Store Bought Waxes Part II (No Zaino Posts)
1596062646577
    I agree with you that one of those 3 step kits might just be the ticket. You can use all 3 products on the Honda, then use just 2 products, the glaze and the wax, on the Audi. Keep the polish as eventually you'll need it too.
    To answer your "#20 vs #26" question, I think #20 would be the better choice. It has a mild cleaning ability which would be fine for a new car, plus its more durable. The #26 needs a prep step (or more) prior to its use. And use Dawn if you have it. If not, a good auto shampoo is fine.
    As for dealing with interior smells, I use a product similar to Febreeze and I'm not too thrilled with it either. If your interior is especially smelly it may need pro help. Many detailers use odor foggers and the best equipped shops use ozone generators. It may be worth the $$ to have a pro detailer deal with the interior smells permanently.
    Final Comment - Swirl marks usually are caused by poor maintenance rather than poor polishing/waxing methods. You can greatly minimize swirls by simply hand washing your car with care - Use only new 100% cotton chenille mitts or pure lambswool, use the Two Bucket Method while washing (one bucket with soap and water, the other with plain water, after soaping a section of car dunk the dirty mitt into the plain water to wash it off), do not allow water spots to form, dry your car safely with waffle weave microfiber towels instead of an old chamois or old cotton towels. Staying away from commercial car washes and using proper washing techniques will make a big diff in the Swirl Mark Wars.
  • sdradioguysdradioguy Member Posts: 101
    I spent the afternoon going between properautocare.com, Meguiars.com, and Mothers.com. There's a lot of good advice on all three (particularly the "non-partisan" properautocare site).
    I've decided to try the Mothers 3-step system (without the claying). I'll use all three on the Honda, and just the final two on the Audi. Mothers says its sealer and glaze - the second step - is formulated to be used on top of existing waxes, so I wouldn't necessarily have to strip anything off the Audi. And I'm all about saving steps.
    If I were dealing only with the Audi, I'd probably try to find the Klasse cleaner polish, or Meguiars #20, and just use that one product. Both were praised on the properautocare.com site.
    Now I gotta figure out where to find the best microfibre towels for the money, and what cleaner/conditioner I should get for the leather. Anyone else with leather seats in an Audi care to make a recommendation here?
  • atoewsatoews Member Posts: 637
    Light, dark or medium?
  • mralanmralan Member Posts: 174
    Medallion Premium Paint Cleaner is by far the best paint cleaner I've used by hand. I know people who got fantastic results with AIO and GEPC/SEPC with a machine, but by hand MPPC is the way to go!
    The Honda is "Milano Red" (signal light red). The Audi is "Dolphin Gray" (dark gray).
    There are some good leather care products on the market. I'm partial to Eagle One; Mothers leather products are really nice; Pinnacle's leather products at Properautocare.com are awesome but expensive; Lexol's products are OK.
    Also lots of good outlets for microfiber. Properautocare's towels are excellent if pricey. Have a look at http://www.waynestowels.com for great quality towels at affordable prices.
  • reblack_jrreblack_jr Member Posts: 57
    Yesterday I started winterizing my car's outside surface. I "Dawned" it and then "clayed" it with Mother's Clay lubricated with Showtime Instant Detailer. I am partially through the waxing process Mother's Carnauba Cleaner Wax (part of kit purchased at PepBoys). Should I apply another wax on top of this before putting it back into the elements?
    This was the first time using a clay on my 2001 Subaru Outback. I did not seem to pickup much "stuff". The surface seems smooth and clean however. Is there any special process in applying the detailer? I kept the surface pretty wet with the detailer that was eventually wiped off and then cleaned away with the cleaner wax.
    Thanks in advance for the comments.
    I see no problems in your process. You can apply another "coat" of wax but all that will do is even out the shine and protection, not add more. Don't forget to put some wax on the wheels too. They can really use some protection from the road salt and ice.
    I thought I had my mind set on using some Mothers or Meguiars products. But I came across several good comments on this board about Stoner products (particularly the Speed Bead), so I thought I'd give that shot. I mean, what would I have to lose by experimenting on an old Honda?
