Store Bought Waxes Part II (No Zaino Posts)
Grand High Poobah
The Fraternal Order of Procrastinators
But of course if it works for you then use it. I use different products on different cars myself because that's what works best.
Consumer Reports. I bought Consumer Reports recommended child seat over an easily adjustible one that they didn't recommend because it was too expensive. Regreted it eversince. Now it's a guide, not an absolute. On waxes, they don't even test the really good stuff.
An all in one product that is amazing on the Carnauba side is 3M Cleaner Wax Light Oxidation Remover. Better than Mothers or Meguiars Gold Class. On the sealant side Klasse All In One is probably the best one step product.
I guess to me that would be a drawback to Nu-Finish. If it is so strong that it can remove oxidation and such, it seems way too strong for normal use. You said nothing else would work, but I imagine you mean no other protectant. Paint cleaners would have worked wonders, I'd bet. But that isn't something you want to use all the time, or on clean, high-gloss paint. But if Nu-Finish is that strong, you have no choice but to get that level of cleaning when you use it, even if the paint is already in perfect shape. Protectants aren't meant to restore gloss and luster. They are meant to maintain it. Most all-in-one products have very mild cleaners that are suitable for frequent use, but they won't ususally bring back paint in bad condition (although sometimes multiple applications and a lot of working them in might work). Nu-Finish really sounds too strong for regular use on nice paint. If you want to use it to clean up the finish, then maybe you should just use it when there isn't much gloss to the paint. Then switch to a milder protectant to keep the gloss Nu-Finish restores.
Bretfraz and MrDetailer mentioned Klasse All-In-One which is a better, longer-lasting product. Also, #20 and MPPP are good store-bought alternatives. There is no magic about Nu-Finish. There are certainly other products out there that will work as well or better, if that's what you are looking for.
I really like MPPP for an all-in-one. I used to use it all the time, and still use it on family member's cars. It gives a great shine and is very easy to use. Plus, there is a companion cleaner (Medallion Premium Paint Cleaner) that you can use if the paint is too badly oxidized. No 4+ step procedure, just one or possibly two when the paint is bad.
Although, really, if you are happy with Nu-Finish, then you may as well stick with it. These alternatives are if you are looking for something more than Nu-Finish (that will probably cost more, too).
That said, I'd rather buy the #20, most for the reasons stated above (ie. too harsh, etc).
Grand High Poobah
Klasse. I've only seen it on the Internet. Klassdirect.com is the least expensive source, especially for the 500L or Liter sizes. (sale going on right now)
I tried the Zymol that Consumer Reports recommended. It was thick and fairly hard to apply. It also left wax in every nook and cranny of my car -- between panels, around the hood, everywhere. Even my wife commented on how messy it left the car.
I recently found a good mass-market product that I can highly recommend that has great durability, is easy to apply, and doesn't stain trim or leave wax dust in all the cracks. It is Mothers Reflections polish. It is a synthetic, like Nu-Finish, so it has great durability. Only two drawbacks. It isn't as readily available as the others, so if your local autoparts store doesn't have it you may have to order it if you want to try it. The other drawback? It smells like cheap men's cologne! Odd, huh?
If you can find it, you'll like it. Cheap, too. Around $10 USD a bottle and a little goes a long way.
Has anyone else tried this?
Sean
of buying BlackFire or Klasse, any opinions
on which is better for light colored cars.
Also what would the difference from using a
clay bar vs Meguiars Medallion premium
paint cleaner?
thanks.
caddyjet3
Klasse All-In-One -- cleans and provides durability.
Blackfire Paint Protectant -- Much easier to use than Klasse Sealant Glaze which can be real PITA if applied too thick, which is very common. I recommend 2 coats a week apart. Better look, easier to apply, hides swirl marks. Blackfire Paitn Protectant is the most gentle on paint of any liquid, the Klasse SG can be harsh.
Meguiars MPC cleans off road scum and surface dirt. A clay bar removes embedded pollutants that a cleaner won't remove. They are completely different. I see no reason to use MMPC if you decide to use Klasse AIO.
I always Clay Bar once or twice a year when completely stripping then applying new coats.
Based on what I've read and know about Klasse SG, I'd never use it. Just ain't worth the hassle.
combo idea, I just clayed, Meguiars#7, 2 coats
of 3M Paste and 3 coats of #26 so I should be
good for a while, but probably at the end of
Feb I'll put on the K+B.
I also want to say how much I enjoy reading
this forum, My DTS looks like a different
car compared to 6 months ago, just because
of the products and ideas from this board
thanks again
Happy Holidays
On the other hand, everytime someone posts complaining about this, a few people speak up and say it works for them and offer tips for how to get it thinner. My feeling is that it is more difficult to make work than other products.
Sean
If you don't put much on the applicator, Blackfire Paint Protectant is easy to apply and dries in a few minutes. I've never left it on longer than an hour, and that was in 40 degree temperatures. When it's ready it buffs off quickly and streak free. I think it's pretty failsafe. CMA Technical support is very helpful if you have questions.
http://www.finishfirstpolish.com/
I tried the BF first on the white car and 6 months later put the Klasse twins on. I definitely like the Klasse better on white. IMHO it is almost no more trouble than BF to use. The AIO and the BF polish are both easy on easy off. The BF protectant is also easy on easy off. The SG was simple to use as well but it required one additional step to prevent the "SG haze". After letting the SG cure overnight in the garage I first buffed with a wet MF towel and then rebuffed each section with a dry MF towel. That's it. It added maybe 10 minutes of mild buffing and worked perfectly.
