Visitor Agreement.
After reading so many great comments on P21S and S100, I ordered some. I have always been using Mequiar #26 yellow wax in the past and has been satisfied with the results. My order of P21S came in yesterday, I can't wait to try it this weekend. My question is that I just did the whole detailing thing for my car a couple weeks ago including claying, polishing and two coats of Mequiar #26. Can I just wash the car and put on the P21S (2 coats also) or I should polish the car again for the new wax? I really want to see what P21S can do for my black car. Thanks.
I have always enjoyed reading your helpful posts on this board and have learned a lot on car detailing from you.
1...used Macguires Scratch X.
2... MB dealer had car rubbed out by hand. All day job.
3...I applied 2 coates of NXT.
WOW! I have had many black cars but nothing compares to this wax job. So slick & deep that when washing the soap just " sheets" off.
Properly waxing your car does not remove any paint. Polishing your car, not waxing, can remove varying amounts of paint depending on how abrasive the type polish you are using. Many mild polishes can be safely used over and over several times a year with no long term damage.
These are strictly my opinion (and everyone has their own opinion) but the only opinion that counts is yours.
Most durable - Collinite
I like S100 because it is only $14.95 at any Harley Davidson dealer, nothing is any easier to apply or buff off, it does not stain trim, has a wonderful deep, wet looking shine and does not attract dust and pollen as much as some others. I can apply and buff off of my Accord in 30 minutes. If you do not have a local Harley dealer in your area I would try Meguiars #16 although you may have to get a Meguiars vendor to order if for you locally. I have not personally used the #16 but I understand from reliable sources that it is very similar to S100.
IMHO the most important thing in the whole process is to clay your car to remove contaminants to the paint (even if it is straight off the showroom floor) and to polish if necessary prior to waxing.
Claying is the "real trick." If you clay first, you'll be surprised how well NuFinish turns out. Clay Magic is availabl from Walmart sometimes.
It all depends on what your priorities and expectations are. The good thing is there are many very good products on the market nowadays so while some are better than others, there aren't too many dogs. The bad thing is so many waxes perform similarly that its hard to find the stand out's without testing and comparing them yourself.
If you're interested in an unbiased comparison of waxes and sealants, check out The Wax Test at www.gurureports.org . They tested 46 different products so you don't have to.
Can you wax too much? Perhaps, but most of today's waxes are so mild that you could wax your car many many times without noticing paint degradation. There are some aggressive products out there (like NuFinish, which is too harsh for my tastes) but most have been formulated to minimize paint wear to avoid consumer complaints.
but they want to get you roped into a monthly fee (who doesn't).
Ideally, buying a large capacity filter with a fee paid for regeneration as needed seems the way to go. Does anyone here have knowledge or experience in this area?
-David
http://www.apexcone.com/JimPowellHomepage/TechProcedures/EngineBa- yCleaning/ArmorAll.html
How about substituting Griot's Vinyl & Rubber Dressing or Vinylex for Armor All? Thanks!
Are there any abrasive rim brushes you folks are using that won't scratch? Any other tips?
The tips in that link are OK. I'd cover up sensitive electronic components and things like air intakes before using the water and degreaser. Also I'd prefer a citrus-based degreaser instead of a solvent-based one.
I detailed an engine last week and sprayed on a light coat of Armor All as a final dressing. AA is perfect for this task. Just stick with their Original Shine version and it'll be fine. The two products you mentioned would also work great.
Personally I use Klasse AIO on my alloy wheels but that is something that must be ordered online...it is not sold in stores. It is VERY easy to use and allows the brake dust to wash off easily during normal wash routine.
i will appreciate if you share your experience with the stuff advertised here http://www.5starshine.com.
do they exist at all?
i never got a response to my several e-mails and couldn't get anybody at that phone number (except autoanswer).
thanks.
I've heard others recommend barkeepers friend which contains oxalic acid as a good cleaner...
But I think the material that's used to rub has to have a texture that will grab and rip away the road film that has stuck to the glass.
Just wax the car once or twice a year...
This is just a 'pack' to pack extra cost into your purchase.
What they're probably applying is some sort of polymer sealant. You can buy a comparable sealant at a parts store for about $20. It applies/removes just like any wax.
Here's a link to Car Brite's website describing their sealant and their warranty package that's offered to dealers:
http://www.carbrite.com/servlet/com.ebiz.ecom.search.ResultsPubli- - c?st=SUB&catcd=iepr&loc=Interior%20and%20Exterior%20Prote- - ction
While there may be some chemical similarities, there are far more differences between the two product lines. Doesn't make Carbrite a bad product line but their business focus is not on the individual car owner.
You can go to a local parts store and buy something like Liquid Glass or Meguiars #20 for about $15-20 and have something very similar to Carbrite's sealant.
The Sandman :-)
The Sandman :-)
I was just at my local Kragen store to buy replacement bulbs and I noticed Meguire's (sp?) clay bar /lubricant/wax kit. Anybody have use that product before. Any other suggestions other than "Z"?
Thanks in advance.
I do wash and wax my car, but I'm not really sure what the wax is supposed to be doing. I do notice a slightly brighter look on my car, but it's not like those mirror-like finishes that detailers do with their polishes and waxes and spending hours and days doing.
