Store Bought Waxes Part II (No Zaino Posts)
Why would you want to remove the wax layer? I'm reading through these two threads (and there are a lot of posts, so I don't know when I'll get done) and I've seen people talking about waxes that are easy to apply and to take off. Why would you want to take it off it it's protecting your car? And how do you go about taking it off? How do you know if you've taken it off? Once I've buffed the wax onto my car, I can't even tell it's there.
With wax, the typical process involves applying the wax and letting it haze over. You then remove the haze - not the wax - by wiping if off.
Most waxes don't last very long - typically a few weeks at most for vehicles that live outside. Some people who are fanatics (or own trailer/garage queens) don't like multiple layers of wax because it can yellow and reduce the shine. Hence, they may actually remove the previous layer of wax before applying a new layer.
As for ease of applying and wiping off, the newer wax products are so much easier to use than the waxes of old.
Also, there are plenty of polymer based sealants that are not considered waxes that may or may not work as well as wax.
Good Luck.
Also about the detailing clays. Can you just use plain water as a lubricant before using the clay to remove the impurities and such? I've never clayed before and am thinking of getting some to test out the next time I wash and wax my car.
Clay - I use some car wash soap and water in a spray bottle. I guess you can use water. Heck, this weekend I was cleaning up a couple of little bird poop spots on my paint before applying a sealant and I was too lazy to go back into the basement for my spray bottle so I used spit. It seemed to work.
Hey Bret - you're the expert. Help my out here!!
CLEARCOATS - The easiest way to test for a clearcoat is to rub a little bit of paint polish or car wax w/cleaner on a hidden area of the car. If the color of the paint shows on your applicator, no clearcoat. If there is no color, your paint has a clearcoat. The vast majority of cars produced in the last 10 yrs have a clearcoated paint job.
CLAY - Most paint detailing clay kits include a bottle of spray lubricant. If you have a clay bar w/o the lube, I strongly recommend one or at least the use of a soap/water mix in a spray bottle. There needs to be a lubrication agent for the clay to work and not scratch the paint. Water is not slippery enough to do this. Just about any quick detail spray will do the trick, and a bottle is only a couple of dollars.
The clear coat is supposed to protect the car from the elements right, or what exactly does it do? What happens if there is no clear coat on the car (like the really older model cars). Waxing helps to add a layer of protection, right? So cars with clear coats and waxing have like double protection?
Toyota just released a TSB regarding "IRON PARTICLE RUST CONTAMINATION REPAIR" (i.e. rail dust etc.)They say "Washing the affected paint surfaces with an oxalic acid solution is the recommended method to dislodge embedded iron particles and remove the surrounding rust stains." and recommend using Auto Magic Special Cleaner Concentrate #713. The MSDS has pH: ~11 to 12
What effect will this have on the particles and paint? Will it work better if the particles are larger or smaller (i.e. before or after clay)? Will it even work at this point with a couple coats of Z or Klasse on it? Should I do it? I plan on doing the full treatment in spring again anyway (Dawn, clay, etc) but should I follow the clay with this stuff THEN dawn wash the second time and then wax? What are the GURU's consensus here?
I notice on my older car that I see what appears to be many small pinhole type marks in my hood after 11 years even though it was cleaned and waxed very well over the years. It wasn't clayed until about 2 years ago for the first time. I had also noticed this on MANY other older vehicles from family and friends and just looking when out at malls etc. Did the embedded rail dust cause this? Will the clay prevent itsince it removed most of the particles? By itself or with addition of Auto Magic?
Oh, I bought it online at autosupermart. I just thought I'd share my experience.
(Man, I sounded like a commercial)
The Sandman :-)
Am I nuts? Anyone have a better method that actually works? What's the most aggressive wheel cleaning brush you've seen that can get dirt off a textured spoke?
CR Spotless has just released a new design that will rid you of your monthly service fees- I just got one of their new units and it works awesome. They now use filters that are good for about 100 gallons, enough for me to wash 2-3 veh/wk and they last 5 weeks. Check it out!
~John
However, when the sun hits my car and I look into the reflection, I can see a lot of very very small micro-scratches. I can only see the scratches in when a light directly reflects off the car (and not from every angle). On cloudy days, the micro-scratches can't be seen from any angle. The The guy at Meguiar's said to use the scratch X product, but I would have to do the entire car. When I apply something to the entire car, I want it to make the car look better and protect. Please help with some suggestions to make the micro-scratches disappear and protect my car from future damages.
