Store Bought Waxes Part II (No Zaino Posts)
1373840424377
  • britton2britton2 Member Posts: 305
    I use those Detailer's Choice chenile wash mitts that I get at Wal-Mart - this is considered a good brand so I think they are OK as far as being 100% cotton
    100% cotton is best but is getting very hard to find at retail. Viking used to sell them but recently went to a cotton/poly blend to keep pricing low. They felt consumers didn't care that much to pay for 100% cotton.
    I now use the 100% cotton chenille mitts from NAPA. Not quite as fluffy and soft as the old Vikings but still pretty good.
    I think if you're coming from a sponge or old poly sheep fuzzy thing, the cotton blend chenille mitts are fine. If you can easily find 100% cotton mitts then I recommend that. But use the softest mitt you can find.
    Carnaubas can be a HUGE PITA to remove if you don't follow directions and do it right. As tntitan said, apply to a small area, thin coat, let it set up briefly (no more than a couple minutes) then quickly buff off. When using the better quality carnaubas like One Grand Blitz, Pinnacle, Zymol, and Collinite, you've got to use this technique to avoid problems. If you let these carnaubas dry hard, you will need a chisel and a blow torch to remove them.
  • adc100adc100 Member Posts: 1,521
    What I have noticed is that after the first coat of a wax is on and you put another coat on it later- Removal seems to be lots easier. The other thing is that as you work with your favorite you develop a sixth sense on the best way to work with it.
    I am curious about one thing- I use the Collinite Fleetwax which has about 25% less than their "Marque". They do this to make removal easier. Strange? More carnuba-easier removal?
  • canccanc Member Posts: 715
    How does Collinite compare to Meguiar's Gold Class? Too bad the waxtest.com website is down. I'm not too fond of carnauba waxes, and prefer polymer-based waxes, which is why I use GC.
    Lasts better than #26 in my informal test but doesn't look quite as good IMHO (That's the Fleetwax-not the Marque). Take it from there. If the #26 doesn't last as well as the Class then it won't last as well as the Collinite. If it looks better than the #26 it will look better than the Fleetwax. Can't speak for quality of Collinite Marque.
  • bt1bt1 Member Posts: 4
    Whats the best types of bonnets to use for applying, removing and polishing your car. My buffer came with three bonnets, a applicator, terry cloth, and a wool blend polishing bonnet. I heard that its not good to use a wool bonnet for polishing because it will scratch the paint.
    It depends on what kind of buffer you've got and the product you're using. For most inexpensive orbital buffers the terrycloth ones are great for applying products. The wool bonnets will bite into the paint a little more (to remove oxidation, for example) but most of the consumer-type buffers do not spin fast enough to generate heat that causes paint damage. So if you had paint that was badly oxidized and were using an aggressive paint polish, the wool bonnet would be OK to use.
    I used terrycloth bonnets for application only. Product removal was always done by hand.
    You might want to stock up on bonnets; they're one of those things you can never have enough of.
  • tntitantntitan Member Posts: 306
    Applied the 2nd coat of Collinite after allowing the first coat 1 week to cure. It may have gone on just a little bit easier. The car really looks good - I guess only time would tell how long it lasts.
  • beachnutbeachnut Member Posts: 291
    Bretfraz is correct as usual, it does depend on the type of buffer. For example, if you have a Porter-Cable 7424, there are specific bonnets made for this buffer. (BTW, thanks bret for the p-c tip; I'm searching ebay & ubid for one as we speak!) I am looking to use micro-fiber bonnets for my new buffer. They make seperate types, one for applying, one for removing. Both are sold on www.properautocare.com
    (hope there's no peta folks here, it's just an expression!) How come "no zaino posts"? I know they have their own forum, but since I'm somewhat new to this board, I'm curious as to why there seems to be this definitive line in the sand. What don't you guys like about zaino? Or maybe what I should say is: why do you prefer these methods as opposed to their's?
    I wasn't here when the board first started, but I've seen many Zaino posts here on Edmunds that are the brink of propaganda. Zaino is only available through the manufacturer, whereas most products here are easily available through retail outlets. Some tout Zaino as being the best, but I don't think the product justifies its high price tag.