Both of these products work great but have different looks. The Klasse is more reflective (which I really like on the white car) while the BF has a wet,deep look (which is better IMO on the dark color cars). Both are fairly easy to work with but the common consensus is that the Klasse longevity is hard to beat (maybe Zaino).
Whatever you decide be sure to clay first. Claying is so simple you won't believe it and it really prepares the surface.
Claying a car is like prepping the surface for polishing (compare it to sanding a wood surface before painting). It removes contaminants like brake dust, rail filings from railroad cars when new cars are shipped around the country, insect remains, or any other crud that prevents your paint surface from being perfectly smooth. After you clay the car your polish and/or wax will go on and off easier and you will not need as much of it.
The actual process is pretty simple. Wash your car to get as much surface dirt off as possible. Lubricate a section of the car with either detail spray or carwash soap and water and then rub the clay over the surface until it glides back and forth smoothly without "catching" on the surface...usually on two or three passes over any given area will be all it takes. The front of your car and the lower side panels will usually have the most crud on them. It is important that you keep the surface you work on lubricated so that the clay bar slides easily and it is critical that you do not drop the clay bar and reuse it.
Check the bar every so often and when it looks dirty or has contaminants of any kind over it, fold it over until a clean surface is visible and continue. Most bars will clean 6-12 average size cars easily.
There are many clay bars available and from what I have read almost all of them are fine to use except the Meguiars clay. Mothers makes one that is easily found at auto stores but if you search around most of the experts seem to think that the Clay Magic bars are the best. I use one called the Erazer.
The only way you will damage your car using one of these is by dropping and getting something in the bar and then rubbing it against your car paint. Once you use one you will see that they are wonderful, easy to use, and inexpensive. It only takes me about 30 minutes to do my Accord but might take 45 minutes to do a full sized car. It is not difficult labor at all.
After you do it once it will go a lot faster. Then you can just do it as needed. It is so easy it is not that big of a deal to do the whole car before polishing every time.
I like to put on a wax or "adhesive remover" first so the clay will be removing embedded contaminants, not wax. The job goes even faster then. 3M Adhesive, Sap and Wax Remover can be bought at Walmart, or many other Paint Prep products found at an auto paint supply store are even cheaper.
Keep a towel handy to wipe any runs. If left to dry, it may stain the paint.
Use plenty of lubricant. Easiest one to use is a pint spray bottle with 2 tablespoons of Auto Wash Soap added to the water.
http://www.nytimes.com/2002/12/20/automobiles/20AUTO.html
Brenda
Thanks for the NYT article, Brenda.
I just got my used car (98 Civic). I realized that there are something (it looks like a fingerprint) on the paint above driver side door.(You can see from image link)
http://www.geocities.com/soft-master/111-1128_IMG.JPG
I don't know what is that. It looks like fingerprint. It has couple of them in the driving side area. It seems that "fingerprint like" dirt are not on the surface. It wouldn't come from car wash. I used Meguiar's Cleaner Wax today and it didn't help. Does anyone know what is that? Does it help with some other wax product?
Moreover, I heard some product called Clay Bar from Mothers. Do anyone know whether it helps?
Any comment and recommendation are welcome!!
Thanks a lot!
Vince
It is quite possible that it will take the fingerprint out. I think it is some sort of embedded contamination, which is what clay bars are for.
Sean
A step below Zaino and Klasse as far as polymer sealants go. But easy to use and reasonably affordable. And better than 90% of the stuff you see at retail.
If protection and durable was more of a priorty than reflectiveness on a new finish?
Read thru the posts here and you'll see some of the brands we use and recommend.
Did I read somewhere that you can use AIO as a car wash? Does that work well?
Use a shampoo made just for the job. There are many on the market.
Both supposedly have easy applications, but I don't know if you should mix them.
I think its fine to experiment with wax/sealant combos as long as the wax is on top of the sealant and not the other way 'round. Sealants bond best to clean, uncoated surfaces but you can use wax as a topper to most anything you want.
What is everyone down on Zaino about? Please explain.
OK, some Cliff's Notes:
Both are brands of car appearance products. There are no two brands that have a more loyal, devoted, and passionate following than Zaino and Zymol. Spend some time searching the net and you will find literally thousands of posts discussing both brands. It will blow your mind.
The Zymol you see at places like WalMart is made by Turtle Wax under a licensing agreement. Its nothing like the super expensive Zymol products you see elsewhere. The quality of the store-bought Zymol is average at best but better than some $5.00 wax.
Zaino distribution is extremely limited: Buy direct, from a local distributor, or Ecklers.com.
That's all I'm saying (for now).
S100 Shine Enhancing Paint Cleaner
Klasse All In One.
Blackfire Paint Protectant 2 coats.
P21S/S100 Carnauba wax.
It will be durable and look better than you can imagine, even on a new car.
