Store Bought Waxes Part II (No Zaino Posts)
Someone else probably knows the exact answer to this!
Ah, mountain-fresh dawn... That's a nice thought! :-)
Pat
Sedans and Women's Auto Center Message Boards
Thanks for the advice. I'll remember to use the rubbing alcohol.
Some people just don't like using abrasives on a paint job--or some may have already had their clear coat seriously compounded once or more, and feel that any more abrasive polishing will be removing too much paint.
And as you say machine polishing can be great--and an orbital is pretty safe--but it is possible, even with an orbital to do some damage on edges and the like--so if someone's never used one before--I don't know if it's a good idea to start practicing on a 3 year old Mercedes. I'm a little conservative, I guess.
-Larry
However, it WILL remove all the wax on your car, so be preared to re-wax.
DO use Dawn or any other dishwashing detergent when you want to get rid of all the old wax, etc. on your car. If your car is going to get painted, or if you want to put a fresh coat of wax or polymner sealant, make a very strong solution of dishwashing detergent and wash the heck out of your car!
However, teflon is NOT going to stick to your paint, or engine or tranny (at least not with a hand applied product or a bottle of engine stuff).
I found an old bottle of Turtle Wax (copyright 1991) that advertised that it was a TEFLON wax, but this was just a fad. Get a bottle of Meguiars #20 Polymer Sealant. I think that is a very good long term treatment for a paint job.
Although it doesn't fit the parameters of a "Store Bought Wax", it can be ordered online from several places.
and at best all you would get is $100 if it did not work.Has anyone tried this stuff?
I would say if you pour pure, concentrated vinegar on your finish it probably WILL cut the wax. I wouldn't advocate that. But I also wouldn't advocate using any kind of detergent on your wax job at all - it just hurries your next wax job up. But, hey, a lot of folks just LOVE to wax their cars and won't be denied the pleasure. More power to 'em! I prefer to spend my time doing other things. Like I said in a previous post - avoiding any kind of detergent - my wax jobs last all year long and my truck sits outside (not garaged).
All I'm advocating is that folks TRY washing their car without soap of any kind. It's just as fast as using soap, but doesn't cut the wax job. Without the trail of suds, you'll have to pay closer attention to what you've washed and what you haven't, but you'll get pretty good at it with a little bit of practice.
Pat
I usually spray the most heavily soiled areas with a car wash/water solution in a spray bottle first to loosen up the dirt(the dirt usually breaks up and starts floating off) and follow up same as above using a cotton towel.
I need more proof than one person's testimony what works for him. I also believe smog, acid rain, salt and bird droppings would make it impossible for any wax or polymer job to last a year no matter how many times the vehicle is washed-soap or no soap...especially if it is not garaged. I would be very hesitant at this time to wash without using some type of car wash solution. I do believe you do not need huge suds to clean your car.
As to soap (detergents) disolving dirt - it's true that it does this - the detergent penetrates into the tiny cracks and releases the bonding and helps to "float" the dirt and grime like you say. BUT - in the process it is ALSO taking your wax with it. And as you know - you can't just count on the chemical "floating" action to clean, you have to use a little elbow grease to get the dirt to free up even when you're using soap.
Plain water WILL preserve your wax better and for MOST routine cleanings you just don't need soap. Try it. Rinse the car and get the area thoroughly wet, then use a soft cloth dunked in water to loosen the dirt gently - then rinse away the dirt you've loosened up manually.
Just because you're using detergents - soap - doesn't mean you're "protecting" the finish from tiny scratches when cleaning. You're getting just as much cloth contact with your finish whether you use soap or not. Think about it - if you soaped up a brillow pad or sand paper, would you feel any more safe than if you used just plain water? Of course not - same goes for your soft cotton rags or towels that you use. Use LOTS of water to keep the scratches at a minimum - and throw your soap away unless you just love waxing your vehicle!