    Zaino is actually a very good wax, but I personally don't think it's drastically better than Collinite, Gold Class, or other premium waxes out there. On the good side though, I believe Zaino doesn't have any solvent cleaners in its formula whereas my GC or Collinite does.
    What really pushed me away drastically from Zaino is the customer testimonial pictures on their website. At least a few of them are, um, "enhanced", with Photoshop filters. That's just cheap.
  • alan81alan81 Member Posts: 4
    I dont use ZAINO im a carnauba person souvern P21s or griots garage carnauba but mu friend use ZAINO and his car shines and shines(it kills me)there is no bull in that product its whatever you want to use yes its expensive but woth it DIFFERENT STROKES FOR DIFFERENT FOLKS
    Please reread my post. I _did_ mention that Zaino is a great product, but that I don't think the result is significantly better than a Collinite or GC wax, especially considering the price difference.
    Anyway, back to the topic. Does anyone here use Meguiar's Professional vs. the Gold Class?
    Thanks for the reply. I'm not trying to bait anyone here ... I just honestly wanted to know.
  • mbdrivermbdriver Member Posts: 426
    Like you, I haven't been around since the beginning and I share your curiosity about why the "forbidden" product can't be mentioned here. My guess, though, based on posts last year and before, is that many Z users are too fanatical about how good their product is, and lots of flaming posts resulted. It really wasn't propaganda, as Canc suggests, but rather too much enthusiasm on both sides. Besides, Z ain't a "Store Bought Wax" -- the title of this forum.
    I myself switched to Z more than two years ago, and I'm convinced it's better than anything I've ever used in 50 years of "waxing" cars (Oops! I'm showing my age). But I also respect the opinions and preferences of others. If the product someone else is using produces the desired results, so be it!
    One last comment -- Z really isn't unduly expensive. Perhaps the only problem Z users experience is that they try to apply too much. A little bit of the product goes a loooooong way!
  • mrdetailermrdetailer Member Posts: 1,118
    so it was moved to its own discussion group and leave it at that.
    Now adays if I use Meguiars products I will only purchase the professional line. I use the #26 Hard Yellow Paste constantly. @ coats lasts 4-6 months. A can on a well prepared surface lasts me about 2 years, and I maintain 6 cars. I always apply multiple coats and have estimated that I get about 50 applications for about 10 bucks.
    I really like their professional vinyl preservative and cleaner. I believe it is #46. When I run out of the current bottle I will definitely buy it again. It is the best combination cleaner preservative. But on the dash I use nothing but Aerospace 303 because of it's extra UV protection, and low shine.
    #7 Show Car Glaze is excellent. It doesn't allow to overuse it since the clay used in the abrasive breaks down after a while. Shine is excellent. With more experience, I am leaning to Meguiar's Imperial Hand Glaze, or Perfect-It Machine glaze and swirl remover. I have no problem recommending it to anyone, and it is easily purchased at any auto store here.
    The Professional Quick Detailer is more expensive than the red bottle, but is an excellent product. It can be used as a cleanup just before painting as well. Great shine. When I run out of my other quick detailers I'm going to order a gallon.
    So while I don't use Meguiar's exclusively, I really like their products as a whole.
  • protege_fanprotege_fan Member Posts: 2,405
    Just out of curiousity, what are the MF towels actually made out of? Also, I've only been able to find MF towels that are about the size of face-cloths...nothing the size of a 100% cotton bath towel. Do they make large MF towels?
    Thanks guys!
  • pjyoungpjyoung Member Posts: 885
    I just can't help but notice that there was a lot of "MF's in that MF post ;>)
    I see your point...but does anybody know the answer?
    Everything you ever wanted to know about them:
    http://www.properautocare.com/micwhatbigde.html
    Who wants *me* to go into the reasons why Zaino is not allowed to be discussed in here?
    Let's just say this "issue" was a contentious one before I came here, about 2 years ago. Lots and lots and lots of posts have been deleted over that time. I believe some folks have been banned from Town Hall for being a "participant". As you can imagine, it's not been pretty. But it has mellowed quite a bit in recent times and I'm happy to see it stay that way.
    and others, I promise never to bring it up again and scamper back into my little corner, tail tucked - so I won't be voting :-(
    Thanks for the microfiber link. :D
  • specialmspecialm Member Posts: 31
    I've heard that waxes don't allow the paint to breathe. Over the long term it could be bad for the finish. The guy who painted my car said it was best to use glaze only. Is this true? I tried 2 coats by hand on my new paint job (base coat/clear coat) and wasn't very happy with the results. I couldn't get rid of the swirl marks.
