Daniel, If you go to the meguiars website, punch in some info in their car care prescription, it will spit out what Meguiars recs: www.meguiars.com/CarRx.cfm IMHO, I don't think you probably need to use clay, a swirl removing polish, or Dawn at this point, I would jus use Meguiar's professional series car wash and paste wax to start. I'm sure others on this site can also offer some good recs. Vern
Everyone is saying wash with Dawn to remove wax. I tried it on my car that I had waxed with Meguiars, and gave up after 3 tries. It did nothing to the shine and water beading.
If you want to remove wax the first time, use Meguiars Medallion Premium Paint Cleaner.
I wouldn't worry about whatever the dealer put on your G20. You've bought all the right products and are doing it the right way. The swirl mark remover will take off most any wax or polish left behind. Dawn is good for removing oil and grease but I wouldn't use it every time I wash. Stick with the #00; it's great. Be careful with the clay and use lots of lubricant like Final Inspection. That's about it. Don't forget to write back with your results.
jster wrote :"Also according to an article I just read, a Ford rep said that clay won't remove rail dust or iron filings, anyway:"
He probably has never tried clay then. Clay removed the rail dust and embedded brake dust on my vehicle quite well. Requires some effort in some places but well worth the results.
Please read the article. He is a refinish technical specialist for Ford. I would suspect he he quite familiar with painting, and detailing automobile paint.
And notice the juxtoposition between the terms "clay compounding" and "wet sanding".
Maybe the clay just sheared off the very tiny parts of the rail dust and embedded brake dust that were protruding above the paint on your car.
I have used clay to remove paint overspray (the blue, so-called "non-abrasive" Clay Magic) and I believe that it was a very fine shearing action--not "stickiness" as some say, that removed the overspray.
Let's think about this: If clay was "sticky" enough to remove auto paint overspray and embedded metal filings, than I should probably just throw away my claw hammers and prybars, and use paint-cleaning clay to remove nails from plywood as well.
I tried it a few years ago after I bought a new Maxima and was living in Chicago. I was looking for a product that held up during the winter. I bought the 3 pc. kit which included the wash, Finish Prep, and Finish First polish. They threw in a sample of Finish Fast, their between-wax polish. I liked the Wash the best, so much so that when I run out of what I currently use I'll buy another bottle. The Prep did a great job of removing deposits, especially tar, grease, and road grime. It left a very slick surface for the polish but did nothing for the swirl marks. I was disappointed with the polish. It didn't last long and didn't shine any better than a carnauba or even the Prep. I did exactly what they told me (multiple coats, waiting time for each coat to cure, etc. etc). It was easy to apply and remove and the surface was slick but it went away after a couple washes. After awhile I stopped using the polish and just used the Prep. But after the mediocre experience with synthetic polymer sealants like Finish First, I never went back.
I ended up using the Prep to polish chrome in my bathroom and protect shower tiles. I used the 3 products on other cars with poor results. I haven't used the polish except for an occasional coat on the front of my car before a long road trip; the slick finish keeps bug residue to a minimum. After the post-trip wash the slickness is gone so in the long run it's a waste of product but I guess I'll try to use it up over the next few years. Or I'll toss it. No big deal.
jster wrote:"Let's think about this: If clay was "sticky" enough to remove auto paint overspray and embedded metal filings, than I should probably just throw away my claw hammers and prybars, and use paint-cleaning clay to remove nails from plywood as well."
1. Clay does not work on plywood 2. Most nails are much bigger than the millimeter(s) size specks of rail dust or brake dust that gets embedded. 3. The clay is very sticky...Just try it without lube. If the clay were shearing off the specks than I would still see the remains of the specks. My vehicle has a white clearcoat finish.
How do you come up with these leaps from pulling specks of metal in paint to pulling out nails in plywood? It just makes absolutely no sense to compare the two.
I read the article. Just because someone has credentials does not make everything they say right. There are many different opinions on the myriad of automotive detailing products around.