    Overall, I'm pretty satisfied with the results, although I'm not sure Speed Bead got the paint as clean as it could be, even with all the dirt that came off on the applicator. If you look VERY close and at the right angle, you can still see some water spots and other tell-tale signs of the car's age.
    I don't know if all age and water spots would be wiped out with one of those "3-step" methods or not. I was trying Speed Bead to see if the one-step approach would work to my satisfaction, and it pretty much did. It minimized the appearance of some not-too-small scratches in the paint. And the car really does shine. I put two applications on hood-trunk-roof, and it seemed to make those surfaces smoother than just one coat.
    I made another trip to Pep Boys for Stoner's Trim Shine and Invisible Glass. The Trim Shine works well, but removing it from paint or glass can be a pain. The Invisible Glass foam-like spray is easy to use. It takes less time to remove and seems less likely to streak then normal liqud cleanears.
    I'm still not sure if I'm going to use the Speed Bead on the Audi. It didn't perform any miracles on the Honda, but that's an 8-year-old car that has spent almost half its life outside. Anyone else use Speed Bead on a new car, particularly a German one? Would I be cutting too many corners if I used it on mine?
  • just4fun2just4fun2 Member Posts: 461
    Not sure what the difference is in a German paint job vs most other cars. I think that you should have use a clay bar first and then applied the Speed Bead.
    My van is a 2002 and I have used Speed Bead for about a year and a half and the paint is flawless, no water spots. I just put Bead Max on about a month ago, it says that you can dry your car off by driving it. I washed it last week and took it down the road 4 miles at 40 MPH and everything was dry except the back hatch area. The roof, hood and sides were dry, just the back hatch needed some wiping. I believe that if I would have driven it longer or on the freeway, it would have been completely dry.
    Bead Max won't clean you paint, Speed Bead will clean you paint, but you should use a clay bar if the finish isn't clean and smooth.
    bretfraz, how's the new products working out on your new truck?
    The S100 is looking great on the truck. I've been letting one coat of it ride on the horizontal surfaces but have put an extra coat on the vertical surfaces just to play with it. With the rain we had today I could see the product had beaded up nicely and I watched it blow off completely at highway speeds. For $15 this wax is simply killer.
    I've applied Mothers Clearcoat Wheel Polish on the clearcoated alloys and that seems to be doing well too. Hard to tell though as the Sierra does not shed its brake dust all over the wheels as my Saab did.
    When it warms up a tad I'll do a P21S wash and have a closer look at the paint.
    Recently ordered 2 more jars of S100 ... love the stuff.
    Presently, my favorite products are MPPC, Vanilla Moose, S100, and Final Detail.
  • sandman46sandman46 Member Posts: 1,798
    Where can I purchase this stuff. I live in the Ft. Lauderdale area.
    The Sandman :-)
    Many Harley Davidson dealerships carry it, although not the ones in my area. I had to order it online.
    http://www.properautocare.com/s1carpaswax.html
    It's a pure wax with no cleaning abilities, so make sure your paint is well prepped first.
    I washed the Honda yesterday for the first time since using Speed Bead on it. The dirt came off effortlessly, the water beaded impressively, and the car quickly wiped dry with no streaks. Not bad for a product that doesn't require a whole lot of effort.
    I was still wondering what to do with the Audi when I realized Audi sells it's "own" line of car care products through its accessories catalog. The catalog also mentioned its dealers carry 3M products, so I took that as a tacit endorsement of 3M. Besides, how could you go wrong using Audi-branded products on an Audi?
    I stopped by Metro VW/Audi today. While the parts department didn't have any 3M products, it did have all the Audi washes/waxes/polishes/cleaners, etc. There was also a full line of VW products -- identical to the Audi products, but anywhere from one to five dollars each less expensive.
    I grabbed the VW polish/wax, detail spray, leather cleaner and leather conditioner. Each product clearly states on the back label that it was made by Eagle One (I imagine that's the case for the Audi stuff, too. The packaging is the same, but the bottles do not divulge the company of origin). Prices for the VW products are very close to what the Eagle One products go for in auto parts stores.
    I tried out the leather cleaner and conditioner this afternoon. The seats (which had never been cleaned or conditioned) must have been awfully thirsty, because they really drank up the conditioner. There wasn't much excess at all to buff out.