    It's OK, you can come out and play with us ;-)
    If you just gots to know you can always e-mail me and we can discuss offline. But it's best for all involved that we don't discuss the forbidden topic here.
    Wax won't get rid of swirl marks. It won't even hide them. A glaze and sealer will hide the swirl marks to some degree. To get light swirls out a swirl mark remover (SMR) will work best when applied with an orbital buffer. Of course, this is just what I've read. I have a bunch of swirls that I need to get rid of on my car :(
    A sealer and glaze product won't last long without the protection of wax.
    I'm not sure about the paint breathing...but IMO the wax will only serve to protect your paint, not harm it (assuming you apply it properly of course).
    and when I last checked, if the base coat is "breathing" the base coat will come off on the clean up cloth, and it is actually causing problems.
    Waxes expand and and contract with temperature change at least as much as the paint coats do. I have a 15 year old car that looks better than new. Most cars of that model and year are faded and peeling, and rusty. Do the clay bar, glaze and wax and you won't regret it.
    Clay is the one thing that I have yet to do...aside from getting out my nasty swirls :(
    But I did use the Mother's 3 step "Ultimate" wax system with good results this past weekend. Looked pretty amazing, except for the swirls.
    I recently had Wilsonart solid surface counters installed in my new kitchen. The startup kit came with a cleaner/wax/polisher call Quick Shine Plus and it was highly recommended by Corian, Avonite, Gibraltar, et al. Upon surfing to their website http://www.protectall.com , I found that they have all sorts of products for auto detailing, including a carnuba wax. Any experiences?
  • zoomjzoomj Member Posts: 6
    I just bought a 2002 Camry.
    I just puchased Meguiar's Gold Class car wash (I was using Armor-all car wash). Is the Meguiar's worth the extra cost or should I just stick with the Armor-all car wash?
    I also puchased the Meguiar's Cleaner Wax. Is this any good? I liked the fact that it seemed easy to put on the car and you could do the whole car at once, not just a small section at a time. Does the wax last a long time? How often should I wax the car?
    What do you apply the wax with? I have applicator pads from Target that are terry covered sponges. Are these safe to use? It doesn't say if they are all cotton. It's probably a blend. It says they are soft and lint free.
    To apply wax, 100% cotton applicator pads are fine. i don't know about the applicators you bought though as I haven't seen them.
    I used Meguiar's cleaner wax once. There was a lot of residue. I don't use it anymore. It's not as good as a 3-step system or just a straight carnauba wax and the cleaner wax is slightly abrasive.
    Meguiar's cleaner wax probably won't last any longer than 3-4 months under good conditions. Note, you can't layer the cleaner wax as it will clean off the previous layer. It's a good quick wax if that's what you're after, but just be aware that there are better products out there....of course for more money too.
    I think the Armor-all car wash may strip off any wax that you have on the car. I know that I used the Armor-all wash and it seemed as though I needed to re-wax after using it (ie. water didn't bead up as well anymore). The Mother's California Gold wash that I use says that it does not strip wax and I believe your new Meguiar's wash is the same. I think it's worth the extra money if it makes you happy. :D
    Thanks for the replies. I haven't tried any clay on the repainted car yet but plan to after seeing the results on my Jeep.
    Question: Is glaze aka; SMR? Or are they different products? I've heard mention of that being used.
    I do want to try a wax on the newly painted car as well. It was actually repainted 2 years ago but hasn't seen much use and has been garaged. So, the paint is definately cured. Just trying to iron out the swirls issue now. Thanks!
    As I understand it:
    SMR (Swirl Mark Remover) is actually abrasive and will remove the swirl marks.
    A glaze will fill in the swirl marks, making them less noticeable, but will not actually remove them.