FYI, jus bought some 100% cotton Cannon Fieldcrest towels from Sams...they also stock the Poly-blend Cannon Fieldcrest towels...so look at the tag carefully... Vern
"2. Most nails are much bigger than the millimeter(s) size specks of rail dust or brakedust that gets embedded."
Thanks again.
"3. The clay is very sticky...Just try it without lube. If the clay were shearing off the specks than I would still see the remains of the specks. My vehicle has a white clearcoat finish."
Sorry, but I have seen and heard too many references comparing clay compounding to wet sanding, often by people with the credentials that you scoff at, to believe that it is simply "stickiness" pulling out metal slivers that have fused into paint.
I mean, really, what could a paint repair expert at one of the world's largest automakers (who works with and studies paint repairs everyday for years, has access to sophisticated testing equipment, etc.), possibly know about this subject? He's probably some sort of silly "engineer" or something....
What is the composition of paint cleaning clay, anyway? It's easy to say..well, it's clay. But.....
The only company I have seen list the makeup of this product is Zymol. The clay they sell contains quartz, according to their website. And obviously quartz is an abrasive.
You say that you no longer see specks in your white finish proving that it is only adhesive-type action that is cleaning the paint.
What I suspect really happens is the the shearing action of the clay does pull out a very small amount of the filings embedded in the paint, just by the physical force of the action.
What's left is far enough below the surface that you can't see it. But that doesn't mean it's not there--which is why the guy from Ford says the only way to "completely remove iron is with an alkaline, acid-neutralizing wash. Clay compounding or wet sanding will not remove iron."
Thanks for all the responses! Surprised to see so much response so quick. Hopefully all this stuff comes by thanksgiving. Supposedly shipped today via priority. The car looks clean to me but following this topic it seemed glaze/polish was needed but I guess not. Well, I will save the stuff for next time or us it on my Corolla which has plenty of swirls. I'll let you know how it turns out, again, thanks for the help. That is why Edmunds is so great! Plenty of helpful people.
I don't know what is in my clay. It is made by Erazer. I do know that when used on a non-clear coat surface no paint is removed unlike compounds and glazes. That is good enough for me.
Odd-Lot stores, the liquidator has it for $1.99 for the paste. I bought 2 cans. I swear by it and use it on my 2000 Subaru Legacy GT Ltd(Rio Red) and 2000 Honda Odyssey EX (Canyon Stone Silver). Used it previously on my 1991 Honda Accord EX (Frost White) and 1996 Chevy Blazer (Emerald Green). I apply Meguiars Gold on top of the AutoFOM. AutoFOM twice per year, Meguiars 4x per year.
Recently, I saw this idiotic infomercial on television talking about this polish that lasts for a year named DuraShine (don't be confused with DuraGloss.) Their infomerical sounded too good to be true and it's hard to believe. They claim that you won't need to wash your car for a year, just hose it off clean and it will dry without waterstains. Did anyone try this product yet? Is it a miracle or just a joke?
I finally did it - backed up into a white car with my new black car, leaving scratches and white paint on my rear bumper, which I believe is plastic (2000 Lincoln LS). Any suggestions on a) how to remove the white paint embedded in the scratches, and b) how to remove the scratches? They are not very deep, but definitely noticable to the touch.
First think to try is clay. I've used clay to great effect when this happened to me. If that won't work, you'll have to use a polish. The polish usually has some "grit" to it. Then follow up with wax. If you can feel the scratches, then you'll have to use touch up paint.
Touch up paint is a risky proposition. I've heard people that have used the "langka" products, but with mixed results. In addition, the odds of the "touch up" paint perfectly matching the paint on your finish, is rarely acheiveable.
Short of a "re-paint" where they can blend the colors, you may make the scratches look worse rather than better by trying touch-up paint.
