-Larry
I did take my last detail project a bit seriously. However, you only live once and I really enjoyed preparing my beloved 2000 Mazda PRO-ES for the Edmunds users Mid Atlantic Protege Picnic!
BTW, Autopia.com is a great place to do research, if you want to take your detail program and "Kick it Up a Little"!
http://www.autopia-carcare.com/
Be Well;
Larry
Al
http://www.properautocare.com/index.html
The Klasse Web page, were you have purchased Klasse: All-In-One, lists $20.00 for 500 ml. I was never good in math. How does 500 ml compare to 16 oz?
Nonetheless, I purchased the Klasse: Concours Kit for $39.95. With the Autopia Klasse Concours Kit, you get a 16.9 oz bottle of both, 3-In-One and Sealant, and two micro-fiber applicators. Hope this helps. :-)
Respectfully,
Larry
http://www.properautocare.com/klasconkit.html
That kit listed above is a pretty good deal.
dave
-Larry
I just waxed with Nu-finish and I'm a little scared now because we get some pretty good temperature fluctuations here in Calgary during winter (ie. -20 degress C one day, +15 the next)because of the Chinooks.
Thanks in advance.
Protege_fan
2. Break the bar in half. The boxes advertise that it can be used for 3 cars, but it is too small to use if only 1/3 is used. Flatten into a pancake that comfortably fits on your fingers. (A slightly smaller size makes it easier to find a clean surface.)
3. Spray the lubricant liberally on the surface. Honestly this varies depending on the condition of the paint. When I first did it I would go through a pint bottle. Now I can get 2 cars with the same amount. Spray the claybar itself also. You want a slippery surface. If you feel the slightest pull quickly spray more on the area. I use a rag to clean off the area where the clay stuck. It's the dull area. I literally have a spray bottle in one hand and the clay in the other at all times.
4. Use a circular motion. The pressure should be firm, but not too heavy. The bar should slide over the surface easily. Initially you will hear a light scraping sound like it's being sanded. As you go over the area it will go away. The first time I go over roughly an 18 inch square area. I then look at the clay. If it's black I fold it on itself until a clean surface appears. This can be done many times. Now for my twice annual clay bars I can go over much larger areas like half of the hood since it's so much cleaner.
5. After I've done an area the lubricant is cloudy. I wipe it off and feel the surface. If it isn't as smooth as glass, I re-spray and do it again. This takes a while the first time. Later sessions for my mid size cars take between 30 and 45 minutes if I hussle.
I never use a clay bar AFTER I wax. It is done before the glaze/wax.
Quite honestly, if the finish feels grainy at all I do a clay bar before I glaze, this helps minimize spider marks.
I thought I got good results with my car care before, but a clay bar adds another level of shine, minimizes scratches, and the surface feels mirror smooth after treatment. I will never be without it.
One thing I do is lay down an old blanket around the area I am working in. That claybar gets pretty slick with all the lubricant. Nothing worse than dropping your clay and getting it all full of pebbles.
Al
robr2. the blanket's a good idea. I had to throw away a clay bar because when I dropped it, there was a lot of grit in it. Then I can let it fall with impunity.
BTW my wife's friend has a scratch on her Toyota. How do those paint sticks work???
The bottle doesn't state how long it takes to "dry to a haze". I found out the hard way that this is more in the 5-10 minute range as opposed to the 1-2 minute range.
Also, keep an extra towel unused. When you have finished waxing and buffing the whole car, use this extra towel to get any spots you missed. I noticed a big difference in the finish after doing this. This step removed a lot of the swirls and spots left in the wax layer after I first finished waxing and buffing.
If your car is just dusty and not dirty, I'd clean it first with a product like Meguiar's Final Inspection or Quik Detailer. That will remove any dust, oils, fingerprints, and whatnot before you apply coat #2.
Towel Tip: go to an outlet mall and buy towels strictly for car care. if you wanna look cool, get them in black to match your car. Towels on sale from WalMart or similar are fine too if you have no outlet malls nearby. Wash the towels in light soap, no softener, no Cling Free's in the dryer.
Waiting period between coats. OK, truth out, I don't want to wax again just one week after I've done the prior coat. But if I did I would certainly wait a while. If it is not completely cured then you are removing some of the prior coat as you apply the new one. I like to make sure that the vehicle has been out in the sun for a few days where the surface has had time to essentially bake the wax. Overnight, or a few hours later, unless it's had a chance to heat up will not be as durable in my experience.
-Larry
I have a friend who only uses automated car washes. Never waxes. (horrors) He always uses the wax. It looks better than I expected. Not great, but could be worse.
zoom-zoom,
Bruno
The instructions recommended doing only a 2 X 2 foot square at one time. They are really correct. If you do too large of an area or wait too long is it a miserable cuss to remove. Not for Amateurs. If I hadn't have had a fair amount of experience I would have been major frustrated.
I REALLY liked the results however, so it's worth it for me. I had some small swirl marks from learning to use the buffers, and it buffed out a lot of them.
Give me the Imperial Hand Glaze for ease of use. And it looks almost as good.
dave
I tried that once but the topic got closed.
looks like the P21S Concours is the one i'll try next. claimed to live up to it's promises.
thx
-Larry
-Larry
I was all set to buy klasse. Now, i'm no longer so hot about it. So far, the cheap zymol ( zurtle wax ) has been the effective thing for me. The problem with this product seems to be longevity.
I do think they're doing exactly the right thing, doing one section of each on a large body panel.
I spoke to them over e-mail and they said they're doing a longevity test, and they're going to re-test the klasse and the Z.
dave