Look, I don't think this would hurt any finish just to TRY it. As for the vinegar - I use that mainly to avoid spotting as I'm drying. I have had terrific success over ten years... I'm not trying to lead a revolt against the makers of car wash soap - but I do think you'd save a bunch of money and time if you do.
And of course Duckcaller is correct when he notes that any soap will reduce the longevity of a protectant. And also that the number one thing when washing a car is to use LOTS of water.
I do think that using soap does provide at least a little bit more of a "safety cushion" when washing the car--how much of one is certainly open to debate--and the price you pay for that safety cushion is shorter longevity for your wax.
Personally I prefer the safety cushion--and will take the time to apply protectant more often--but for other people whose priorities are different--Duckcaller presents a viable option.
I guess a lot of people would blanch at the thought of not using soap when washing a car. But I also see a lot of people recommend using a "quick detailer" type of product--which is just a spray bottle of mostly water with some alcohol and wax thrown in--to do light cleanings of an entire vehicle. Personally I would prefer washing a car with no soap and a lot of water to using a quick detailer for light cleanings.
Usually, when the car is too dirty to use only water, it is time for waxing. THEN, I use Dawn.
Seriously, I see mentions in several forums about using clay before waxing. I can guess it smoothes the finish, but it's all new to me. Can you, or anyone, direct me to someplace I can learn these techniques. I don't think my two year old liquid Maguire's is going to be the right answer for my new Sequoia.
Awhile ago, someone mentioned "liquid glass"; anyone else using it ?
http://www.autofanatics.com/waxselections.html
Collinite is best ordered online.
To learn about paint cleaning products like clay, you can go to Meguiars.com, Eagleone.com or try this: http://www.erazer.com/
http://www.autopia-carcare.com/waterspots.html
That sounds like a good idea to add 2 tablespoons of vinegar per gallon.
I REALLY LIKED # 20. This is going to become my "normal" wax, even though it is a little more expensive (about 15-20 $ per 16 ounces, but you can get large bottles that are a much better value per ounce).
I liked it for the following reasons:
1. I have a brand new 2001 truck (and of course, paint job!) No need to really polish or use buffing cleaners yet.(although I did buy #7 Show Car Glaze from Meguiars)
2. It went on easy and came off easy
3. It is supposed to be the longest protecting of any Meguiars product
I was very impressed when I did my truck, so impressed, that I did it twice.
Now to have fun, I did half of my trunk (this is the third coat now) with #26, that has some canruba wax in it, and the other half with Gold Class, also by Meguiars, but available everywhere (wal-mart, K-Mart, Pep-boys, etc) Just FYI, I liked the smell of Gold Class the best, but #26 just was so much glossier and deeper than Gold Class.
I put a 4th coat on, (all #26) and something neat happened. My hood actually had that "wet look" that everyone is talking about!
The hood had that slick wax feel that new cars in showrooms have. It had a deepness that #20 did not give it. Now from 3 feet away, I could not tell the difference between #20 and #26, and I actually felt that my surface felt smoother with #20.
#26 was also easy to apply and remove, although it had more of a drag than # 20.
SO, my opinion (and we all know what they say about opinions, they are like butt holes, every one has them!) since I have limited time to wax my truck, I want the best protection rather than the best shine, I want the protection to last, and I want it to be easy to put on and take off, and I WAS very happy with the shine after my first application, I will use # 20, and when I am feeling like I want to do my truck two or three times, will do a final coat with # 26.
While I loved the smell of Meguiars Gold Class, I thought it was harder to remove (needed more terry cloth towels), and I just liked # 26 better, of the two.
I did Like The Wax Shop Super Glaze, that was until I used #26. I find that the Super Glaze seems to wear off rather quickly.
BTW, I do not work for Meguiars, I just decided that company made since to me. They dont have a "miracle product", or a "ultra expensive caviar" type product, or a "one size fit's all" product, and they have been around for a long time, and I think they have a good reputation.
The person who made the comment about #20 Polymer Sealant being hard to find, is a valid statement! I found only 2 auto parts store (or any store for that matter) that sold it, and all they had were the old bottles of the stuff on the shelf. I had to mail order it.