    Tomorrow, I plan to try the polish/wax. I'll let you know how it goes.
    The repackaged Eagle One polish/wax sold under the VW brand name is good stuff. I can really tell the difference in the way the car looks, compared to whatever wax the dealer used before delivery.
    Before I used the polish/wax, I used some Meguiars Scratch X on the decklid. I wanted to erase some scratches I accidentally left when the car was 2 weeks old. It took about 4 or 5 applications to get the scratches minimized to the point where I was sorta satisfied. To be fair, these were pretty deep scratches. Luckily, they don't show up unless you look at a certain angle. And, after several applications of the "X", they are much less noticeable.
    So, I guess I've learned that Eagle One products are good (as if there were any doubt). After I use all this stuff, I'll probably try one of the 3-step programs. Or maybe I'll clay the car sometime early next year. I don't have to decide right now. I'm just happy to have a good wax job on the car before winter.
    Keep us informed with an update now and then as to how both car waxes hold up.
  • 747pilot747pilot Member Posts: 38
    I bought a can of Scotch Guard so I can protect my carpet. I have used this stuff before so I did not bother to read the can. I sprayed away and after I was complete I read the back of the can. I did not know this but apparently they have a blue can that is soposed to be used for carpets. The red can is for fabric.
    In a panic I went out and sure enough they have a blue can for carpets and auto's. I bought it and the only difference I can see is the blue can sprays it wider and it is more foamy whereas the red can is a mist. I personally prefer the mist of the red can.
    Did I just perform a big no no by spraying my carpets with the red can?
    My second coat was done with the proper blue can. The carpet looks fine. I would like to believe that the only difference is the red can would be less affective on carpets because of the application process.
    I'm thinking of purchasing a California Car Duster.
    Does anyone recommend it?
  • tmarttmart Member Posts: 2,398
    Yes, it works as advertised. Also get their Dash Duster too. Both are great.
  • amheckamheck Member Posts: 37
    I was in WalMart last nite and they have the California dusters. The full size plastic handle version is $9.99 and the dash sized one is around $6.50, I think. I picked up the little one to give it a try.
    Aaron
    I was on my weekly die cast model car hunt at Big Lots when I discovered some bottles of Zymol Protectant for $2.49. I like to use it on exterior plastic, vinyl, and rubber. It gives the trim a nice satin sheen. Needless to say, I bought quite a few bottles...
    My truck's paint is in very good condition.
    Would a buffer be a good idea for waxing and polishing, or is it mainly a tool for removing imperfections?
    If you recommend a buffer, what kind? what wax and polish do you use with your buffer?
  • hokiehankhokiehank Member Posts: 1
    I just bought a new 4Runner in dark blue (stratosphere mica). I have read through this forum and I am a bit confused on what to do. My priorities in order are car protection, ease in both time and application, aesthetics, and value.
    What should I use (car wash?, polish?, wax?, etc.)? Many thanks for any help!!!!
  • 4x4bully14x4bully1 Member Posts: 8
    Finally a product to remove marks on plastic trim that is easy to use and no toxic chemicals involved.
    I tried it for the first time and all the black marks on the sill trim panels simply rubbed off.
    Read the instructions, though, not intended for glossy or shinny surfaces. You will also be amazed at what it will do for the flat paint around your house. It looks like a fresh paint job after scrubbing with the eraser.
    I highly recommend trying this product.
  • rs_pettyrs_petty Member Posts: 423
    Nice truck and congrats. There probably isn't one single recommended product that covers your priority. There is a tremendous amount of products, especially "boutique" type products, that will give you a tremendous finish. It is the work-result-cost equation that makes recommendations hard. Only you will know if the work and cost is worth the result with a certain product. You may want to check tundrasolutions.com and see what other toyota truck guys are using or browse detailcity.com, carcareonline.com, or properautocare.com for other product recommendations. If protection is #1 priority you may want to look at polymers or acrylics. Or you may be just as happy with Meguiars or Mothers carnuba on a more frequent basis. A pretty good one-step product is the Zymol (Turtle Wax) at Walmart. Another pretty tried and true combination is 3m imperial hand glaze and blitz wax. You may want to hold off until some more results are in on Meguiars new Next Generation wax (suppose to be out in Feb). Initial results I've read sound pretty good. It may be what your looking for. Hokies over Golden Bears??