  • bigcompactbigcompact Member Posts: 33
    I have been using the Meguiar's products for almost a year now with great results. About 2 months ago, I stripped the finish with Dawn, and did one coat of Meguiar's #7, followed by a coat of Meguiar's #26. The beading seems to be going away, so naturally, I want to wax the car again. Now here's the question. I don't intend to strip the existing wax off. So, do i wash the car and apply a coat of #26, or do I apply a coat of the #7 followed by a coat of #26? My gut tells me that a glaze won't do any good unless it's between the paint and the wax (which would require stripping the finish, which I don't want to do). But you guys would know better than me. Thoughts?
    P.S. I am have a black car, so I am going for protection over shine.
    Go ahead and slap on another coat of #26. My guess is most of the original product is gone so I'm sure your car can use another coat.
    You might want to do a little side-by-side comparo to see if you need/want a coat of #7 prior to #26. Just do your normal wash and dry, focus on one panel (like the hood or trunk lid) and apply #26 to a small area. Do the #7/#26 combo on another small area right next to the #26 only section and evaluate results. Compare to the unwaxed areas too. That way you get a good idea of what kind of work needs to be done. And you didn't do the whole car to find out ;-)
    Let us know how it goes for you.
  • Kirstie_HKirstie_H Administrator Posts: 11,247
    A major daily newspaper is writing a story about collision damage insurance, and is looking to talk with drivers who have run into deer or moose. "In most states, such an encounter is not covered by comp. or collision damage insurance; you need special coverage. I want to talk to people who have had these collisions and learn how they handled them. Likewise, I'd also like to hear from people who were involved in some other sort of incident involving their auto and found out that insurance they thought they had was not there." Please respond no later than Monday, June 3 to paudel2001@msn.com and/or jfallon@edmunds.com. Thanks as always!
    Jeannine Fallon
    PR Director
    Edmunds.com
    MODERATOR /ADMINISTRATOR
    Review your vehicle
    I just puchased Meguiar's Gold Class car wash (I was using Armor-all car wash. Is the Meguiar's worth the extra cost or should I just stick with the Armor-all car wash?
    I have found the Gold Class Car wash to clean well and leave a brillant shine. However, I would also finish using the Armor all.
    I hate cleaner waxes. While they look great immediately after finishine, they don't hold a top shine and protect well for longer than 6-8 weeks. If you want to redo it that often it will work great. I've been able to use the #7 show car glaze, and #26 Hard Yellow Wax (2 coats a week apart) and it's lasted 4-6 months depending on the conditions. At least twice as long as any cleaner wax. 3M Perfect_It show Car wax Paste lasts 6 months even in winter.
    If it's made for auto applications it will be terry, don't worry.
    I think I will return the Meguiar's cleaner wax. What about Meguiar's Gold Class Wax? Any good?
    Looks fabulous, but doesn't last. Especially if you have a buffer, use #7 Glaze and #26 Hard Yellow wax and costs about the same as Gold Class. The separate products are less work in the long run.
    Thanks protege_fan!
    I don't have a buffer. Would it be a lot of work without a buffer? Where do you get #7 and #26? Do you need to use them together? Or can you only use the #26 wax? To use both do you have to use dawn to strip the car? I don't want to do that since it is a brand new car.
    The Meguiar's Gold Class wax has a foam sponge applicator (NO terry covering). Is that ok to use? How long does this wax last versus the #26?
    Sorry for so many questions!
    You should be able to get both #7 Show Car Glaze and #26 Yard Yellow Wax at auto parts like AutoZone, Pep Boys, or Checkers.
    I used Glaze and Wax by hand for years. It's a bit more work, but fine. Glaze application is more even and quicker but you can go a very good job if you work in about 18 inch squares. I use paste waxes so they are always applied and removed by hand anyway. I use buffers only for swirl remover, and glaze application. I always remove by hand.
    A glaze, together with a clay bar are the real secrets to adding depth to the finish. #26 Hard Yellow Wax can be used by itself, and I do that quite often when needed. I only use the Glaze in spring and fall. Every three months I do a refresher coat if the weather permits. While not technically necessary it keeps the shine in top condition.
    Dawn, or other dish washing detergents are used when you want to take off old waxes. If it's new I would recommend a car wash that doesn't have any waxes in it like Meguiar's Gold Class Car Wash.
    The foam applicators are fine and easier to clean up than the terry applicators. Just make sure to keep that seam around the edges from touching the paint surface.