Anyway, from what I've been reading on this and the Zaino posts, those scratches are probably in the clearcoat polish of the car, not the paint. From what I understand, you have the steal car, then the primer coat, then the paint, then the polish, and then the wax.
If you wash your car with regular Dawn dishwashing soap, you'll strip the car down to the paint. You can then apply a new coat of polish that won't have any scratches in it, followed by a wax. I think it takes a long time for the polish to dry, and you need several coats, but if you're a do-it-yourselfer, this may be the way to go.
So, if I just want to use a sealant, is Klasse topped with a good carnuba wax the way to go?
robr2 - do you use the microfiber cloths to wash your car? i currently only use them to buff, but I have plenty. i am washing with a chenille mit.
No I do not - I use the aforementioned cotton towels. I also try to wash in straight lines as opposed to circles to minimize swirl marks.
As for product, I also use the forbidden #5. It works for me and as such I have not tried other swirl hiding products.
I have heard about "wet sanding" and I tried that on a small area. However, it takes forever and is a lot of work b/c I had to remove the clear coat down to the base paint before it looked OK. Then, how do you protect the paint after removing all of the clear coat?
Feel free to experiment with wetsanding to see if you get positive results, but the vast majority of detailers and pro painters won't mess with it at this point. There is no shortcut I am aware of.
Good luck with it.
Car glitters as good as new.
Then followed it up with a muscle building waxing (Gold Class wax) and removal. Didn't have the time to do one door panel.
How does the glitter of the rest of the car compare with this door panel?
No difference!
Wondering how many of you got that impression.
Is anyone else using their leaf blower to "blow-dry" their car after washing it? I got tired of chamois and chamois-substitutes.... No water spotting and much faster than chamois drying.
This is working great for me, but it's so easy it seems sinful somehow..... will I go to BMW hell for this?
By the way, I'm a longtime fan of Klasse All-in-One. It's easy to use, cleans well, and protects for a long time. I also like the sealer, but it's almost as hard to use as All-In-One is easy. I find that it's good for 6 or 7 months here in the brutal Dallas sun before it stops beading up properly...
I'm sure your neighbors love you for doing that.
My neighbor uses Downy in buckets of rinse water which he throws over his Acuras after washing. Reduces spotting.
lmifazol - Downy ?... hmmmmmm ... Really?
They did not react when told. A few months later Mr. Clean has a spray unit for purchase (a P&G brand) which uses softner in rinse water. I has the same effect as the wax that I tried years ago that was supposed to keep water from beading and causing spotting after rains: the water sheets off.
Been using Turtle Wax 2001 on my other cars but thinking of trying something more premium like Meguiar's Gold or Zymol. Any recommendations?
I went to the auto store and found a Meguiars product called Clean and Wax. It appeared to bejust what I wanted: Safe for clearcoat, Removes swirls, removes dirt, waxes to a gloss shine, may be applied to the entire car at one time - no need for a section at a time, just cover the car and wipe off with a terry towel. Sounded simple enough.
Well I worked the back end of my car first. I started an hour before dusk so I was in the shade and the car cool. I applied the wax and had to rub hard but it appeared to remove the dirt. I ONLY applied it a section at a time even though it said you could coat the whole vehicle at one time. I did the trunk and rear qaurter up to the rear doors. After wiping on and 'cleaning' I applied another coat and wiped off with a clean rag. Up close it looked shiny and clean. At one point I stepped back and almost fainted. The entire rear of the looks like it is covered in some sort of dull haze--in the paint---ie you can not wipe it off, even with a bare finger! From a distance it looks shiny but as you approach at a certain angle it looks like it has been coated with something that does not rub off. Night has fallen and it has started to rain. The water appears to bead. I am afraid of what I may find in the morning! There is a tech number on the wax bottle for whatever good it will do.
Does anyone have any experience in this area? I am really scared I will not be able to get this junk off? Should I use my trusty old NuFinish over it? It just seams as though there is a coating of something on my car that should come off first!
HELP PLEASE!
Also, I bought one of those new wands you clean your windows with....suppose to be streak free. You may have seen them at WalMart for $6. Looks like a triangle covered in foam with a handle attached. You slip a micofiber cover over it and then wet the window and rub it dry with the wand. It worked pretty well, not perfect but much less work and streaking than when I did the windows by hand. Of course maybe a simple microfiber cloth would do just as well though I do not know where you find one. Comments?