  • micwebmicweb Member Posts: 1,617
    It's neck and neck, but Nufinish worked better for me. Zymol is less environmentally nasty.
    If you want something that is easy, fast and long lasting, use Speedbead from Stoner products.
    IF you like to spend all day working on you cars finish, use something else.
    I haven't had a chance to try it yet. Just4Fun2, how well does it clean the surface? In the products I tried, NuFinish is easy to use and gives a lasting "bead", but TurtleWax 2000 cleans better (but not as good shine).
    I used a clay bar on my vehicle before I used Speed Bead. That was over a year ago. I was planning to clay the vehicle every year to keep the surface clean and smooth, but I didn't have to do that. Speed Bead kept my paint smooth and clean. I use Speed Bead about every 3-4 months because it is so easy and done in a flash.
    Speed Bead has kept my paint clean, so I can't say how it would work on a very dirty painted surface.
    I just know that I don't have to rub and rub this stuff in. I lightly spray a section about 2'x2' and rub lightly. Again, my vehicle's surface isn't dirty.
    Some people like a multi-step process waxing system, that's find, for me this works and it is easy.
    I should clay my car and then see if Spead Bead thereafter is enough to keep it clean.
    My personal theory is that a good product will keep gunk from adhering so tightly to the surface, making it easier to clean the next time....but maybe the cleaning agents in Spead Bead are better than those in NuFinish.
    In searching through the previous threads on Medallion & Reflections I did not see specifically that anyone used a carnuba topper. This seems to be a trend in other forum circles. Anyone done that? Just wondering if the technique works on store bought as well as the boutique products. I'm planning to try Kit over TW Formula 2000 when the weather warms up just to see if it works. A lot of possible combinations, but thinking same manufacturer would give better results (e.x., Mothers carnuba over Mothers Reflections).
    I want to protect a new truck tool box. It's made of aluminum diamond plate.
    Can I use regular paste wax on aluminum?
  • alwaysfordsalwaysfords Member Posts: 210
    Use Never Dull on the diamond plate. We use it on fire trucks regularly and it keeps it clean and bright.
  • rjs200240rjs200240 Member Posts: 1,277
    I have put #16 on top of Medallion Premium Paint Protectant with great success. It looked great, beads great, and has been lasting for 6 weeks now in the snow and salt with no sign of letting up.
  • richinraleighrichinraleigh Member Posts: 18
    Tried my SpeedBead out this past weekend on my new 4Runner. My initial impression is very favorable. It was easy to apply, wiped off with little effort, and left a mirror like shine. Of course being a new vehicle it should be...but it did seem to enhance the shine of the clear coat. We'll see how long it lasts, but since it is so easy to apply I can do it every 3 months or so. Did the whole vehicle in less than an hour. My next application will be with BeadMax. Also, will be using the SpeedBead on my 10 year old Camry sometime soon...it hasn't been waxed in a couple of years so it should be a good test.
    I want to know if it takes off the road grime and other pollution. I have a serious pollution problem in my neighborhood - everything from specks to stains.
    Wax (speed bead included) doesn't take off road grime and pollution, it just makes it water repellant. You still will need to give your finish a nice cleaning. From the cleaning on if you keep it waxed it will always clean up better in the future. Clay it, glaze it, and then speed bead it.
    My son bought a l989 Celica for a winter beater vehicle. The vehicle is in good shape for it's age, but the paint is cracking. He used Speed Bead on it when he bought it 5 months ago and the car does shine. The car is black in color and I didn't see the car before he used Speed Bead, so I can't say how bad the finish was, but my son said that he didn't spend any more time waxing it that he did with his 03 Corolla.
    I clayed my cars and then used Speed Bead or Bead Max ( I didn't use glaze) and the finish has stayed smooth since I started using Speed Bead products.
    Two months ago I switched to Bead Max from Speed Bead, just washed the van yesterday and it still beads water like it was just waxed. I live east of Cleveland in what's called the "snow belt" so my vehicle sees alot of salt and snow.
    If you're looking to stock up on some good quality products, head on over to your local Target.