    I'm going to add one more thing. After you wash, run your hand over the surface, especially the hood, roof and trunk. If it feels the slightest bit rough then do the clay bar procedure. New cars quite often have dust from the freight trains that contains microscopic iron filings. These are murder on the clear coat if not removed, and can scratch your car finish. Dealers quite often don't do it since it is labor intensive. I consider this just as important as glazing and waxing. Also done twice a year.
    If you do all three you will love the clarity and depth of shine, and it will last longer, and be less work in the long run.
    How long do you wait to wax a brand new car? I've already washed it once.
    How long does #26 last compared to Gold Class wax? Do you need to strip with Dawn before each time you wax?
    What does the glaze do? If I glaze do I need to strip with Dawn? Not sure what the clay bar procedure is.
    Thanks for all the info!
    The paint is well cured by the time it arrives on the lot it can be waxed immediately as evidenced by their special $400+ protectants that are nothing more than glorified wax coats.
    I've found #26 Paste to last about twice as long as Gold Class if the car has been glazed every 6 months and two coats are applied a week apart. I've actually gone as long as 7 full months last summer, and 5 in the winter and still had a great finish. I recommend a glaze/wax spring and fall. I have not found it necessary to use glaze more often than that. I do a refresher coat 3 months later of #26 for increased protection and beauty.
    I only use dish washing liquid if I want to help strip off existing wax before glazing. Never otherwise. I use Gold Class Auto Shampoo or some comparable brand at other times.
    The glaze has a few buffers (#7 uses a clay) that will remove invisible surface contamination, but not hard enough to actively remove scratches. It also has nourishing oils that deepen the shine. If you want to keep scratches off as much as possible, never use a glaze unless you have used a clay bar first. I've used this technique on my Dad's Dark Green Taurus and it doesn't have swirl marks at all.
    Glazing also uses much less wax. My current can of #26 has lasted through at least 50 coats. Much more than the expected 15 applications.
    Clay Bar -- Check back about 8 weeks ago on this forum under my name. I did a detailed explanation then. Roughly you buy a kit that has a quick detailer with a clay bar. Meguiar's was the least expensive. Wash the car with Dawn, et. al. Dry the car. Break the Clay Bar in half. Flatten it into a pancake. Work in about 18 inch squares. Liberally spray the quick detailer on the surface of the car and the clay bar itself. Spray again if you feel the slightest resistance. Clay stuck on the surface takes a lot of rubbing to get off. Use both circular and horizontal and vertical motions over the area to completely cover all sections of the surface. Only light pressure is needed. Wipe with a 100% cotton terry towel. Sam's Club has some small ones that are inexpensive but good. Check the surface of the clay. If it's dirty fold the clay into itself until a clean surface appears again. Repeat if needed or move on to the next section. When done the surface should be as smooth as a glass mirror to the touch.
    I really Like using Eraser and Meguiar's clay. Mother's also is good, but in my area was expensive.
    With practice it can be done in 30-45 minutes on most vehicles.
    Hope this helps.
    it should be noted that quick detailer (QD) is NOT the quick wax that come in similar bottles.
    Mr. D's been doin some typin!
    Ok, let me see if I got this right. I will need to use Dawn on a brand new car before I glaze because you can't glaze on top of old wax. And even though #7 has clay in it already I should still use a separate clay bar. On a side note-
    I did not pay $600 for the Toyoguard (BS?)protection pkg- I got a car without this pkg.
    I'll add a few pennies in here too. :-)
    The reason to use Dawn (or comparable) is to strip/remove all waxes and polishes from the paint prior to fresh detailing. Dawn is typically suggested as its well-known to be a strong alkaline (pH of 9.1) and it has grease-cutting agents in it to remove stubborn road film and grime. It's not something to be used frequently as an strong alkaline product will remove plasticizers from clearcoats and dull them over time. But for a once or twice a year full detail, it works well.
    Clay bars remove surface contaminents from your paint. It's another important prep step. Mr. D outlined some of the reasons; I'm sure you dug up his post on claying and know how to do it.
    I think the clay Mr. D is referring to in #7 is kaolin clay. There's just enough in #7 to act as a very mild polish. But it's not designed to do the same thing as detailing clay; they just share the same name.