We had to wash ALOT - the place we lived in was a car owners nightmare... right next to a huge cherry orchard and the building we lived in was home to hundreds of those mud-daubing bird nests (martins?). Literally, in the spring, you had to park a block away to wash your car or there'd be a half dozen bird droppings on it before you finished washing!! Also learned that wax seemed to last a lot longer if I didn't use any soap.
In addition to washing a lot, we all owned car covers that would take most of the abuse between washings... but inevitably you'd get two or three "hits" as you were pulling in and putting the cover on. Ugh - those were the days! We had to wax constantly since the bird drops inevitably burned through the wax job. I found that the more expensive products listing "pure Carnauba" seemed to hold up best against this abuse - believe I used a Maguires wax then.
On my current truck I have the "Toyo-gard" package that came with it... I've not used one of these sealants before, but it comes with the undercarriage spray and the window and door etching (anti-theft). I do save about 25 bucks a year on insurance, so in theory it will eventually "pay for itself." So far (one year) I'm quite pleased with it. Anybody know what I'll be facing in five years or more? Please, I know already that it's (allegedly) a big rip-off, but what's it going to LOOK like down the road.
I'm suprised you even found #20 in a retail store. The only place I could think of that stocked #20 is a Mirror Glaze store in Louisville, KY. That's why online mail-order is best; you'll get products fresh and fast.
FWIW, one of the many "wax cocktails" I used to make was one step of Super Glaze followed by a step of #26. On a non-clear coat paint job like I had, Super Glaze did an excellent job of polishing the paint, espeically with a buffer. But you're right, it doesn't last long. I don't believe it was designed to last.
Anybody out there come up with a cure for static cling? I know this has to frustrate a lot of people - you just get your ride looking super fine and look it over, only to find stuff drifting through the air being drawn to your car... like the output of the neighbor's lawnmower or dust from the construction site two blocks away?
Any of those dust-mop clingy things do any good?
dave
The husband of a former co-worker owned a body shop. You wouldn't believe the kind of wheelin' and dealin' that went on with him. Practically his whole house was furnished "free"; benefits of doing body work in lieu of cash payment.
Every body shop owner I've ever met has a boat and several cars. A couple guys I knew owned airplanes. Unbelieveable.
Meguiars cleaner/wax with good results but this time I want to start out with the right
stuff. My paint is very smooth and I havent waxed it yet. What do you all suggest in the
Meguiars line?? I was thinking of the Gold Class lineup but figured Id check here first
before I go and buy anything.
Also, once you polish and then wax the vehicle, is it necessary to polish every time
you wax or can you just wash and then wax?
TD
I had liquid glass on my 95 Pontiac it held up very well.
Having said that, I'll post a few of my faves:
1. Although I don't use it, Meguiars told me that Gold Class is their best product for shine/gloss. I think this is especially good on a dark car but you'll likely have to wax more often.
2. I've used Meguiars Medallion and found it to be great. It's Meguiars' longest lasting product but doesn't shine like Glod Class. It also repels dust better than other products. I found it to work great on black paint.
3. 3M makes great stuff. Their Imperial Hand Glaze is considered to be one of the best products of its kind. It's a fine hand polish to bring out the highest gloss. You'll need to follow it up with a good wax but you'll get fantastic results.
There are lots of excellent websites to check out. Meguiars.com, Eagleone.com, Carcareonline.com, dccarcare.com are just a few.
car glaze underneath but dont know what the difference is between the two. Does anyone
know??
TD
By the way, I haven't tried New Car Glaze but Show Car Glaze is phenominal.
I'm not familiar with New Car Glaze myself--but since it's called "New Car Glaze"--and Meguiar's recommends it for new cars--this would probably be the product you would want to use--I suspect it is a chemical cleaner that contains some mineral oils as well.
You would probably be fine just using the #26 Hi-Tech Yellow wax on a new car--a new car usually doesn't need much polishing IMHO.