Save you money. I tried Durashine and I'm disappointed and out the money I paid for it. It doesn't leave much of a shine, seems to offer no protection, and I have doubts about their sheeting action protection. "If it looks too good to be true, then it is." I rather see water bead. I am an AutoFOM user, the product sold on the infomercial with Dennis Weaver. Extremely high gloss, easy to use, and most durable finish I have seen. I've tried many different sealants and waxes over the years. Never tried Zaino because I don't have the time based on their instructions.
Actually, I incorrectly posted that Odd-Lot had AutoFOM. The store is Odd-Job Trading, Not Odd-Lot.
what is the total number of times that you have clayed your bumpers-and is there any difference in appearance from the unclayed areas like your hood? Also, what is the "fisheye" efffect in the carwash.com article? For my recently repainted fender and door, the autobodyshop said to wait 3 weeks before waxing. Sounds short according to the article. I have seen a recommendation for 3M Imperial Hand Glaze that says it can be used for the first 30 days after refinishing. And I would like to put some kind of protection with all the rain we've had lately.
I finally quit using the Pinnacle Souveran carnuba wax. Too many problems in the humid Hawaiian weather. Hazing, streaking. The car always looked fantastic right after I waxed. No streaking even when I'd do a final dusting with miracle cloth. A day or 2 later I'd get hazing or even if no hazing occurred when I'd dust the car off, the wax would streak. I'd then have to spray water to bring back the clean shine. The streaking was continous, no matter how long after the waxing or how many car washes. I tried baking the car in the sun but it didn't help. It was too much work.
Last Sunday I used Meguiars Show Car Glaze and then waxed with Meguiar's Premi
Last Sunday I used Meguiar's Show Car Glaze and waxed with Meguiar's Premium Paint Protection. That was the advice I got from Meguiar's Car Clinic to achieve a great shine. Monday morning the car still looked great. No hazing. Also when I wiped the dust off the car there was no streaking. Will Meguiar's PPP last as long as Pinnacle Souveran Wax? Probably not, however I won't have to do a major buff down every time I take the car out. Thank goodness!
This is a term used to describe paint that has a very uneven appearance--it looks like numerous "pinholes" in the surface. I guess you could describe it as a condition caused by an uneven adherence of spray paint to a body panel. It is caused by painting a contaminated surface that hasn't been prepped right or even by a contaminated painting environment.
Silicone can particularly be a culprit in this way, because it very easily penetrates paint and tends to bond very well to body panels. However, there are chemicals which can remove any silicone from body panels, prior to repainting.
Clay:
Probably the most I have clayed any one section of a car's body is only two times (this is in about a years time). I haven't noticed any difference in paint thickness--but then again if the clay is removing any paint at all--it would be far, far too little for me to notice--even it it were a relatively large amount of paint.
I am told and have read that clay either removes a.) no paint, or b.) very little. Depends who you ask. To me it seem like the purpose of the lubricant is to provide a very thin layer of protection and lubrication--just enough to remove any contamination (high spots) without much touching the paint (provided enough lubrication is used--along with very little pressure). I am comfortable using it infrequently to remove various contaminants. I am not comfortable using it as a general paint cleaner, but others disagree.
Waxing after repainting:
Seems as though there are many different answers to this question, as well. In the article you referred to the Ford guy says:
"Waxes and sealants can be applied after refinish repairs, but detailers should wait 60 days.
Which would seem to be a little contradictory--and I have heard other answers as well.
I guess if it was me I would tend to play it a little conservative and wait a longer amount of time--then again your bodyshop should be familiar with their own paint--so it's tough to say.
One thing--3M Imperial Hand Glaze will NOT provide any real paint protection. IHG is a "pure" polish (the label says "Stoddard Slovents", which is a mineral spirit based cleaner, and mineral oils). It is often used as a "finish polish" by professional painters and detailers after machine buffing, but it provides no protection.
