Visitor Agreement.
To me the real issue for vinyl cleaners is cost. If it has inexpensive ingredients cracking can occur. The more expensive dressings use ingredients that help, rather than harm. I've become a real convert of the more expensive products. I'd rather pay a little more for care than to have to do another repair.
1) Looks
2) Longevity
3) Cost
4) Ease of application
5) How well it preserves the paint
There are good examples of each of these.
I use the cheap zymol($8). It does well in all of the areas except longevity, i think. I got it for $8 at costco. Its MSRP is $19.95, and i'd never pay that for it. If you don't mind waxing once ever y month or two, i think it's good. There are good and bad sides to this. You will keep contaminants off the paint more with a cleaner wax, but you will be rubbing it more too, and it will be more work ( although initial applications are easy ).
I have tried nu-finish($5) and it does seem to last six months, longer than anything else i have tried, but i worry about using it, because i did a section of the paint with no clearcoat, and it took up quite a bit of the paint. I did part of the inside of the engine bay. and the rag turned blue. I had a similar experience on a red car with no clearcoat--the rag turned completely red.
The meguairs stuff generally ($4-$15) i have thought well of, but i think it's harder to use than others, and it stains the black trim and gets caught in cracks easily, etc.
The basic 3m liquid wax seemed to have pretty good longevity, but it looked smeary after i took it off, and it dried very hard.
I hear good things about some of the expensive waxes, but in my mind, with things like wax, paying double seems to only net you a 5% improvement or so. The difference between a $5 and a $100 bottle might be only a 30% improvement in these factors... maybe... I think with equal attention and efffort you will NOT see a BIG difference in the results of the $5 and $100 bottle.
I think there is no replacement for using a decent wax, the proper techniques, and some elbow grease.
dave
Sounds like these folks really are trying to be as fair and objective as possible. Even if you don't agree with their findings, you NEED to give them "props" for trying!
I can't wait to see their results on Polymer Sealants and the Polymer vs. Carnauba Comparo. I believe they rated KLASSE a tick higher than Zaino the first time (before they regrouped & updated their site). I will check in from time to time. I think there whole premis is very cool. Bret, I hope that was articulate enough for Koury, hehe!
-Larry
I have found that any all in one produt that advertizes itself as a cleaner/wax, or polish/wax is not nearly as durable as a pure wax. Zymol and Meguiar's Gold class are cleaner waxes. Good shine, much lower on durability.
If you really want to take care of the finish use the clay bar, glaze and then put on a good wax of choice.
Your results may vary.
By comparison, #26 is a protectant only - no cleaner or polish. It won't remove water spots or anything like that. You'll need to use #7 Show Car Glaze or Medallion cleaner or 3M's Imperial Hand Glaze, something to remove spots, polish the paint, and leave a high gloss for the #26 to protect.
Even Meguiar's Medallion has some chemical cleaner in it. Medallion is designed to last a long time (it's mostly a polymer product) whereas GC is designed to provide high gloss and reflectivity.
Hope this helps.
Thanks in advance.
I'm now using Eagle One's clay bar and am much happier.
Hope this helps.
Why Austria? Some family lineage goes there but I was also thinking of the last episode of "Band of Brothers" when they were in Zell Am See, Austria. An incredible place. Perfect place to drive your Porsche.
It's a natural clay so it is a little heavier.
The real trick to not leaving a residue is to spray a good coat of lubricant on the surface, and on the bar itself before rubbing. Spray more if even a slight stickiness is felt. Mrdetailer's posts in this forum have detailed discussions on this.
I like the shine of Gold Class, but #26 lasted 7 months and counting (can't test anymore for durability when I have to get ready for winter). Gold Class only kept up excellent beading for 3 months and had to be redone.
Thewaxtest.com may show that over time as well.
Needless to say, I would recommend this product for a dress up date only as the durability is not even close to a real wax job. Has anyone else used?
http://stores.yahoo.com/autofanatics1/collinite1.html
I have not seen any Collinite locally or in any auto places. Usually the salesperson will look at you kind of funny and say he has never heard of Collinite. I plan on trying the #845.