    They're selling Zymol and Meguiar's gift kits for 50% off. Both kits offer the basics; wax, shampoo, interior cleaner (leather products in the Zymol kit), wheel cleaners and a few other items. They come in those hardwood boxes.
    The Zymol kit I saw today was $17.50 and the Meguiars kit was $15.00. Consider that a 16 oz bottle of Zymol wax is almost $20 and the same size bottle of Meguiar's Gold Class polish is about $10, these kits are a screamin' deal.
    Limited to stock on hand, I'm sure, so don't dillydally if you're interested.
    This has been a Public Service Announcement from your friendly neighborhood BretFraz.
  • quesera1quesera1 Member Posts: 18
    I picked up a box of each, Meguiar's and Zymol at my local SuperTarget. I'm looking forward to spending New Year's Day cleaning the car inside and out if weather permits. The days here have been sunny and dry lately. Happy New Year.
    Here's wishing all y'all a happy, healthy, and safe 2004. Extra special wishes for those who have family and friends stationed overseas protecting our freedoms.
    Keep those vehicles shiny in the new year. Clean, good looking cars make the world a better place.
  • peta7979peta7979 Member Posts: 1
    Just got my 2004 black envoy home. what is the best product to keep black paint finish mirror like? Are waxes my only concern, or do these silicone based liquids i've seen on auto parts stores really shine up the finish?
    I personally vote for Nufinish, Zymol, or TurtleWax 2000, but it's worth reading the old messages to get a sense of the opinions on the various store bought products. I have some Stoner Spead Bead to try next.
    The other thing to consider is getting a pro to do your first wax job. Your vehicle is pretty big, it's brand new, this is rough weather. A pro will clay it, if necessary, and you can take your own product if want to use that same product in the future. If you are looking for the best store bought shine, consider having your vehicle clayed and an all polymer product like Nufinish applied, then a week later put a carnauba wax product over it. You can do the "overlayer" yourself, but be sure to use a "wax" only and not a "cleanerwax" or you will be stripping off the polymer base coat.
    Your professional should be able to tell you if swirl marks are likely to be a problem with your preferred product, given the black finish. I don't have black, but recollect hearing people complain about swirl marks on black.
    A new car should cost a lot less to professionally finish like this, than a badly contaminated older vehicle.
    Finally, you should get a good price this time of year.
    Once you have a nice start, it won't be so hard to maintain thereafter. Personally I just wax "top surfaces" thereafter, until the "sides" don't bead up as well, then I wax the whole car. My cars are in the sun, and the angle of the surface (flat top, for example) makes all the difference in the speed of contamination and durabilty of the wax/polymer.
    Oh yeah, one mistake I have made is to "not clay." Even a new car picks up crud in transit etc. It's worth claying first, or else you are "finishing" the environmental crud, waxing over unremovable dirt. Clay Magic at Walmart works swell.
    Because it strips off prior wax (so do the cleaners in "cleaner-waxes" and "cleaner polishes", so this step is somewhat redundant). Thereafter, of course, don't use Dawn, use a car wash product that states it doesn't strip wax. I bravely go where most other list posters don't, through a drive through car wash, which hasn't scratched, swirled, or removed wax, to date.
    Speed Bead by Stoner products is what you need to make that black shine. My son has been using Speed Bead on his dark blue car for over a year and half now and it looks like new still. And, yes, it does shine!
    I too suggest using a clay bar even on a new vehicle first before using anything you decide to use. Stoner products are available on line and at some retail stores. I called Stoner and my order was at my door the next day!!! Speed Bead is in a spray can and is about as easy as it gets. Spray on, rub lightly, let it dry and wipe off, very fast to use and lasts for months.
    A pet peeve of mine is when polymer sealants are called waxes. I don't even like the term "synthetic waxes" when applied to polymer sealants.
    My question: Is SpeedBead a polymer sealant, a wax or both?
    Also, an ad for SpeedBead said it removes fine scratches.
    Does that mean there are abrasives in it?
    I don't see how it can remove fine scratches, unless the "scratches" are just swirl marks from an earlier wax job.
    The Spead Bead kit ($20) includes Bead Max, which has NO cleaners at all.
