Power Seat Making Noise
jdalabamajdalabama Member Posts: 4
edited January 2024 in Buick
Driver's seat is noisy when moving backwards (but not when moving forward. Is this a failing motor? Is there a work around to avoid changing the motor? If must change motor, needs dealer or any reputable mechanic?
  • LawKay2011LawKay2011 Member Posts: 5
    Have similar problem. Driver 8 way seat ‘grinds’ going forward, and ‘grinds’ to a HALT when trying to RAISE the seat. Dealer says the frame assembly (part#13506164) needs to be replaced. Problem is it is no longer available!
    Can get a used one for $125 BUT it is $300 to ship. They won’t separate bottom from just the fabric part of seat!
