Store Bought Waxes Part II (No Zaino Posts)
However, last weekend, I was helping a friend with her car, in 90 degree weather, 10% humidity and was unable to rinse/dry quickly enough. Both of our cars had water spots when we were finished, and neither of us felt like rinsing and drying again.
I plan to wash again this weekend - I hope that is soon enough for the spots not to be impossible to get off, but if they dry hard, I'll be needing all your advice.
OK no prob, I'll just apply Meguiar's swirl remover. Only thing that did was leave a haze on the small part of the hood where I tried it out. I can still see the swirls from the right angle.
Are these swirls here for good and should I just accept it? The next black porsche or other nicely kept black car I'll sneak a peak at and see if I see the same thing.
What about this microfiber towel? Am I using it the wrong way?
On a good note, I used the Quick Detail which took those water spots right up!
thanks for any & all info
fo
btw, u do have to rinse them first when u first get them or else tiny micro fibers will be left behind... r u sure your swirls aren't those hairs? i got them all over my windshield the first time i used them w/o rinsing. they almost look like tiny scratches.
We have recently purchased a green Miata with a neglected paint finish. I’ve been reading a lot of your posts out here to get “in the know” again and we have chosen the following steps:
#9 to remove whatever gunk was on the car and to clean up some of the smaller marks;
#2 to remove some of the deeper scratches;
#20 to finish it off;
#26, maybe to top off the 20, understanding this is not necessary but may add something to the look.
Now, I’ve got questions about #20. We haven’t used this product before however I used Liquid Glass for many years on a white car and was always very happy about that.
Do multiple coats of #20 improve the protection/durability? If multiple coats of #20 are recommended, how long should we wait between applications?
How much time should we wait for #20 to “cure” before applying #26. I think I read that we should wait 24 hours? Is this correct?
Thanks for all the great info.!
My "new" car has dirt and tar accumulating in perfectly straight lines along the hood and trunk. I strongly suspect this is because the protective plastic sheets they ship cars in has left a slight sticky residue where the sheets used to be. Does anyone have suggestions as to how to remove the tar and adhesive line without doing too much damage to the finish? Should I use a cleaner wax and concentrate on those areas and therefore have to wax the entire car?
Thanks to any and all suggestions.
I am planning on washing it with Meguiars car wash and following up with Meguiars #26 paste. Any insight/experience is welcomed.
Follow up with a wash and some wax and you'll be set. My car had them too around the sunroof so I know (think?) what you're talking about. Should be a piece of cake to fix.
You might want to use a little polish like Meguiar's #7 glaze prior to the #26. Remember the #26 has no cleaners or fillers in it, its a "final step" product. The glaze will fill in any minor flaws, if they exist at all.
Good luck with your new ride!!
It is going to encounter city driving soon enough, I just wish that I could wax it first. Thanks again for your input.
Again, thanks.
This is exactly what I was looking for,
thanks again!
What is the consensus on using a product like California Duster then polishing, without a wash directly before - with a detail-level wash having been done the night before?
Basically, last night ran out of time/daylight/wife-patience after washing/drying/interior wipedown/re-drying drips from those @?!@#& hidden spots. I want to know if after work today I can dust it off and do a quick detail type polish. Car is couple months old and babied from the start so don't want to risk swirls (black Acura TSX)...
Thanks for the input, y'all,
Squirrel
SInce you have already driven the car today, I would think twice about just doing the CD before waxing / polishing. What if particles were embedded into the paint or what not, is it worth to risk your paint job. I say, just be happy that you were able to wash the car. Maybe next time you will have time to do your entire regimen. Don't take the shortcut and risk any damage, not worth it.
At times I too don't have enough time to do my entire schedule (same reasons as yours) that I just walk away happy that the car is at least clean, and maybe the following weekend that when I can do a full schedule. I usually try to start at 7AM to do my entire regimen so the rest of the day is there for family and house errands. I try to do my leather interior during the week in the garage to break apart my regimen.
I did a search and only found a couple of posts on this and they didn't go into much detail so I apologize if this has been discussed before.
How NOTICABLE this is will be a function of upholstery COLOR. Dark blue and black won't show much besides LINT, unless you go looking for FADE and such in the inside corners.
Light beige will become dark beige over time, light burgundy will become grungy crimson, light grey will either become greasy brown-grey or dusty ash-grey...
Personally I have found that a good soaking of genuine ScotchGard does make even regular dust/dirt a bit easier to brush/vacuum out, but it is not mandatory. As long as the upholstery is reasonably new/ unsoiled a shampoo is not needed, just a thorough brushing/vacuuming. It's "longevity" depends MOSTLY on dirt accumuklation. If the the seats stay mostly clean (by avoiding all the obvious stuff) the ScotchGard will last around a year. If you have to vacuum weekly to keep form noticing the "mess" you will probably need to re-apply quaterly...