Thanx jster for your response. I did not have time to wax my car even once before my accident and I don't know what the dealer put on, so I was concerned about the fisheyes. It is geting close to four weeks now and no solvent smell(and no fisheyes) from the refinished area so maybe I'll do something over the T-day weekend. On clays: I guess paint must have pretty large pores for the industrial fallout to stick IN to paint like it is diagrammed...Anyway to practice, I used clay on the loaner from the autobodyshop-someone had driven in a puddle of green paint, it had splashed on the rocker panel and would not wash off. It worked very well, left the white paint very smooth, even though I started with the wrong bottle-Vinylex for a lubricant. I could see the green specks in the clay, no white even though the loaner was 7 yrs old. Also went much faster with the supplied (Mothers) lubricant. Hotrod20: Checked one small Redline store and wasn't too impressed with the array, however should you need any of the 3M products the Napa stores carries them. Please let us know how long the Meguiar's stuff holds up in our Hawaiian climate.
The main reason I was interested in DuraShine is because of how water sheets off and no drying is nessasary. I was wondering if AutoFom requires drying or does the water just slide off. Thanks!
Don't fall for that Durashine - no drying required crap from their infomercial like I did. I still have more than half a bottle lef that will probably go unused. It did not leave any shine or protection.
I wonder how good it is for a paint to have the sun heating it through a water bead.The water act like a magnifying glass , it is not better to do everything possible to avoid this situation ?
wrote:"I wonder how good it is for a paint to have the sun heating it through a water bead.The water act like a magnifying glass , it is not better to do everything possible to avoid this situation ?"
That's what the guy on the Durashine infomercial says too. He is right. It is harmful to have sun heating water beads on paint.
No matter what product you use(wax or polish), if your car dries out in the sun after a rain, especially dark colors because they heat up faster in the sun, the water beads that are burned off and evaporate will leave behind some kind of environmental impurities. How long you leave these on your car without either washing or using a quick detailer product will be a major factor in determining whether they become very hard to remove or even become permanently etched in the paint.
Maybe if Durashine worked as advertised it would be a good product. I saw little or no gloss and no protection. Even worse, the bottle directions even state that you may need to hand dry areas but they "never tell you that in the infomercial".
Bret gave you some very good recs, I will post what I am using and what I have heard is good.
1)Currently trying P21S Paintwork Cleanser + One Grand Blitz Wax- I am pretty satisfied with the results, easy to apply, leaves a great shine. (P21S Carnauba Paste Wax also rated high)
2)Malm's Formula 10 Polish/Glaze + Malm's Carnauba Wax- Waiting to try this combo, one edmund's poster claimed this was better than Zaino.
3)Collinite Marque d' Elegance Wax- Have heard that this is a very good product.
4)Finish First & Klasse- Have heard that these are a couple of good polymer products.
Which is better? They probably are all very good products...which will make most people pretty happy with the results...surely better than any mass market product like Kit or Turtle Wax.
wrote: "2)Malm's Formula 10 Polish/Glaze + Malm's CarnaubaWax- Waiting to try this combo, one edmund's poster claimed this was better than Zaino."
I believe you are referring to post # 10 which was followed by post # 20 in this forum. That poster retracted his statement that the combo was better considering the effort required by Malm's.
If I am wrong and you are referring to another post about Malm's please provide the post number.
Joe, Yes, #10 was the post I remembered, but I never saw response #20 until you mentioned it...so guess I will jus have to say Malms is one of the premium wax products available. Vern
I wanted to warn everyone away from a particular brand of towels...I purchased a pack of 100? Cotton Terry Towels from Darra of California, and I must say that I'm very disappointed in them. I have a black 2000 Monte Carlo, and I've been trying like h*ll to keep it clean (the only "problem" with black). I've noticed that after the last few months of washing and using the Meguiar's Quick Detailer (love that stuff!) that I started getting really fine scratches (I guess some will call them swirl marks). I figured they would go away when I used Step 2, the Meguiar's Polish, but no avail. I recently received a part that goes in place of my front license plate, and prior to putting on the car I wanted to use the Step 3 wax to protect it. Well, when I went to wipe off the wax, using these towels, I left a sh*t load of scratches behind. I could not believe what the towel did to the finish, even with the thin layer of wax! I looked a bit closer at the package, and it says "made in Pakistan". I recall reading in here that only 100% cotton made in the USA should be used because of our quality standards...well I guess there may be some truth to that. Please don't make the same mistake I did. If anyone has any good comments to make about these towels, I'm willing to listen...or if anyone recommends anything to replace them...