Does anyone have any suggestions? price range? brand?
Or is there anyone who'd recommend against using one?
Gonna give Blackfire a try? I'm thinking about it.
- - Bret - -
Thank You,
Larry
Yes, I'm from the dark side and just have a couple of comments:
1. Blackfire sounds a whole lot like the unmentionable stuff used on my planet.
2. Are they going to have to alter the title of this topic on November 14 when Blackfire comes out?? :-)
I also took the time to read the information on Blackfire and it sounds very interesting as well as very familiar. I sincerely hope that whoever decides to try it will like it. It's description of capabilities, application procedures, and method of purchase (ie no retail) was funny in that it hit close to home and IMO it would be ironic to discuss it in this forum.
As you stated some time ago, I too look forward to a day when we can all get along in one forum. That's why I was suprised that you, one of the more open minded and level headed individuals whose posts are usually worth reading, would come back so strongly.
Well, I misunderstood the tone of your post, my bad. I deleted my post. I guess, I'll switch to de-cafeinated!
Respectfully,
Larry
Nah, life can be too boring with decaf. Besides decaf gives me headaches!!
Robert
http://www.portercable.com/cgi-bin/products.cgi?method=byid&prod_id=7424
This one is all the rage with the car care fanatics. Make sure you buy an accessory kit that includes a Velcro backing plate and various pads.
Go to http://www.craftsman.com and enter item # 00927098000 into the Search window. It will show their 11" Industrial orbital buffer for $119.99.
I've been using a 20 year old version of this one and it's still running strong.
In my view the smaller bonnet is more maneuverable in tight spots. Also I think that a larger bonnet on a high-torque buffer may make it too heavy. Just a guess on my part.
In the long run the swept area of the bonnet doesn't make a difference. It's all in how you use it and what products are used. There have been times where I wish I had a high speed buffer but my Sears 11" has done the job just fine. I have a 9" Chamberlain somewhere (at my parent's house, I think) and that works well too.
If it's workin' for ya, Mr. D, just keep on keepin' on.
It is nice sometimes, but the wax gets everywhere--on trim, in cracks, etc.
dave
I do have an old 6" or so model I bought for about $40 that was supposed to be a random orbit polisher. The problem is that it stops spinning as soon as it touches the paint...very weak. So I abandoned it.
Do these new ones have more power? and can you vary the speed on any of them?
The Porter Cable does have a speed adjustment dial on the back. Next time you're at Home Depot, have a look at it.
Take a spray bottle filled with water and spray & wipe down your car. A quick detailer product will also work. This should "cure" the wax and the streaks should disappear.
If that doesn't work, rewash the car.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=43424
It has .65 amp, about half of the Sears. Mine works fine- of course It won't last too long =cheap.
It's always best to use a product sparingly. If the results aren't what you expected you can apply a second coat. If you're still not getting the results you want then something is amiss - wrong product, incorrect usage, poor paint prep, unrealistic expectations, something.
Too much product makes the job harder. So next time try applying it thinly and evenly. Let it dry the proper amount of time. Remove and review the results. Apply another coat and review those reuslts. As you apply coats the job should get easier and go quicker. Use a little water or a quick detailer to finish off the job.
I suggest experimenting with different products and/or techniques until you find somethig that works for you. For example, divide your hood in half and wax one side with lateral motion (back and forth) and the other side with the classic circular motion. On another panel, apply a couple thin coats of your favorite product. Then try a thicker coat on yet another panel. Do this all over your car. Eventually you'll come across a combo you like. I've been doing this for many years; it's fun using my car as a product tester.
Have fun! Let us know if we can help.
Crevices. If it's the same color I keep the buffer away and do that area by hand with the same bonnet after I used on the the flat areas. If it's a rubberized black trim, before I apply the wax, I use either Black Magic Tire trim -- the extra thick kind that is not a spray bottle --- or Meguiars Trim Finish. The wax just doesn't stick to this pretreated surface.
dave
Thank you in advance!
-Larry