Thank you for your clean input
I use it with a microfiber cloth. You can find those in the same section.
Sean
Since auto interiors are somewhere between, I try to get by with a vacuum & spot cleaning. If LOTS of soiled areas are present I would shampoo the whole thing and start over...
Hope that helps.
Side note - I think they are based in Virginia and there was one of the GURU's named Bret Frazier with a picture......HEY? doesn't Edmunds own BRETFRAZ live in VA and seem to be the local detailing GURU? Coincidence???????
Seriously gurureports.org, great info, keep up the good work to make my life easier. Same reasons I love Autopia car care and Classic Motoring and still come here to Edmunds for more info gathering and sharing.
The problem I'm having is that any kind of dirt seems to bond with this wax. The car seems to get dirty really fast with it and the dirt does not want to come off. Even at a coin-operated car wash with a pressure washer the dirt will not budge. The only way it comes off is with a hand wash. Of course, before I scrub it off (and around and into the paint) I'd at least like some of it to rinse off with water.
Am I doing something wrong? Any other wax suggestions? I don't have time to do clay, cleaner, wax, polish so a one-step product is imperative.
Thanks!!!
Oh yeah, the 303 is great!
z7 wash,
clay
meguiars #58(or 53-the dual action stuff)--no orbital buffer
dawn wash
3 coats of z2...heres what i got...
people turning their heads, coming up saying like the new car, what do you use for wax, all the stuff you z heads have heard before. the stuff is absolutely fabulous. no rain in site down here for another week. i posted earlier about the z5. has it been out long enough and/or have any of you used it enough to say its better than the old stuff to any appreciable degree? i used my last ounce of z2 and last clay bar so have to place another order. now if i could only get mercedes to put better paint on their cars. ive got a black slk320, 2 years old, looks brand new, thanks to z
I've been reading ALL the posts in this and the other wax forum and know one has touched on this topic. I'm looking for a way to get my new Forester through the winters here in the Great White North. Winter here lasts a good four months. (Spring and Fall aren't that warn either) They salt and sand the roads. It can be -22F to -40F for weeks at a time and if you do wash your car there's a good chance you won't be able to get back into it because it will freeze like a big ice cube. I'm planning to have the Forester oil sprayed sometime soon to keep it from rusting. It's a messy business the over spray will attract a lot of dirt and is a bear to remove. It also gets in every crevice of the car.
What's a good strategy to clean the car after the oil spray? It seems that your car is never the same after. You can clean the exterior but dirt always collects in the door jams, under the hood etc. its a thick gooey mess and sticks to any cloth or mitt you use to wash with. Is there a foaming grease remover I could use? HELP.
Any other tips or hints on this topic would be greatly appreciated.
Having a car you care about is a horrible thing.
how about kerosene? my bro use to use this on his car to REALLY remove the grime on his white car due to heavy diesel-smoke staining on his car paint. HUGE difference after. i'm sure kerosene will remove the oil. just make sure u have a good supply of rags. try on a small section of the car first of course. this will remove everything wax and all so a good waxing (and the other steps mentioned here) would need to be done after.
1. Can I use my water blade when using this or must I using towels? (I have only used terry so far followed by a flannel cloth)
2. Can you let this stuff on your windshield and window? (I've worked hard at avoiding this)
As for the knowlege sharing get together - we can do it at bret's and we can try to use up the hundreds of bottles of car care potions he has!!
I have Sierra Nevada in the fridge so bring something different. Ribs sounds terrific to me. I drove thru Illinois last week; should have stopped and bought some corn straight from the fields.
I don't own a machine ... we'll be applying by hand.
Any special precautions to take, after I inform
the coroner of the location of the culprit`s body?
As for the etching, I know of no product or method that is hand-applied. To remove acid rain damage it always takes a machine and an experienced operator. Sorry.
Just remember to wear gloves, a ski mask, and pick up all shell casings before leaving the scene.
Good luck. Let us know if the vinegar trick works for you.
http://www.homemadesimple.com/mrcleanautodry/index.shtml
The "water sheeting polymer" is probably something MUCH CLOSER to Downy fabric softner than Zaino -- techinically Downy is a kind of "wetting agent" that (among other things) lowers the surface tension of water so that it sheets off instead of beading up -- perhaps a good water to make the product "self drying"...
This is a Proctor&Gamble product -- it won't be cheap.