Also, can a chamois be washed in a washing machine? Mine is getting a bit dirty, and I don't want that ruining my finish. I guess my question is, what is the best way to clean a chamois?
Does anyone have an experience with the new clay from Meguiar's? I like their products, and I would like to continue to use them if I can.
You can put a chamois in a washing machine--but I'm not sure it would get it all that clean--or that it would be the best thing for the chamois--clothes detergents are pretty harsh, and would remove some of the oils from the leather.
It's usually recommended to rinse a chamois after every use--if it gets dirty probably the best thing to do is hand wash it in some soapy water like a sweater.
Whatever you do, don't put it in a clothes dryer.
If you are a fanatic--probably the best way to keep a chamois clean is to keep it away from the areas that might not have gotten 100% clean when you washed the car--air dams, wheels, door jambs, inside trunk lids. (probably not the answer you were looking for.)
Just use a separate towel for those areas--also you can pretty much just let those areas air dry--especially if you aren't planning to wax the car afterward.
In the harsh winter where I live I never use a chamois--just towels--because it is hard to get the car 100% clean in those conditions. Towels are a bit safer.
IIRC, Griots Garage use to sell some kind of Chamois cleaner/conditioner in their catalog--might be almost as cheap just to buy a new chamois, though.
Towels:
You are not the first person to have a problem with towels. I'm not sure that even a "100% cotton, Made in the USA" label is a surefire guarantee that towels don't have some polyester blended in.
Also the stitching in most towels is polyester, which some people claim can also cause scratches.
Again--if you are a fanatic--I ended up buying Fieldcrest Towels at an outlet store near me--then cut off the embroidery and stitching. Makes a unbelievable mess in the dryer because of the fraying and tangling--but I have had my current set for more than two years and they still work well. They are definitely a little smaller than what I started with, though!
Kind of expensive and maybe a little crazy--depends on how far you are willing to go. You will get quite a look from your wife or girlfriend when she sees you buying premium towels--for your car--and then start cutting them up!
Also with towels--it is a good idea to wash them once or twice before you use them. Silicone "sizing" is used in new towels to make them fluffy looking--supposedly this is also a "scratch hazard".
I used to use a chamois (shammy? shaa-mowah?) for many years. They always got grungy so I bought a new one every year. Used every technique I could think of to keep it clean. Never worked.
Now I use The Absorber. No, it doesn't work quite as well as tanned deer skin, but it can be machine washed, its easy to store in its little tube, and comes in wacky colors. Also, at $12 each, if its runied my bank account doesn't suffer. I have two Absorbers; yellow and purple. I use the yellow one on normal sunny days. The purple one is used when I'm in a weird mood or when its cloudy. I'm hoping I get a green one for X-Mas.
Use Cannon Fieldcrest Royal Velvet WHITE Towels 100% USA cotton. Can get irregulars fairly cheap here. I have gotten good prices at Linens and Things too. Cut off all the edges and re-sew using cotton thread to prevent fraying when washing.
To all - thanks for your input on the towels! I've been reading these posts just before I purchased my car...I even started with the first list and worked my way over to the second. I've read lots of good things about many prodcuts in here...and because of that, I settled on the Meguiars...I really like that Quick Detailer.
Spent three hours on Saturday cleaning my car using Meguiar's car wash, swirl remover, and yellow wax. I like the results. i was a little worried at first about the streaks but i was able to get them out with some buffing. happy with the results, looks as good as new, literally. since i have silver i don't have the real nice shine
Cloth diapers can still be bought. Go to a big department store, Sears or JC Penney's. Their catalog will always have them, even if they're not on the store shelf.
How reliable are detailers? I've fished up the web page of one local to me, at www.waxmycar.com. Are their services and prices anything out of the way?
Detailers provide a service and like any service, quality of work and results can vary greatly. Most detailers will do the basic job well. It's the, uh, details that make one detailer stand out from another.
My suggestion is to ask for referrals from friends, neighbors, co-workers, etc. Just like you'd ask for a referral for a plumber or landscaper. Usually the best detailers are found word-of-mouth, like any service provider.
FWIW, a company car was recently detailed by a local operator for $150. They were found thru the phone book. I was disappointed by the attention to "detail". The basics were done but there was plenty of leftover wax and some of the hard to get parts like the lower air dam were not polished at all. I rated it a 5 out 10 for quality. Yes, the car was clean and waxed but not detailed.
When I wax, I notice two problems keep cropping up:
1. Build up around plastic parts and logos. 2. Patchy look after a wax job.
In the first situation, I guess I have to be careful applying around plastic trims. How do you folks avoid getting wax over trim and unwanted wax build up? The stuff is a pain to remove. I eventually remove it using Mother's Back to Black.
I am not sure what's causing the second problem. Too thick of a coat? Uneven application? I try buffing out the patches, but it just doesn't work.
Worse yet, I recently purchased a black car, which means everything shows (black isn't my color of choice, but color is further down my list of priority when I buy a used car).
On another note, what's the most durable product out there? So far, I have had my best luck with NuFinish, but even that gives out after a couple of months. I recently notice a product call Prolong Paint Sealant and claims to last longer than anything else on the market. At $20, this seems extremely expensive. I also recall the name Prolong being attached to some lawsuit involving engine additives.
For the first problem the easiest to do is just take more time around emblems and trim. I never actually run the applicator over the trim - just around it. Try an old toothbrush to remove any buildup around emblems. For trim, wipe immediately or keep a cloth and vinyl cleaner handy and use it to wipe the places you touch. Particularly difficult places could be masked off - use the blue kind that won't leave a residue. The most probable cause of streaking is because the paint needs polishing. If you are using NuFinish then you aren't getting an even application and the streaks are the duller paint left behind. The solution is to polish first and then wax. Technique is everything. This will vary based on the products you use.
Definitely works. It fixed the white spotting i got on my trim after waxing that you see in this photo of my car post waxing:
The stuff on the sideguard in front of the front door-that's what you mean? Now it's nice and black again. Tire dressing makes it shiny, although also makes it a dust magnet.
Around the emblems, etc i am just careful, and i fish out extra wax with a corner of the towel. I guess a q-tip would be better.
The reason pb works is the oil breaks down the wax. It also conforms to the rough surface of the vinyl enabling it to reach all the little pockets of wax. Then it just simply washes out. Any wax remover will do the same thing.
Vern
Vern
"1. Clay does not work on plywood"
Thanks for the info.
Thanks again.
But hey--believe what you want.
Michael
Thanks in advance!
Larry
Clay:
Michael
P.S. Also, is AutoFom safe for clearcoats?
Good Luck,
Vern
Vern
Thank you for your suggestions of the best wax. I am planning on trying the Malm's sample Carnauba Wax as well as their glaze. Once again, thank you!
Michael
Towels:
http://www.carcareonline.com./wash_car.html
http://fieldcrest.com/servlet/Product.GetProds?catName=Bath
Here are the cheap priced towels.
Anyway, thanks again!
Brenda
Brenda
Paul
Wonder if crunchy scrubs better? ;-)
Pat
Pat: gotta try the crunchy.
dave
Pat
